HTTPRespons and json
Maxx
Post by Maxx »
Hello All,
I am experimenting with HTTPResponse and json and I have a question about accessing the data in a json table.
This is the call I do:
			url = 'http://192.168.1.231:8080/json.htm?type=devices&rid=230E',
				method = 'GET',
				callback = 'trigger', -- see httpResponses above.
then I access the json with:
	if (item.isHTTPResponse) then
			if (item.statusCode == 200) then
				if (item.isJSON) then
					local someValue = item.json.Sunrise
This gives me the Sunrise time perfectly and I can put in a dummy text device.
Now the question:
If the json looks like:
"Sunrise" : "08:15",
   "Sunset" : "17:34",
   "result" : [
         "AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "BatteryLevel" : 100,
         "CustomImage" : 0,
         "Data" : "17.5 C, 55 %",
How do I get the variable "Data" in the dummy text device?
I have tried all kinds of combinations:
local someValue = item.json.result.Data  - Doesn't work returns "nil"
local someValue = item.json.result:Data  - Doesn't work returns "nil"
local someValue = item.json.["result.Data"]  - Doesn't work returns "nil"
I hope someone can help me
Marci
Domoticz version: 3.8153
Re: HTTPRespons and json
Post by Marci »
local someValue = item.json.result[0]['Data'];
Result is an array containing an object. As it's the only object in the array, it sits at the first index, and a JavaScript array's first index position is 0.
Extended Domoticz homebridge-plugin for latest Homebridge - adds temp/humidity/pressure sensors, power consumption sensors, DarkSkies virtual weather station support, YouLess Meter support, general % usage support & switch/lamp status checking!
Maxx
Post by Maxx »
Thank you for your quick response, I've tried this but it gives me the following error:
 2018-02-04 12:55:01.218 dzVents: Error (2.4.1): An error occured when calling event handler http test
2018-02-04 12:55:01.218 dzVents: Error (2.4.1): ...domoticz/scripts/dzVents/generated_scripts/http test.lua:25: attempt to index field 'result' (a nil value)
2018-02-04 12:55:01.218 dzVents: Info: ------ Finished http test
Marci
Post by Marci »
Sorry, my fault. LUA not JavaScript. In LUA array first index is 1 not 0. Change result[0] to result [1]
Maxx
Post by Maxx »
perfect, it works.
dannybloe
Post by dannybloe »
My question is though: why have this script in the first place? I'd say that dzVents already gives you all this data. No need to get it from Domoticz from the outside-in. Or is there something missing in dzVents?
Maxx
Post by Maxx »
Hello Danny,
It was just a test to see how it works, the next step for me is to do a json call to Hue to directly to check the status of the lights. (see my other message). The domoticz status is not updated when the light is offline.
thanks
elmortero
Domoticz version: 3.9639
Post by elmortero »
dannybloe wrote: Thursday 08 February 2018 7:52 My question is though: why have this script in the first place? I'd say that dzVents already gives you all this data. No need to get it from Domoticz from the outside-in. Or is there something missing in dzVents?
Well, now that you mention it:
Maybe I am overlooking something, but is it possible to query the domoticz settings (in particular longitude and latitude)?
dannybloe
Post by dannybloe »
Of course but you have to make sure that 127.0.0.1 (or whatever url you use) is listed to access the API without a password (settings of Domoticz).
