2018-02-02 20:05:06.187 was before configuration upgrade, sorry, but what to do to turn them on now?Barberousse wrote: Monday 05 February 2018 13:52where the read command returns only 4 fields, with 7 fields expected (???), and afterwards in your messages, I can now see 7 fields for 8 expected, because my plugin must ignore "IGN" type field.Code: Select all
2018-02-02 20:05:06.187 Error: (ebusd-a) parsing error on field count for value mc Mode temp0=22;mcmode=auto;=05;onoff=off (7 fields expected)
Python Plugin: ebusd
Esper
Re: Python Plugin: ebusd
Barberousse
You mean the "IGN" fields? I will upgrade my plugin to ignore them, next version probably (1.1.3), give me some time.
Barberousse
Could you try version 1.1.3 ?
Esper
Of course i can
(1.1.5?)
Its better, I can add multi value positions, but plugin is adding only first value. For example:
Maybe its connected with older probes? I will try some new positions.
New cc:Status0a - same situation:
2018-02-09 08:36:43.678 (E) Handle
2018-02-09 08:36:43.678 (E) Telnet write: read -v -c mc Mode
2018-02-09 08:36:43.678 (E) Sending 21 bytes of data:
2018-02-09 08:36:43.678 (E) 72 65 61 64 20 20 2d 76 20 2d 63 20 6d 63 20 4d 6f 64 65 0d read..-v.-c.mc.Mode.
2018-02-09 08:36:43.678 (E) 0a .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .
2018-02-09 08:36:43.728 (E) Received 129 bytes of data:
2018-02-09 08:36:43.728 (E) 6d 63 20 4d 6f 64 65 20 74 65 6d 70 64 65 73 69 72 65 64 3d mc.Mode.tempdesired=
2018-02-09 08:36:43.729 (E) 32 33 3b 6d 63 6d 6f 64 65 3d 61 75 74 6f 3b 66 6c 6f 6f 72 23;mcmode=auto;floor
2018-02-09 08:36:43.729 (E) 70 61 76 69 6e 67 64 72 79 69 6e 67 64 61 79 3d 30 3b 66 6c pavingdryingday=0;fl
2018-02-09 08:36:43.729 (E) 6f 6f 72 70 61 76 69 6e 67 64 72 79 69 6e 67 74 65 6d 70 3d oorpavingdryingtemp=
2018-02-09 08:36:43.729 (E) 30 3b 74 65 6c 65 73 77 69 74 63 68 6d 6f 64 65 3d 6f 66 66 0;teleswitchmode=off
2018-02-09 08:36:43.729 (E) 3b 6d 63 74 79 70 65 37 3d 6d 69 78 65 72 3b 64 61 79 6e 69 ;mctype7=mixer;dayni
2018-02-09 08:36:43.729 (E) 67 68 74 3d 64 61 79 0a 0a .. .. .. .. .. .. .. .. .. .. .. ght=day..
2018-02-09 08:36:43.729 (E) Calling message handler 'onMessage'.
2018-02-09 08:36:43.729 (E) onMessage called
2018-02-09 08:36:43.729 (E) Parse telnet buffer size 129
2018-02-09 08:36:43.730 (E) Reveived value: 'mc Mode tempdesired=23;mcmode=auto;floorpavingdryingday=0;floorpavingdryingtemp=0;teleswitchmode=off;mctype7=mixer;daynight=day'
2018-02-09 08:36:43.730 (E) Save whole fields values 23;auto;0;0;off;mixer;day
2018-02-09 08:36:43.730 (E - mc:Mode:0 - tempdesired) Updating device from 0:'' to have values 23:'23'.New cc:Status0a - same situation:
2018-02-09 08:44:56.102 (E) Handle
2018-02-09 08:44:56.102 (E) Telnet write: read -v -c cc Status0a
2018-02-09 08:44:56.102 (E) Sending 25 bytes of data:
2018-02-09 08:44:56.102 (E) 72 65 61 64 20 20 2d 76 20 2d 63 20 63 63 20 53 74 61 74 75 read..-v.-c.cc.Statu
2018-02-09 08:44:56.102 (E) 73 30 61 0d 0a .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. s0a..
2018-02-09 08:44:56.152 (E) Received 71 bytes of data:
2018-02-09 08:44:56.153 (E) 63 63 20 53 74 61 74 75 73 30 61 20 66 6c 6f 77 74 65 6d 70 cc.Status0a.flowtemp
2018-02-09 08:44:56.153 (E) 3d 2d 3b 6d 69 78 65 72 3d 6f 66 66 3b 70 75 6d 70 3d 6f 66 =-;mixer=off;pump=of
2018-02-09 08:44:56.153 (E) 66 3b 6f 6e 6f 66 66 3d 6f 66 66 3b 66 6c 6f 77 74 65 6d 70 f;onoff=off;flowtemp
2018-02-09 08:44:56.153 (E) 64 65 73 69 72 65 64 3d 30 0a 0a .. .. .. .. .. .. .. .. .. desired=0..
