- htilburgs
I loaded your CONFIG.js and took it appart. So first the config -> working, then config with var calendars{} -> working, and so on, until you got to the part where it's not Ok anymore. Than take a look at that part and find the error. (Took me for about 5 minutes...)
Hardware:
thx that worked.. funny thats isnt default when you outqoute the */
another thing. My blocks will not show up, when i connect outside my local network. Is that a known thing?
- Domoticz version: 3.9224
Default Dashboard Code
I have just started playing around with Dashticz and only now realised that initially the CONFIG.js file is entirely commented out.
Even though that was commented out, Dashticz still produced a dashboard showing the switches, etc that I have on the default Domoticz dashboard as well as weather forecast (I configured items through the settings cog at the top right). I was wondering if there is a file somewhere that this is being configured from. Ideally I would like to use it as the template and modify from there. When I did remove the comments from the CONFIG.js file the Dashticz dashboard obviously completely changed.
Re: Default Dashboard Code
Okay, I have looked at a few examples and gotten a Dashboard going using the uncommented CONFIG.JS
I also discovered that the 'use favourites' does not do what I thought. I didn't realise it would restrict what I can have on the dashboard to only what is in my favourites list.
Been a steep learning curve but I'm getting there
- htilburgs
You’re outside your network and your config.js points to you’re internal IP address. That’s why.
Use custom_2 to make an external view in combination with index2.html. Is it wise to publish to rhe outside? I don’t think so.
Hardware:
- Domoticz version: 2021.1
Re: Dashticz - Defined Buttons for screen navigation
I have scanned the forum for a way to create a button to navigate to different defined screens, but didn't find any solutions.
I want to create various buttons on screen 1, that when pressed would go to a specific defined screen number. These buttons would be labeled as to the content of given screen and allow the user not have to use the bottom slider to advance to each screen separately.
thanks
thanks
- DewGew
- Domoticz version: V4.10618
You can use:tlkg wrote: ↑Tuesday 30 January 2018 0:07 I have scanned the forum for a way to create a button to navigate to different defined screens, but didn't find any solutions.
thanks
buttons.screen2 = {width:12, icon:'fa-chevron-right', title: 'Page 2', slide:2};
buttons.screen3 = {width:12, icon:'fa-chevron-right', title: 'Page 3', slide:3};
columns[3] = {};
columns[3]['blocks'] = [ buttons.screen2];
columns[6] = {};
columns[6]['blocks'] = [ buttons.screen3];
Wow, works perfect !! Thanks!!
Hi Everyone,
I have been busy with domoticz for some time and wanted to expand this with dashticz.
Reason: to place a tablet on the wall for extra functions.
Now I have installed dashticz following the wiki page: https://www.domoticz.com/wiki/Dashticz_ ... stallation
I used the following command to install it:
git clone https://github.com/robgeerts/dashticz_v2 dashticz
Then everything followed neatly as on the wiki page are also neatly removed the / * at the beginning and * / at the end + ipaddress of my domoticz inserted. Only I do not get a connection with domoticz, if I want to adjust on the page of dashricz and I choose to save, nothing is stored.
Hopefully someone can help me in the right direction.
Below the complete file: CONFIG.js
- Spoiler: show
- DewGew
Garbage module is changed read in garbage thread here in forum. Delete:marcel19 wrote: ↑Thursday 01 February 2018 7:29 Hi Everyone,
- Spoiler: show
var trashnames = {}
trashnames['Gft'] = 'GFT';
trashnames['Pmd'] = 'Plastic';
trashnames['Rest'] = ''; //LEAVE EMPTY IF YOU WANT TO HIDE IT
DewGew wrote: ↑Thursday 01 February 2018 8:28Garbage module is changed read in garbage thread here in forum. Delete:marcel19 wrote: ↑Thursday 01 February 2018 7:29 Hi Everyone,
- Spoiler: show
Now you can connect to dashticz.Code: Select all
var trashnames = {} trashnames['Gft'] = 'GFT'; trashnames['Pmd'] = 'Plastic'; trashnames['Rest'] = ''; //LEAVE EMPTY IF YOU WANT TO HIDE IT
Like i said i can connect to dashticz, everything is working. but when i make a change in the dashticz dashboard like changing the refresh time from dashticz from 60 to 1. when i hit apply and refresh the page. everything is reset to 60 minuts.
