How to connect OTGW between Remeha Tzerra and eTwist thermostat
For OpenTherm-gateway related questions in Domoticz
Ritmeester
Post by Ritmeester »
I have a question on how to connect the OTGW between the Remeha Tzerra and eTwist thermostat.
I have this equipment:
Remeha Tzerra Plus
Remeha Tzerra 1 - 800.jpg (117.37 KiB) Viewed 4859 times
and some box on the wall between the eTwist and the Tzerra
Remeha Tzerra 2 - 800.jpg (159.86 KiB) Viewed 4858 times
So, how to connect this OTGW PCB?
titanl
Re: How to connect OTGW between Remeha Tzerra and eTwist thermostat
Post by titanl »
I have the same setup here ( only waiting for the optocouplers).
As far as I read here viewtopic.php?f=38&t=15099 It should be inbetween the gateway and the boiler, as this is OT protocol.
I am wondering if you can override the room setpoint ( sow I finally can get geofencing working on the etwist)
Ritmeester
Thanks for your reply. But must I connect the OTGW PCB in “series” or in “parallel” ?
titanl
Post by titanl »
Thermostat<---Rbus--->Gateway<---OT-->OTGW-Thermostat<----OT---->Boiler
is must be in serie...
