Doorbell in Domoticz with window sensor
domogijs
Post by domogijs »
Because a doorbell works with an electronic magnet I taped a window sensor on it. It works like a charm. When doorbell is pressed I get activity in Domoticz. So I made a script to send me a notification when doorbell is pressed.
Problem is, when doorbell is pressed there are a lot on, off,on, off (like 25) readings in Domoticz. And every time the script processed. Is there an way to process this script only on time in like 5 sec?
Greets Gijs
Raspberry Pi3, RFlink, PiZigate, Yeelight, klikaanklikuit, Kodi, harmony hub, Zwave, ThermoSmart, XiaomiGateway (Aqara), Google home hub, roomba,
dannybloe
Re: Doorbell in Domoticz with window sensor
Post by dannybloe »
Look into the historical persisten data support in dzVents. You can use that.
domogijs
Post by domogijs »
Ok thanks will do, right now I can't see my gateway anymore so I have to fix that first.
domogijs
Post by domogijs »
Ok this is my code right now but is doesn't work. Some thing is wrong with the aftersec command. If I understand the wiki right you can use it in combination with the counter command.
            devices = {  'Switch B' }
        data = {
            counter = { initial = 0 }
        execute = function(domoticz, devices)
            if (domoticz.data.counter == 5) then
                domoticz.notify('doorbell')
                domoticz.data.counter = domoticz.data.counter + 1
                domoticz.data.counter = 0 .afterSec(20)-- reset the counter after 20 sec
    [Code]
dannybloe
Post by dannybloe »
This part is not correct:
You can only use afterSec with device(updates). Data changes are always immediate as there is no scheduling system for this in place.
I think you should take a different approach here. What you can do is only notify if the lastUpdate of the switch is more than x seconds ago:
        execute = function(domoticz, switch)
		if (switch.active and switch.lastUpdate.secondsAgo > 10) then
Of course you won't be notified if the person presses the doorbell again within 10s. But that's not a problem I guess.
domogijs
Post by domogijs »
This is exactly what I need!
Thanks! Keep up the good work with dzvents. I will try to develop with less help :)
Greets Gijs
