Who can help me I am just a beginner in programming in dzVents
I try to switch on two groups if they are not switched in yet with an extra switch.
Added some log rules to show if the script passes these phrases but there is nothing in the logging and the lamps are not switched on.
See code and logging below.
Thanks in advance for any help.
Marc
devices = { 'Laat-Thuis' }
execute = function(domoticz, switch)
if (switch.state == 'On' and (domoticz.groups('Binnen-Lampen') == 'Off' or domoticz.groups('Buiten-Lampen') == 'Off' )) then
domoticz.log('Welkom Thuis')
domoticz.groups('Binnen-Lampen').switchOn().forSec('60')
domoticz.groups('Buiten-Lampen').switchOn().forSec('60')
domoticz.devices('Laat-Thuis').switchOff().afterSec('10')
elseif (switch.state == 'On' and (domoticz.groups('Binnen-Lampen') == 'On' or domoticz.groups('Buiten-Lampen') == 'On' )) then
domoticz.log('Lampen zijn aan')
2018-02-09 09:44:57.082 (RFXCOM) Lighting 2 (Laat-Thuis)
2018-02-09 09:44:57.208 dzVents: Info: Handling events for: "Laat-Thuis", value: "Off"
2018-02-09 09:44:57.208 dzVents: Info: ------ Start internal script: LaatThuis: Device: "Laat-Thuis (RFXCOM)", Index: 28
2018-02-09 09:44:57.208 dzVents: Info: ------ Finished LaatThuis
2018-02-09 09:45:01.583 User: Admin initiated a switch command (28/Laat-Thuis/On)
2018-02-09 09:45:01.973 (RFXCOM) Lighting 2 (Laat-Thuis)
2018-02-09 09:45:02.161 dzVents: Info: Handling events for: "Laat-Thuis", value: "On"
2018-02-09 09:45:02.161 dzVents: Info: ------ Start internal script: LaatThuis: Device: "Laat-Thuis (RFXCOM)", Index: 28
2018-02-09 09:45:02.161 dzVents: Info: ------ Finished LaatThuis
dzVents if and elseif not working.
- waaren
Re: dVents if and elseif not working.
Try to change (domoticz.groups('Binnen-Lampen') == 'On' to (domoticz.groups('Binnen-Lampen').state == 'On'
and
domoticz.groups('Buiten-Lampen') == 'On' to domoticz.groups('Buiten-Lampen').state == 'On'
and see what happens..
and
straatm
- Domoticz version: Stable
waaren wrote: Friday 09 February 2018 10:12 Try to change (domoticz.groups('Binnen-Lampen') == 'On' to (domoticz.groups('Binnen-Lampen').state == 'On'
and
Thanks that solved the problem!
