Cannot change Alarm state in LUA script
SayHi
Post by SayHi »
Hi All,
I made a dummy switch(name: SetSecurity) to toggle the alarm status. It triggers the LUA script, but it doesn't really work. It seems tot change the "otherdevices['Domoticz Security Panel'" to normal state, but will not set the status. It seems not to remember....
What am i doing wrong?
Tnx
print("______________________________________________________________")
print(otherdevices["Domoticz Security Panel"])
if (devicechanged['SetSecurity'] == 'On') then
print('Wanna arm:')
otherdevices['Domoticz Security Panel'] = 'Arm Home'
if (devicechanged['SetSecurity'] == 'Off') then
print('Wanna disarm:')
otherdevices['Domoticz Security Panel'] = 'Normal'
print("++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++")
--Arm Home
2018-02-08 16:01:33.888 User: XXXXinitiated a switch command (1388/SetSecurity/Off)
2018-02-08 16:01:34.009 dzVents: Device based event fired on 'SetSecurity', value 'Off'
2018-02-08 16:01:34.019 dzVents: All based event fired
2018-02-08 16:01:34.025 dzVents: ______________________________________________________________
2018-02-08 16:01:34.025 dzVents: Arm Home
2018-02-08 16:01:34.025 dzVents: Wanna disarm:
2018-02-08 16:01:34.025 dzVents: Normal
2018-02-08 16:01:34.025 dzVents: ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
2018-02-08 16:01:34.026 (DummyHardware) Lighting 2 (SetSecurity)
2018-02-08 16:01:52.793 User: XXXXinitiated a switch command (1388/SetSecurity/On)
2018-02-08 16:01:52.907 dzVents: Device based event fired on 'SetSecurity', value 'On'
2018-02-08 16:01:52.917 dzVents: All based event fired
2018-02-08 16:01:52.924 dzVents: ______________________________________________________________
2018-02-08 16:01:52.924 dzVents: Arm Home
2018-02-08 16:01:52.924 dzVents: Wanna arm:
2018-02-08 16:01:52.924 dzVents: ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
2018-02-08 16:01:52.925 (DummyHardware) Lighting 2 (SetSecurity)
2018-02-08 16:02:00.506 dzVents: Time based event fired
2018-02-08 16:02:00.513 dzVents: All based event fired
https://snag.gy/dpIt7D.jpg
SayHi
Re: Cannot change Alarm state in LUA script
Post by SayHi »
Did another try today, but did not succeed :oops: ... anybody?
emme
Domoticz version: latest
Post by emme »
it is NOT 'Normal'
it is 'Disarm'
"We always done this way"
SayHi
Post by SayHi »
Hi Emme,
Thank you for your reply.
Disarm isn't working either. The value of otherdevices["Domoticz Security Panel"] is "Normal" if i use the Panel with a code.
That's why I was using "Normal".
SayHi
Post by SayHi »
mmm, cannot insert image :oops:
Link image of different states of the varable:
https://pasteboard.co/H7LK93n.jpg
emme
Post by emme »
I'm quite sure it should be 'Disarm'
do Arm Home and Arm Away work as they are supposed to?
is the panel name correct?
Are you using a linux based hardware?
jvdz
Domoticz version: 4.107
Post by jvdz »
emme wrote: Thursday 15 February 2018 17:09 I'm quite sure it should be 'Disarm'
Correct! the command to get the state to Normal/DIsarmed is "Disarm".
Jos
SayHi
Post by SayHi »
I'm indeed on a Raspberry Pi. Does that make a difference?
The screenshot above is a when i Arm/disarm manualy with a code in de security panel.
But setting it to Disarm doesn't make a difference. It's like it doesn't rememeber it after I leave the Lua script
emme
Post by emme »
uh oh.... I think I got it!
otherdevices['Domoticz Security Panel'] = 'Disarm'
please note that the second print will STILL display Armed Home... the commandarray is executed at the end of the script so, you will see Armed Home, but if tyou check the log you should see Normal!!!
the script runs correctly (except tha tyou have to issue Disarm and not Normal) but you cannot get the right state
emme
Post by emme »
this is the same script in dzVents
		devices = { 'SetSecurity' },
	logging = {
        level = domoticz.LOG_INFO,
        marker = '[SET SECURITY]'
	execute = function(dz, device)
	    dz.log('______________________________________________________________')
	    local secPanel = dz.devices('Domoticz Security Panel')
        dz.log('Actual security State ==> '..secPanel.state)
        if device.state == 'On' and secPanel.state:gsub(1,3) ~= 'Arm' then
            dz.log('Wanna arm!')
            secPanel.armHome()
        elseif device.state == 'On' and secPanel.state:gsub(1,3) == 'Arm' then
            dz.log('Wanna Disarm!')
            secPanel.disarm()
        dz.log('++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++')
I have only added a second check to arm/disarm only in case the system is not already armed/disarmed
SayHi
Post by SayHi »
emme wrote: Thursday 15 February 2018 18:18 uh oh.... I think I got it!
Thank you for thinking along with me!
But... the second print is displaying it correct:
it display's "normal", but it seems not to remember the state.
Really don't understand... I will do a new install on another rasp....
SayHi
Post by SayHi »
Yeah, got it....
ok here goes:
The status of "Security Panel" when disarmed is "Normal"
To change the state of Security Panel, set it to "Disarm"
I used otherdevices['Security Panel'] = 'Normal' and otherdevices['Security Panel'] = 'Disarm'
But they didn't work. Set the status with commandArray, not otherdevices
commandArray['Security Panel'] = 'Disarm' Works like a charm!