2018-02-09 08:44:56.153 (E) Calling message handler 'onMessage'.
2018-02-09 08:44:56.153 (E) onMessage called
2018-02-09 08:44:56.153 (E) Parse telnet buffer size 71
2018-02-09 08:44:56.153 (E) Reveived value: 'cc Status0a flowtemp=-;mixer=off;pump=off;onoff=off;flowtempdesired=0'
2018-02-09 08:44:56.153 (E) Save whole fields values -;off;off;off;0
2018-02-09 08:44:56.153 (E - cc:Status0a:0 - flowtemp) Updating device from 0:'-' to have values 0:'-'.
2018-02-09 08:44:56.156 (E) handleFifo() called-
Barberousse
What is your complete registers configuration line? If you want flowtemp and flowtempdesired for instance, you must have:Esper wrote: Friday 09 February 2018 8:41 Its better, I can add multi value positions, but plugin is adding only first value
cc:Status0a:0 cc:Status0a:4
cc:Status0a cc:Status0a:4
Maybe not well documented...
Esper
Sorry, my misunderstanding..
Last cases are clear..
New question about hwc:SetMode
Any idea?
2018-02-11 20:51:59.516 (E) Handle
2018-02-11 20:51:59.516 (E) Telnet write: read -v -c hwc SetMode
2018-02-11 20:51:59.516 (E) Sending 25 bytes of data:
2018-02-11 20:51:59.516 (E) 72 65 61 64 20 20 2d 76 20 2d 63 20 68 77 63 20 53 65 74 4d read..-v.-c.hwc.SetM
2018-02-11 20:51:59.516 (E) 6f 64 65 0d 0a .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. ode..
2018-02-11 20:51:59.566 (E) Received 24 bytes of data:
2018-02-11 20:51:59.566 (E) 68 77 63 20 53 65 74 4d 6f 64 65 20 68 77 63 6d 6f 64 65 3d hwc.SetMode.hwcmode=
2018-02-11 20:51:59.566 (E) 33 31 0a 0a .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. 31..
2018-02-11 20:51:59.566 (E) Calling message handler 'onMessage'.
2018-02-11 20:51:59.566 (E) onMessage called
2018-02-11 20:51:59.567 (E) Parse telnet buffer size 24
2018-02-11 20:51:59.567 (E) Reveived value: 'hwc SetMode hwcmode=31'
2018-02-11 20:51:59.567 (E) Save whole fields values 31
2018-02-11 20:51:59.567 Error: (E) 'onMessage' failed 'UnboundLocalError':'local variable 'iValue' referenced before assignment'.
2018-02-11 20:51:59.567 Error: (E) ----> Line 745 in /home/pi/domoticz/plugins/DomoticzEbusd/plugin.py, function onMessage
2018-02-11 20:51:59.567 Error: (E) ----> Line 552 in /home/pi/domoticz/plugins/DomoticzEbusd/plugin.py, function onMessage
2018-02-11 20:51:59.567 Error: (E) ----> Line 272 in /home/pi/domoticz/plugins/DomoticzEbusd/plugin.py, function parseTelnet
2018-02-11 20:51:59.567 Error: (E) ----> Line 893 in /home/pi/domoticz/plugins/DomoticzEbusd/plugin.py, function valueEbusdToDomoticz
2018-02-11 20:52:00.168 (E) Calling message handler 'onHeartbeat'.-
Barberousse
Did you change your ebusd configuration? Based on the data.json you send, the command "read -v -c hwc.SetMode" should return 10 fields, you received only one. Could you try again with version 1.1.8?Esper wrote: Sunday 11 February 2018 20:54Code: Select all
2018-02-11 20:51:59.516 (E) Handle 2018-02-11 20:51:59.516 (E) Telnet write: read -v -c hwc SetMode 2018-02-11 20:51:59.516 (E) Sending 25 bytes of data: 2018-02-11 20:51:59.516 (E) 72 65 61 64 20 20 2d 76 20 2d 63 20 68 77 63 20 53 65 74 4d read..-v.-c.hwc.SetM 2018-02-11 20:51:59.516 (E) 6f 64 65 0d 0a .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. ode.. 2018-02-11 20:51:59.566 (E) Received 24 bytes of data: 2018-02-11 20:51:59.566 (E) 68 77 63 20 53 65 74 4d 6f 64 65 20 68 77 63 6d 6f 64 65 3d hwc.SetMode.hwcmode= 2018-02-11 20:51:59.566 (E) 33 31 0a 0a .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. 31..
Esper
Its much better on 1.1.9.
