Generic Wake Up script
Brighthead
Post by Brighthead »
after searching this forum and not finding any Wake Up script to suit my need I decided to write my own.
The script is a generic script that can support an unlimited number of Wake Up sequences. Configuration is done by creating devices, groups and user variables.
I named the Dzvents script "Wake Up" but it can be called anything. However, the devices, groups and user variables needs to follow a naming convention as follows: (<sequence> is a unique name for the specific Wake Up sequence)
Trigger device: "Wake Up <sequence>" Virtual device used to trigger the Wake Up sequence
Enabling device: "Wake Up <sequence>_Enabled" Virtual device that enables or disables the Wake Up sequence
Device group: "Wake Up <sequence>_Devices" Group that contains all the devices to be woken up by the sequence
User variable: "Wake Up <sequence>" Integer user variable used by the sequence
In addition you need to create a variable to hold the duration of wake up sequences. All sequences has the same duration.
This integer user variable needs to be named "Wake Up_Duration".
And finally, here's the script.
-- Generic Wake Up script for domoticz
-- Set up:
--  Create the following entities in Domoticz:
--  1. A user variable named "Wake Up_Duration" of type Integer containing the number of minutes in a Wake Up sequence. The duration is the same for all sequences.
--  2. A Virtual Device to be used as the trigger for Wake Up
--  3. A Virtual Device to enable/disable Wake Up named <trigger device> + the suffix "_Enabled".
--  4. A group named <trigger device> + the suffix "_Devices". The group should contain all devices to be woken up.
--  5. A user variable named <trigger device>.
--  Example: If the trigger device is called "Wake Up Bedroom" then the control device needs to be named
--           "Wake Up Bedroom_Enabled" and the device group should be named "Wake Up Bedroom_Devices".
-- Usage: Use a timer setting the trigger device to ON when the Wake Up sequence should begin
--        To stop an active Wake Up sequence, set the control device to OFF
--        To reset a stopped Wake Up sequence, set the trigger device to OFF
		devices = {
			'Wake Up *'
	logging = {
        level = domoticz.LOG_INFO,
        marker = 'Wake Up: '
	execute = function(dz, d)
	    local duration = dz.variables('Wake Up_Duration').value -- Set Duration of Wake Up sequence
	    local enabled = d.name .. '_Enabled'                    -- Control device (Wake up enabled if this is ON)
	    local devicegroup = d.name .. '_Devices'                -- Device group
	    local initvalue = 100 % duration                        -- Start value for sequence
	    local stepvalue = (100 - initvalue) / duration          -- Increment per wake up step
	    local level = 0                                         -- Work variable, current level
        -- If the changed device is a control device we just ignore the event
        if (string.sub(d.name,-8) == "_Enabled") then
            return
        -- Make sure wakeuplevel is set
        if dz.variables(d.name).value == nil then
            dz.variables(d.name).set(0)
        -- Is the trigger device turned ON?
	    if (d.state == 'On') then
            d.switchOff().silent()
            -- Is the control device turned ON?
    		if (dz.devices(enabled).state == 'On') then
    		    -- Are we still in the wake up loop?
    	        if (dz.variables(d.name).value < duration) then
    		        level = dz.variables(d.name).value + 1
    		        dz.variables(d.name).set(level)
    		        local dimlevel = initvalue + (stepvalue * level)
    		        dz.log('Set dimlevel for ' .. d.name .. ' to ' .. dimlevel .. '%')
    		        dz.groups(devicegroup).devices().forEach(function(sd)
                        dz.log(sd.name .. ' dimmed to ' .. dimlevel .. '%')
    		            sd.dimTo(dimlevel)
    		        end)
    		        -- Schedule next step in Wake Up sequence
    		        d.switchOn().afterMin(1)
        		-- Wake Up loop completed
                    dz.log(d.name .. ' completed!')
    	    -- Control device is OFF
                dz.log(d.name .. ' is not enabled')
        -- The trigger device was turned off so reset everything
            dz.log(d.name .. ' turned off')
            dz.groups(devicegroup).switchOff()
