McMelloW
Posts: 434 Joined: Monday 20 November 2017 17:01
Domoticz version: V2024.1
Post
by McMelloW » Saturday 10 February 2018 21:37
Try to use the timer trigger according this example on the wiki page
'between aa and bb'
-- aa/bb can be a time stamp like 15:44
-- aa/bb can be sunrise/sunset
-- aa/bb can be 'xx minutes before/after sunrise/sunset'
local StrTime = '15 minutes before sunrise'
local EndTime = '15 minutes after sunset'
timer = { 'every minute between StrTime and EndTime' }
The script did not stop after 15 minutes past sunset, but kept on running every minute. Changed the line to:
timer = { 'every minute at daytime' }
It stopped running straight away.
McMelloW on Thursday 08 March 2018 16:55, edited 1 time in total.
Greetings McMelloW
McMelloW
Post
by McMelloW » Monday 12 February 2018 10:41
Just wondering, the lines
Are at the very top of the script. Is the correct place for these lines?
Greetings McMelloW
dannybloe
Posts: 1355 Joined: Friday 29 August 2014 11:26
Post
by dannybloe » Monday 12 February 2018 10:50
Your rule isn't correct at all. It should be:
timer = { 'every minute between ' .. StrTime .. ' and ' .. EndTime }
McMelloW
Post
by McMelloW » Monday 12 February 2018 15:56
dannybloe wrote: Monday 12 February 2018 10:50
Thanks for the update. I misunderstood the examples on the wiki page.
Greetings McMelloW
McMelloW
Post
by McMelloW » Tuesday 13 February 2018 12:04
From your example and the log I understood that the following should works too.
timer = { 'every minute between 15 minutes before sunrise and 15 minutes after sunset' }
Changed it to the line I showed above. It worked OK yesterday evening and today in the morning.
Again, I am surprised by the simplicity of dzVents. It is so much easier to use dzVents for a script.
Greetings McMelloW
dannybloe
Post
by dannybloe » Tuesday 13 February 2018 12:09
Great!
What you did was put the name of a variable INSIDE the string (all between the quotes) so Lua doesn't know that it is a variable:
So with this code dzVents just gets a string with literally 'StrTime' as piece of the rule and not your intended value.
Notice the concatenation of the string 'every minute between' and the VALUE of StrTime.
McMelloW
Post
by McMelloW » Tuesday 13 February 2018 12:22
Exactly, that is what I learned from your changed string. I did not realize dzVents is designed to recognize a string like
Well done!
Greetings McMelloW