My JSON for hwc.SetMode
line from hwcmode.inc
and new situation:
1. Trying to change "hwc:SetMode:0" on --> auto
2. plugin is trying to write hwcmode auto
3. after 1-2 seconds Mode on is back
Debug log (is setmode ON)
I'm afraid, then value 31 is an ebusd error..
"SetMode": {
"name": "SetMode",
"passive": false,
"write": false,
"lastup": 0,
"zz": 37,
"id": [
181,
4,
2
"fielddefs": [
"name": "hwcmode",
"slave": true,
"type": "UCH",
"isbits": false,
"length": 1,
"values": {
"0": "disabled",
"1": "on",
"2": "off",
"3": "auto"
"unit": "",
"comment": "hot water mode"
},Code: Select all
w,,SetMode,Set operation mode,,,,02,,,hwcmode,,,
2018-02-12 16:00:12.688 (E) Handle
2018-02-12 16:00:12.689 (E) Telnet write: write -c hwc setmode on
2018-02-12 16:00:12.689 (E) Sending 25 bytes of data:
2018-02-12 16:00:12.689 (E) 77 72 69 74 65 20 2d 63 20 68 77 63 20 73 65 74 6d 6f 64 65 write.-c.hwc.setmode
2018-02-12 16:00:12.689 (E) 20 6f 6e 0d 0a .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .on..
2018-02-12 16:00:12.839 (E) Received 6 bytes of data:
2018-02-12 16:00:12.839 (E) 64 6f 6e 65 0a 0a .. .. .. .. .. .. .. .. .. .. .. .. .. .. done..
2018-02-12 16:00:12.839 (E) Calling message handler 'onMessage'.
2018-02-12 16:00:12.839 (E) onMessage called
2018-02-12 16:00:12.840 (E) Parse telnet buffer size 6
2018-02-12 16:00:12.840 (E) Reveived value: 'done'
2018-02-12 16:00:12.840 (E) handleFifo() called
2018-02-12 16:00:12.840 (E) Handle
2018-02-12 16:00:12.840 (E) Telnet write: read -v -c hwc setmode
2018-02-12 16:00:12.840 (E) Sending 25 bytes of data:
2018-02-12 16:00:12.840 (E) 72 65 61 64 20 20 2d 76 20 2d 63 20 68 77 63 20 73 65 74 6d read..-v.-c.hwc.setm
2018-02-12 16:00:12.840 (E) 6f 64 65 0d 0a .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. ode..
2018-02-12 16:00:12.991 (E) Received 24 bytes of data:
2018-02-12 16:00:12.991 (E) 68 77 63 20 53 65 74 4d 6f 64 65 20 68 77 63 6d 6f 64 65 3d hwc.SetMode.hwcmode=
2018-02-12 16:00:12.991 (E) 33 31 0a 0a .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. .. 31..
2018-02-12 16:00:12.991 (E) Calling message handler 'onMessage'.
2018-02-12 16:00:12.991 (E) onMessage called
2018-02-12 16:00:12.991 (E) Parse telnet buffer size 24
2018-02-12 16:00:12.991 (E) Reveived value: 'hwc SetMode hwcmode=31'
2018-02-12 16:00:12.991 (E) Save whole fields values 31
2018-02-12 16:00:12.991 (E - hwc:SetMode:0 - hwcmode) Updating device from 31:'31' to have values 31:'31'.
2018-02-12 16:00:12.997 (E) handleFifo() called
Barberousse
Is your JSON definition for hwc.SetMode the same with http://EbusIP:EbusPort/data?def&write ?
Esper
Barberousse wrote: Monday 12 February 2018 17:40 Is your JSON definition for hwc.SetMode the same with http://EbusIP:EbusPort/data?def&write ?
"SetMode": {
"name": "SetMode",
"passive": false,
"write": true,
"lastup": 1518451958,
"zz": 37,
"id": [
181,
5,
2
"fields": {
"hwcmode": {
"value": "auto"
"fielddefs": [
"name": "hwcmode",
"slave": false,
"type": "UCH",
"isbits": false,
"length": 1,
"values": {
"0": "disabled",
"1": "on",
"2": "off",
"3": "auto"
"unit": "",
ebusctl -p 8000 r -c hwc SetMode
ERR: element not found
"fields": {
"hwcmode": {
"value": "auto"
Barberousse
I'm confused, maybe you should fill a bug report in https://github.com/john30/ebusd or https://github.com/john30/ebusd-configuration, it seems to be an issue there, the read command should return "disabled", "on, "off" or "auto", not 31...
pigloox
- Domoticz version: BETA
Hi,Barberousse wrote: Saturday 09 December 2017 16:33 I can read external probe and internal room thermostat for sure (f47:RoomTemp, broadcast:outsidetemp), pipe pressure can be read with bai:WaterPressure, for gaz consumption I'm not sure.
