im a newcomer in the domoticz world, and i learn everyday to use it.
Actually domoticz wake up my computer everyday at a time i ve programmed before.
This week i want to create a scene/ usually when i wake up it s with my alarm clock on my android phone.
I m trying to find a way to make my scene start at the time i ve set on my alarm clock(alarm is "on"--->my computer is turning on, my lamp is turning on...).
i know its possible with autoalarm--->tasker ---> raspberrypi--->domoticz
But the matter is i dont know how to do, i dont find any tutorial that can explain in details all the procedure.
is someone is using tasker like that, or is there another way to use the default alarm clock on android with domoticz?
thx
set alarm clock android and send to domotics with tasker
peterbos
Re: set alarm clock android and send to domotics with tasker
Hi chirac,
It's quite a long time ago you posted this. Did you find a solution? I'm looking for a way to read the next alarm time of a Android phone. My idea is to check at 5.00 in the morning what morning alarms have been set for that day and keep the heating in night mode until the first set alarm. It's not the same as the functionality you wanted.
Peter
Peter
- FireWizard
Hello peterbos,
Is https://docs.sleep.urbandroid.org/services/mqtt.html a useful application?
If it sends the correct MQTT message, you can convert it with Node RED and send it further to Domoticz.
- user4563
- Domoticz version: 2025.2
Not sure if you were aware but the Domoticz android app has Tasker integration built-in.
ODroid H4+ / Ubuntu server 24.04 LTS
Aeotec Z-Stick Gen5+
ZWave-JS-UI / Mosquitto MQTT
Domoticz for Android
Domoticz Scenes add-on in Kodi
