how to control relay board USB
DosN
Post by DosN »
Im a newbe, and im searching how to switch a relay PCB with USB
https://www.sossolutions.nl/2xusbrelais ... hvEALw_wcB
which hardware- and switch setting must be make to control it?
switch USB.jpg (41.13 KiB) Viewed 3758 times
SweetPants
Re: how to control relay board USB
Post by SweetPants »
Without a proper manual or documentation of this board, that will be very difficult.
Marci
Domoticz version: 3.8153
Post by Marci »
See https://github.com/darrylb123/usbrelay/ ... /README.md
Create individual bash scripts to turn each relay on and off. Set the relevant bash scripts as on / off actions on whichever dummy switch you want to use to control whichever relay.
Extended Domoticz homebridge-plugin for latest Homebridge - adds temp/humidity/pressure sensors, power consumption sensors, DarkSkies virtual weather station support, YouLess Meter support, general % usage support & switch/lamp status checking!
DosN
Post by DosN »
First thanks for responce
But is there not a standard hardware type , which i can select?
How can i add this code in domoticz?
SweetPants
There is no standard hardware type to my understanding that supports this relay. You can write some bash scripts and add them to a dummy switch On/Off action or if you know how to do it write your own python plugin for domoticz?
DosN
Post by DosN »
is there a python code or how can i add a C code in domoticz
cyberclwn
Domoticz version: 2024.4
Post by cyberclwn »
Hey,
Why not use this one instead:
https://www.sossolutions.nl/2x-relais
You can easily connect the pins to the Raspberry Pi and then use the GPIO in Domoticz to control it.
Don't know why to complicate things using USB :)
I have this one and it works like a charm.
3xPi 2B (Domoticz "live", Domoticz "sandbox", PhotoFrame)
RFXCom433(E), KaKu, Oregon Scientific, Keyes 2-relay, Logitech Media Server, MiLight, Smartwares heating controller(2x), IR Send/Receive, Keyes PIR, XH-M131 DuskSensor, DHT22/11
bbqkees
Domoticz version: 4.1x
Post by bbqkees »
DosN wrote: Saturday 03 February 2018 21:20 Im a newbe, and im searching how to switch a relay PCB with USB
If it is the same type of relay as what I once had you can use my method which does not need any bash scripts.
https://github.com/bbqkees/Domoticz-Pi- ... -solutions
DosN
Post by DosN »
Hi bbqkees
Wooh , that looks good. Thanks i will try that
greetz