I have these registers:
bai AccessoriesOne = no data stored bai AccessoriesTwo = no data stored bai ACRoomthermostat = no data stored bai APCComStatus = no data stored bai APCLegioProtection = no data stored bai averageIgnitiontime = no data stored bai BlockTimeHcMax = no data stored bai BoilerType = no data stored bai ChangesDSN = no data stored bai CirPump = no data stored bai CounterStartattempts1 = no data stored bai CounterStartattempts2 = no data stored bai CounterStartAttempts3 = no data stored bai CounterStartAttempts4 = no data stored bai currenterror = no data stored bai DateTime = no data stored bai dcfState = no data stored bai DCFTimeDate = no data stored bai DCRoomthermostat = no data stored bai DeactivationsIFC = no data stored bai DeactivationsTemplimiter = no data stored bai DeltaFlowReturnMax = no data stored bai DisplayMode = no data stored bai DSN = no data stored bai DSNOffset = no data stored bai DSNStart = no data stored bai EBusHeatcontrol = no data stored bai EbusSourceOn = no data stored bai EbusVoltage = no data stored bai errorhistory = no data stored bai expertlevel_ReturnTemp = no data stored bai ExternalFaultmessage = no data stored bai externalFlowTempDesired = no data stored bai externalHwcSwitch = no data stored bai ExternGasvalve = no data stored bai ExtFlowTempDesiredMin = no data stored bai ExtStorageModulCon = no data stored bai extWP = no data stored bai FanHours = no data stored bai FanMaxSpeedOperation = no data stored bai FanMinSpeedOperation = no data stored bai FanPWMSum = no data stored bai FanPWMTest = no data stored bai FanSpeed = no data stored bai FanSpeedOffsetMax = no data stored bai FanSpeedOffsetMin = no data stored bai FanStarts = no data stored bai Flame = no data stored bai FlameSensingASIC = no data stored bai FloorHeatingContact = no data stored bai FlowsetHcMax = no data stored bai FlowsetHwcMax = no data stored bai FlowSetPotmeter = no data stored bai FlowTemp = 43.12;ok bai FlowTempDesired = 51.50 bai FlowTempMax = no data stored bai Fluegasvalve = no data stored bai FluegasvalveOpen = no data stored bai Gasvalve3UC = no data stored bai Gasvalve = no data stored bai GasvalveASICFeedback = no data stored bai GasvalveUC = no data stored bai GasvalveUCFeedback = no data stored bai HcHours = no data stored bai HcPumpMode = no data stored bai HcPumpStarts = no data stored bai HcStarts = no data stored bai HcUnderHundredStarts = no data stored bai HeatingSwitch = no data stored bai HoursTillService = no data stored bai HwcDemand = no data stored bai HwcHours = no data stored bai HwcImpellorSwitch = no data stored bai HwcPostrunTime = no data stored bai HwcSetPotmeter = no data stored bai HwcStarts = no data stored bai HwcSwitch = no data stored bai HwcTemp = no data stored bai HwcTempDesired = no data stored bai HwcTempMax = no data stored bai HwcTypes = no data stored bai HwcUnderHundredStarts = no data stored bai HwcWaterflow = no data stored bai HwcWaterflowMax = no data stored bai Ignitor = no data stored bai InitialisationEEPROM = no data stored bai IonisationVoltageLevel = no data stored bai maintenancedata_HwcTempMax = no data stored bai maxIgnitiontime = no data stored bai minIgnitiontime = no data stored bai ModulationTempDesired = no data stored bai OutdoorstempSensor = no data stored bai OverflowCounter = no data stored bai ParamToken = no data stored bai PartloadHcKW = no data stored bai PartloadHwcKW = no data stored bai PartnumberBox = no data stored bai PositionValveSet = no data stored bai PowerValue = no data stored bai PrAPSCounter = no data stored bai PrAPSSum = no data stored bai PrEnergyCountHc1 = no data stored bai PrEnergyCountHc2 = no data stored bai PrEnergyCountHc3 = no data stored bai PrEnergyCountHwc1 = no data stored bai PrEnergyCountHwc2 = no data stored bai PrEnergyCountHwc3 = no data stored bai PrEnergySumHc1 = no data stored bai PrEnergySumHc2 = no data stored bai PrEnergySumHc3 = no data stored bai PrEnergySumHwc1 = no data stored bai PrEnergySumHwc2 = no data stored bai PrEnergySumHwc3 = no data stored bai ProductionByte = no data stored bai PrVortexFlowSensorValue = no data stored bai PumpHours = no data stored bai PumpHwcFlowNumber = no data stored bai PumpHwcFlowSum = no data stored bai RemainingBoilerblocktime = no data stored bai ReturnRegulation = no data stored bai ReturnTemp = 42.31;64858;ok bai ReturnTempMax = no data stored bai SecondPumpMode = no data stored bai SerialNumber = no data stored bai SetFactoryValues = no data stored bai SetMode = auto;51.5;55.0;-;0;0;0;0;0;0 bai SHEMaxDeltaHwcFlow = no data stored bai SHEMaxFlowTemp = no data stored bai SolPostHeat = no data stored bai Statenumber = no data stored bai Status01 = 38.0;33.0;-;53.0;52.5;on bai Status02 = auto;60;75.0;100;65.0 bai Status16 = no data stored bai Status = no data stored bai Storageloadpump = no data stored bai StorageLoadPumpHours = no data stored bai StorageloadPumpStarts = no data stored bai StorageLoadTimeMax = no data stored bai StoragereleaseClock = no data stored bai StorageTemp = 38.50;ok bai StorageTempDesired = 55.00 bai StorageTempMax = no data stored bai TargetFanSpeed = no data stored bai TargetFanSpeedOutput = no data stored bai TempDiffBlock = no data stored bai TempDiffFailure = no data stored bai TempGradientFailure = no data stored bai Templimiter = no data stored bai TemplimiterWithNTC = no data stored bai TempMaxDiffExtTFT = no data stored bai Testbyte = no data stored bai TimerInputHc = no data stored bai ValveMode = no data stored bai ValveStarts = no data stored bai VolatileLockout = no data stored bai VolatileLockoutIFCGV = no data stored bai VortexFlowSensor = no data stored bai WarmstartDemand = no data stored bai WarmstartOffset = no data stored bai WaterHcFlowMax = no data stored bai WaterPressure = no data stored bai WaterpressureBranchControlOff = no data stored bai WaterpressureMeasureCounter = no data stored bai WaterpressureVariantSum = no data stored bai WP = no data stored bai WPPostrunTime = no data stored bai WPSecondStage = no data stored broadcast datetime = no data stored broadcast error = no data stored broadcast hwcStatus = no data stored broadcast id = no data stored broadcast id = no data stored broadcast load = no data stored broadcast netloss = no data stored broadcast netresetcfg = no data stored broadcast netresetstate = no data stored broadcast outsidetemp = 5.000 broadcast signoflife = no data stored broadcast vdatetime = 16:28:52;09.12.2017 f47 ACTOstorDetected = no data stored f47 actoSTOROPMode = no data stored f47 ActualRoomTempDesiredHc1 = no data stored f47 ActualWeekday = no data stored f47 ADCValueTempabove = no data stored f47 ADCValueTempbelow = no data stored f47 ASCDetected = no data stored f47 B51000M10HwcFlowSetMon = no data stored f47 B51000M12DisableBitsMon = no data stored f47 B51000M14Monitor = no data stored f47 B51000M7OpModeMonitor = no data stored f47 B51000M8HeatFlowSetMonitor = no data stored f47 B51000M9TappingSetMon = no data stored f47 B51000TempDesiredLoadingPump = no data stored f47 BMUB51101BoilerFlowTemp = no data stored f47 BMUB51101ErrorStatus = no data stored f47 BMUB51101HwcState = no data stored f47 BMUB51101StorageTemp = no data stored f47 BMUFlowTempOrVF1 = no data stored f47 CalculatedKickStopTime = no data stored f47 ccTimer.Friday = no data stored f47 ccTimer.Monday = no data stored f47 ccTimer.Saturday = no data stored f47 ccTimer.Sunday = no data stored f47 ccTimer.Thursday = no data stored f47 ccTimer.Tuesday = no data stored f47 ccTimer.Wednesday = no data stored f47 ChimneySweepModeActive = no data stored f47 CirPump = no data stored f47 ClockSwitchSummerWinterDone = no data stored f47 ContactName = no data stored f47 ContinuosHeating = no data stored f47 CountryVariant = no data stored f47 CPLPLast24started = no data stored f47 currenterror = no data stored f47 Date = no data stored f47 DcfIsValid = no data stored f47 DisplayedHc1RoomTempDesired = no data stored f47 DisplayedHwcStorageTemp = no data stored f47 DisplayedRoomTemp = no data stored f47 EepromUpdateActive = no data stored f47 EnermanState = no data stored f47 errorhistory = no data stored f47 ExcessTemp = no data stored f47 FactoryTestActive = no data stored f47 FrostOverRideTime = no data stored f47 FrostProtectDelayMonitor = no data stored f47 FrostProtectionRequiredMonitor = no data stored f47 FrostProtectStateMonitor = no data stored f47 GlobalSystemOff = no data stored f47 