- DewGew
You mean to use the setting popup?.. you need to have PHP enabled webserver to save to CONFIG.js or if you want save settings to local storage in your browser your CONFIG.js can look like this or comment out everything in your config.js:marcel19 wrote: ↑Thursday 01 February 2018 9:48DewGew wrote: ↑Thursday 01 February 2018 8:28Garbage module is changed read in garbage thread here in forum. Delete:marcel19 wrote: ↑Thursday 01 February 2018 7:29 Hi Everyone,
- Spoiler: show
var config = {}
config['domoticz_ip'] = 'http://192.168.1.3:8084';
DewGew wrote: ↑Thursday 01 February 2018 10:13You mean to use the setting popup?.. you need to have PHP enabled webserver to save to CONFIG.js or if you want save settings to local storage in your browser your CONFIG.js can look like this or comment out everything in your config.js:marcel19 wrote: ↑Thursday 01 February 2018 9:48DewGew wrote: ↑Thursday 01 February 2018 8:28
Garbage module is changed read in garbage thread here in forum. Delete:Now you can connect to dashticz.Code: Select all
Like i said i can connect to dashticz, everything is working. but when i make a change in the dashticz dashboard like changing the refresh time from dashticz from 60 to 1. when i hit apply and refresh the page. everything is reset to 60 minuts.Else you have to put everything by your self in your CONFIG.js.Code: Select all
/* var config = {} config['domoticz_ip'] = 'http://192.168.1.3:8084'; config['app_title'] = 'Dashticz'; config['domoticz_refresh'] = '5'; config['dashticz_refresh'] = '60'; */
Ok perfect so now i understand. i dont mind to edit the CONFIG.js file at all. i diddent know that the CONFIG.js overwrites the gui interface.
So i understand that when i want to edit it trough the GUI i need to set /* on the top and */ at the end of the CONFIG.js file.
When i do that all my favorites are available trough dashticz, but when i go to edit mode, and try to save the button is the right-bottom corner is not working. (and yes i have php installed)
- DewGew
Edit mode for blocks is not yet finished its under development.
- Domoticz version: 4.10778
Domoticz Beta 8823
Platform RPI3
Dashticz_V2 Beta
Hi ,
I have installed the Dashticz_V2 as per the Wiki instructions using git clone
Config.Js has not been changed except remoe /* */ and update IP:Port .
When loading the dashboard , the error message "Dashboard V2 is loading ... without endind to load
Timeout! Something is wrong check your config.js ( attached below)
Any idea please ?
Thank you
Platform RPI3
Dashticz_V2 Beta
Hi ,
- Spoiler: show
Any idea please ?
Thank you
Domoticz Beta V4.11763 in Debian 10 VM
Domoticz Beta V4.11763 in RPI3
MDAH 0.2.42 + Imperihome Pro V4.3.17
App Android Domoticz Lite V0.2.201
gerardosamara wrote: ↑Thursday 01 February 2018 17:47 Domoticz Beta 8823
Platform RPI3
Dashticz_V2 Beta
Hi ,
- Spoiler: show
Any idea please ?
Thank you
If you are using a username and password to login to your domoticz you need to add this to your config like this:
config['domoticz_ip'] = 'http://USERNAME:[email protected]:8080';
Replace ADMIN:PASSWORD with you own.
Thank you @marcel19 for your answer.
I am not using USER&PASSWORD protection to login in Domoticz.
Gerard
Gerard
another solution: this one took me a time to figure out.gerardosamara wrote: ↑Thursday 01 February 2018 21:34 Thank you @marcel19 for your answer.
Gerard
when you go to the adress: http://192.168.0.150:8080/Dashticz_V2/
the last / at the end of the adress is needed to display dashticz at all.
Same issue when trying to login "http://192.168.0.150:8080/dashticz_v2/ "
Here the install created directoty name as dashticz_v2 instead of Dashticz_V2
