Domoticz App
Re: Domoticz App
Can anybody help me
I m just fresh in the Domoticz story
Install the server on my synology
runs perfect
IP are 192.168.0.116
Https port 8443
http port 8084
I set up a user an password on my server
both work perfect in the browser
Now I like to use the app on my Iphone with are in my home network.
But what ever I add it can not find the server. Not with 8443 or 8084.
What should be in the directory ?
Can anybody help me
runs perfect
Https port 8443
http port 8084
Re: Domoticz App
Hi get now at least inside local network a connection.
Server setting
result = ok
But than ?
No button to save or next slide . I can only go back.
How should I go now ?
Harald
Server setting
result = ok
But than ?
Harald
- galadril
- Domoticz version: latest
Re: Domoticz App
The directory is for exapmle:
"http://192.168.1.25:8080/domoticz/#/Dashboard"
if this is you rdashboard url, then domoticz is your directory..
- galadril
Re: Domoticz App
Do you get that result on https?? (with self signed certificate...?)
Re: Domoticz App
Hi! For me over WiFi is not possible interact with home. Only if I disconnected wifi.
Re: Domoticz App
Thanks for answer I move to a other plattform.
Harald
Harald
- galadril
Re: Domoticz App
Just to let you know. -> There's a new beta coming one of these days..
- Spoiler: show
- Domoticz version: 4.10915
Re: Domoticz App
I'm new to Domoticz
I run a system on an Raspi3-B with Raspian stretch lite and Razberry z-wave+ device. Switches and door sensors NeoCoolcam
(all latest update/upgrade)
on my Iphone i use the Domoticz app and Prowl for push notification (no problem)
Domoticz works fine except for the Domoticz app
it works oké but the switches and sensors don't toggle right if a sensor switches on. When a switch or sensor is activated by Domoticz the switches keep white instead of green.
in the log it's oké
if i use the switches on the Iphone they do toggle right and very fast
everytime i restart the app it's shows the proper situation
the app shows a good server connection
is this a known issue? hope someone can give me a hint
I'm new to Domoticz
in the log it's oké
- Target OS: OS X
Re: Domoticz App
Hi, I am having a similar issue with the app. It worked well until Xmas, but I updated and now on the server setting I can only input either the external/DNS url OR the local IP/port I have my domoticz. If I add both (with the button "use different address for local connection"), it does not work
Any idea why? Is anyone else experiencing the same?
Re: Domoticz App
Mine works only if I use username and password in domoticz..
Inviato dal mio iPad utilizzando Tapatalk
Re: Domoticz App
I created a virtual switch in Domoticz.
When i push this switch on my Iphone everything will refresh correctly
It's a temporarily solution, but it works
Re: Domoticz App
Hey
what a super system and a super app ...
I do have a question about the notifications. if I send a test notification I will receive it .. but otherwise how is this possible?
greeting martijn
greeting martijn
Re: Domoticz App
I bought it for notification but I don't have any sounds on notifications.
Any idea about that ?
Thanks.
Thanks.
- galadril
Re: Domoticz App
it shoud use the sound settings that all notifications use
- galadril
Re: Domoticz App
Whats the issue?marcotrumpet wrote: ↑Monday 08 January 2018 12:59 Mine works only if I use username and password in domoticz..
Can I test against your system?
- galadril
Re: Domoticz App
New feature in next version is:
Use a different language then the default phone language..
I added that settings on the settings page
Re: Domoticz App
I don’t know why but if I use my domoticz system without username and passeord the app give me a connection error (it work for a minute or so and then the error appear) but I found out that if I set user and passwd I can use the app without problem at all.galadril wrote:Whats the issue?marcotrumpet wrote: ↑Monday 08 January 2018 12:59 Mine works only if I use username and password in domoticz..
Inviato dal mio iPhone utilizzando Tapatalk
Re: Domoticz App
I am sorry to ask the basic question, I have seen other have the same issues so maybe resolved but not answered here.
Can you please indicate what needs to be added to the "Server settings" page, I have a plain setup without password and I try to access from same network but I get the "Error: not connected to network"?
In a browser I connect with https://192.168.1.177/#/Dashboard
Domoticz on Rpi, Z-wave, Hue with Philips and Ikea bulbs
Re: Domoticz App
I actually got it up and connected now, I see everything that I see in the web interface but here comes a strange thing... I cant use the buttons, meaning I can see the switches and they go to "green" but they don't turn the devices on or off?djac wrote: ↑Friday 02 February 2018 14:04 I am sorry to ask the basic question, I have seen other have the same issues so maybe resolved but not answered here.
- galadril
Re: Domoticz App
Does you account that you use to login have enough rights to flip the switches?
is it an admin account on domoticz?