Hc1ActualFlowTempDesired = no data stored f47 Hc1AutoOffMode = no data stored f47 Hc1BankHolidayEndPeriod = no data stored f47 Hc1BankHolidayStartPeriod = no data stored f47 Hc1DayTemp = 18.5 f47 Hc1FloorPavementDryingDay = no data stored f47 Hc1FloorPavementDryingTemp = no data stored f47 Hc1HcType = no data stored f47 Hc1HeatCurve = no data stored f47 Hc1HolidayEndPeriod = no data stored f47 Hc1HolidayRoomTemp = no data stored f47 Hc1HolidayStartPeriod = no data stored f47 Hc1MinimalFlowTempDesired = no data stored f47 Hc1NightTemp = no data stored f47 Hc1OPMode = auto f47 Hc1PreCutOffActive = no data stored f47 Hc1PreOrContinuosHeatingActive = no data stored f47 Hc1Pump = no data stored f47 Hc1PumpLast24started = no data stored f47 Hc1QuickVetoTemp = no data stored f47 Hc1RoomTempSwitchOn = no data stored f47 Hc1SFMode = none f47 Hc1SummerOffset = no data stored f47 Hc2BankHolidayEndPeriod = no data stored f47 Hc2BankHolidayPeriodIsActive = no data stored f47 Hc2BankHolidayStartPeriod = no data stored f47 Hc2HcType = no data stored f47 Hc2HolidayEndPeriod = no data stored f47 Hc2HolidayPeriodIsActive = no data stored f47 Hc2HolidayStartPeriod = no data stored f47 Hc2OPMode = no data stored f47 Hc2SFMode = no data stored f47 Hc2TempDesiredB50418 = no data stored f47 HcMc1ConfigCPLP = no data stored f47 HcMc1CPLPState = no data stored f47 HcMc1Detected = no data stored f47 HcName1 = no data stored f47 HcName2 = no data stored f47 hcTimer.Friday = no data stored f47 hcTimer.Monday = no data stored f47 hcTimer.Saturday = no data stored f47 hcTimer.Sunday = no data stored f47 hcTimer.Thursday = no data stored f47 hcTimer.Tuesday = no data stored f47 hcTimer.Wednesday = no data stored f47 HwcActualTempDesired = no data stored f47 HwcCircuitActive = no data stored f47 HwcLegioStartDay = no data stored f47 HwcLegioStartTime = no data stored f47 HwcLoadingIn430Active = no data stored f47 HwcLoadingOffset = no data stored f47 HwcOPMode = no data stored f47 HwcParallelLoading = no data stored f47 HwcPressLowpostrunningtime = no data stored f47 HwcTempDesired = no data stored f47 hwcTimer.Friday = no data stored f47 hwcTimer.Monday = no data stored f47 hwcTimer.Saturday = no data stored f47 hwcTimer.Sunday = no data stored f47 hwcTimer.Thursday = no data stored f47 hwcTimer.Tuesday = no data stored f47 hwcTimer.Wednesday = no data stored f47 HydraulicMap = no data stored f47 HydraulicSwitch = no data stored f47 InstallAssistant = no data stored f47 KeyCodeforConfigMenu = no data stored f47 LanguageVariant = no data stored f47 LcdContrastValue = no data stored f47 LegioProtectActive = no data stored f47 MaintenanceDate = no data stored f47 MonitorCurrentIPart = no data stored f47 MonitorEEpromInkonsiNumber = no data stored f47 OpModeEffect = no data stored f47 OutsideTemp = 9.81;ok f47 OutsideTempOffset = no data stored f47 PhoneNumber = no data stored f47 PreheatingTime = no data stored f47 PreStopTime = no data stored f47 PumpBlockingTimeMax = no data stored f47 PumpEnergySaveCalculatedTimeMonitor = no data stored f47 PumpEnergySaveStateMonitor = no data stored f47 RaumtempIstOben = no data stored f47 RaumtempIstUnten = no data stored f47 RoomTemp = 18.56;ok f47 RoomTempCorrection = no data stored f47 RoomTempOffsetSelfWarming = no data stored f47 SolModuleDetected = no data stored f47 StartEepromUpdate = no data stored f47 StatusDcf = no data stored f47 SummerWinterTimeAdjust = no data stored f47 TestVarActivateFunction = no data stored f47 Time = no data stored f47 V430PluggedIn = no data stored f47 VF1 = no data stored f47 VR81ActiveForHc1 = no data stored f47 VR81ActiveForHc2 = no data stored f47 VR81Detected = no data stored f47 YieldLastYear = no data stored f47 YieldThisYear = 0;0;0;0;0;0;0;0;0;0;0;0 general valuerange = no data stored mc ActualTempDesired = no data stored mc AutoOffMode = no data stored mc BoilerCircuitPump = no data stored mc BoilerMaxPreShutdown = no data stored mc CirPump = no data stored mc currenterror = -;-;-;-;- mc Date = no data stored mc DayNightState = no data stored mc DisplayedRoomTempDesired = no data stored mc errorhistory = no data stored mc FloorPavingDryingDay = no data stored mc FloorPavingDryingTemp = no data stored mc Flow1Sensor = 25.38;ok mc FlowTempDesired = 26.0 mc FlowTempMax = no data stored mc FlowTempMin = no data stored mc FrostProtConfig = no data stored mc FrostProtectDelay = no data stored mc FrostProtState = no data stored mc Hc1PumpKol1PP1Port = no data stored mc Hc2aLegPumpP2Port = no data stored mc Hc2CircuitType = no data stored mc Hc2ContinuosHeating = no data stored mc Hc2ManualOPRoomTempDesired = no data stored mc Hc2pDemand = no data stored mc Hc2PumpAlPort = no data stored mc Hc2QuickVetoActive = no data stored mc Hc2QuickVetoTemp = no data stored mc Hc2RoomControlMode = no data stored mc Hc2SummerOffset = no data stored mc Hc2zPort = no data stored mc HcFlowIncrease = no data stored mc HcParallelStorageFillingEnabled = no data stored mc HcPreHeatingActive = no data stored mc HcPreShutdownActive = no data stored mc HcPumpIdlePeriod = no data stored mc HcPumpIdlePeriodActive = no data stored mc hcTimer.Friday = no data stored mc hcTimer.Monday = no data stored mc hcTimer.Saturday = no data stored mc hcTimer.Sunday = no data stored mc hcTimer.Thursday = no data stored mc hcTimer.Tuesday = no data stored mc hcTimer.Wednesday = no data stored mc HeatingCurve = no data stored mc HolidayTempDesired = no data stored mc InternalOperatingMode470 = auto mc IsInBankHoliday = no data stored mc IsInHoliday = no data stored mc IsInImpactVentilation = no data stored mc IsInOneDayBankHoliday = no data stored mc IsInOneDayHoliday = no data stored mc IsInParty = no data stored mc IsInSystemOff = no data stored mc Mixer1DutyCycle = no data stored mc Mixer1State = no data stored mc MonitorEEpromInkonsiNumber = no data stored mc OffConfig = no data stored mc PreheatingMinutesMax = no data stored mc PsTempDesired = no data stored mc PumpSavingState = no data stored mc Setpoints.Friday = no data stored mc Setpoints.Monday = 18.5;18.5;18.5 mc Setpoints.Saturday = no data stored mc Setpoints.Sunday = no data stored mc Setpoints.Thursday = no data stored mc Setpoints.Tuesday = no data stored mc Setpoints.Wednesday = no data stored mc SfState = no data stored mc SunMoonInfo = no data stored mc TempDesiredLow = no data stored mc ThermostatState = no data stored mc Time = no data stored mc Weekday = no data stored memory eeprom = no data stored memory ram = no data stored scan id = no data stored scan.08 = Vaillant;BAI00;0609;5502 scan.08 id = 21;16;38;0020221905;0001;005608;N2 scan.15 = Vaillant;F4700;0114;6102 scan.15 id = 21;16;31;0020108135;0082;008704;N0 scan.50 = Vaillant;V6100;0418;1902 scan.50 id = 21;16;05;0020139850;0082;005136;N0 scan.f6 = Vaillant;F4700;0114;6102 scan.f6 id = 21;16;31;0020108135;0082;008704;N0
How can you list these registers ?
RPI3 Stretch (Hard disk)
-RFXtrx433 USB
-OpenZwave USB
-Teleinfo USB
-RFXtrx433 USB
-OpenZwave USB
-Teleinfo USB
fantom
ebusctl find
Fantom
ps. I today connect Vaillant to my RPI. Next i look on this script.
ebusctl find
Fantom
Barberousse
Or you can open and see available registers from your favorite internet browser, for instance at this address: http://192.168.0.10:8889/data?def (change IP address to ebusd hosting device IP address or name, change 8889 port to whatever port you configured for HTTP JSON). But before, ebusd must be configured with --httpport 8889 option for instance:
# /etc/default/ebusd:
# config file for ebusd service.
# Options to pass to ebusd (run "ebusd -?" for more info):
EBUSD_OPTS="--scanconfig --httpport 8889"
fantom
I have first prolem with plugin:
2018-02-15 21:14:00.382 (ebus) Started.
2018-02-15 21:14:00.688 (ebus) Entering work loop.
2018-02-15 21:14:00.688 (ebus) Initialized version 1.1.9, author 'Barberousse'
2018-02-15 21:14:00.693 (ebus) onStart called
2018-02-15 21:14:00.693 (ebus) IP or named address set to 192.168.1.2
2018-02-15 21:14:00.693 (ebus) Telnet port set to 8888
2018-02-15 21:14:00.693 (ebus) JSON HTTP port set to 8889
2018-02-15 21:14:00.693 (ebus) Registers set to bai:SetMode:hwctempdesired
2018-02-15 21:14:00.693 (ebus) Refresh rate set to 600
2018-02-15 21:14:00.693 (ebus) Disable cache set to False
2018-02-15 21:14:00.693 (ebus) Read-only set to True
2018-02-15 21:14:00.693 (ebus) Debug set to Normal
2018-02-15 21:14:00.809 PluginSystem: Restarting I/O service thread.
2018-02-15 21:14:01.097 (ebus) Add device bai:setmode:hwctempdesired (bai:bai:2) unit 1 as type Temperature: temperature
2018-02-15 21:14:01.262 Error: (ebus) Error from telnet client: no data stored
2018-02-15 21:14:10.286 Error: (ebus) Error from telnet client: no data stored
2018-02-15 21:14:12.331 (ebus) Stop directive received.
2018-02-15 21:14:12.770 (ebus) Exiting work loop.
2018-02-15 21:14:17.337 Error: (ebus) Plugin did not stop after 5 seconds, flushing event queue...
2018-02-15 21:14:17.337 (ebus) Stopping threads.
2018-02-15 21:14:17.337 (ebus) Stopped.
Fantom
Fantom
Barberousse
Thank you for you message, I saw an error in the plugin, but it won't solve your problem. Could you upgrade the plugin to version 1.2.0? After that, you should have a "bai:bai:2" device and "bai:setmode:2" device in Domoticz / Setup / Devices, delete "bai:bai:2" device (look at hardware column).
For your problem, could you post the log with Debug enabled in plugin settings? Could you post the result of the command
ebusctl read -v -c bai setmode
pigloox
Barberousse wrote: Thursday 15 February 2018 20:49Or you can open and see available registers from your favorite internet browser, for instance at this address: http://192.168.0.10:8889/data?def (change IP address to ebusd hosting device IP address or name, change 8889 port to whatever port you configured for HTTP JSON). But before, ebusd must be configured with --httpport 8889 option for instance:
The httpport option is needed for the plugin to work.Code: Select all
# /etc/default/ebusd: # config file for ebusd service. # Options to pass to ebusd (run "ebusd -?" for more info): EBUSD_OPTS="--scanconfig --httpport 8889"
Thank you for the info, it works well and related to your first post, I confirm that your plugin also works for my boiler saunier duval.
Another question, is it possible to send values to the boiler (temperature setpoint or time) ??? And if yes, how please ?
Thx
-RFXtrx433 USB
-OpenZwave USB
-Teleinfo USB
-RFXtrx433 USB
-OpenZwave USB
-Teleinfo USB
Barberousse
Yes, it works for me, but you have to choose carefully the right register, they don't have all write access, some registers are read-only copy from others. To see writable registers, go to http://192.168.0.10:8889/data?def&write (change IP address to ebusd hosting device IP address or name, change 8889 port to whatever port you configured for HTTP JSON). Don't forget the "&write". Look at registers with name ending with "-w", for instance "SetPoint-w".pigloox wrote: Friday 16 February 2018 13:46 is it possible to send values to the boiler (temperature setpoint or time) ??? And if yes, how please ?
For writable registers containing temperature for instance, the plugin will create a Setpoint you can change. For multiple values, it will create a selector switches, for on/off or yes/no values, it will create a simple switch.
If you initially started the plugin with read-only option enabled, delete devices from Setup -> Devices, and after that disable the read-only option, and click on modify in setup page of the plugin. It will recreate devices as writable, when declared as such by ebusd configuration.
pigloox
I have only this with "write": trueBarberousse wrote: Friday 16 February 2018 14:00
"queryexistence": {
"name": "queryexistence",
"passive": false,
"write": true,
"lastup": 0,
"zz": 254,
"id": [7, 254],
"fielddefs": [
"ident-w": {
"name": "ident",
"passive": false,
"write": true,
"lastup": 0,
"zz": 254,
"id": [7, 4],
"fielddefs": [
Nothing can be written or there is also an option at the level of the deamon to activate to be in writing?
(see all datas if you want in attachements)
-RFXtrx433 USB
-OpenZwave USB
-Teleinfo USB
-RFXtrx433 USB
-OpenZwave USB
-Teleinfo USB
Barberousse
I don't know what the "write" : "true" means in JSON data, we should ask to ebusd author, or look at source code. I know that to be able to read registers, also know as messages, the ebusd configuration must define a write message, and the only one I can see in your data.txt file is "ident-w", and is not very useful. It probably means that your ebusd configuration must be updated to include more write messages. You can still do trial/error tests by modifying the CSV file of you boiler, replacing "r" with "r;w" in first column when you think it should be writable, restart ebusd daemon, and try to write and see with "ebusctl write" command. If you succeed, propose a modification opening an issue or a pull request on https://github.com/john30/ebusd-configurationpigloox wrote: Friday 16 February 2018 14:18 Nothing can be written or there is also an option at the level of the deamon to activate to be in writing?
