Events at startup
candrea77
Domoticz version: 2021.1
Events at startup
Post by candrea77 »
Dear forum users,
I wonder if using dzVents we are able to trigger a script in order to get it run only 1 time at startup.
Thank you for your attention
Inviato dal mio SM-G920F utilizzando Tapatalk
Sorry for any spelling mistake, English is not my native language.
DomoticZ running on Ubuntu 20.04 LTS , dzVents Version: 3.1.7 , Python Version: 3.8.5
SweetPants
Re: Events at startup
Post by SweetPants »
What are you trying to achieve?
dannybloe
Post by dannybloe »
You can. You can use a timer script and a condition that checks the domoticz.startTime. Only run when startTime is less than two minutes ago.
dannybloe
Post by dannybloe »
In the future I want to support system events.
candrea77
Post by candrea77 »
Mmmm ... what is this "domoticz.startTime" ..... I'm using stable version ... is present here ?
dannybloe
Post by dannybloe »
No. You need the beta.
candrea77
Post by candrea77 »
dannybloe wrote:No. You need the beta.
Ok. Thank you
salvacalatayud
Post by salvacalatayud »
This can be great, with this you can set milght to switch off after start up, as they turn on after plugged and this happens in case of a cut of electricity.
I have no idea of dzvents, if someone can give a light on code would be useful.
Enviado desde mi Redmi 4X mediante Tapatalk
Please have a look at the script below. Maybe not the optimal solution but it does the job as expected.
	active when function returns true ( domoticz started less then 180 seconds ago )
	The defined tasks will only execute once after domoticz started.
	Please note that this is not a failsafe way of handling this.
	If domoticz crashes / is stopped after the first excution of this script and before 120 seconds after
	it started, the Executed value is not set back to 0 and the script needs to be reloaded to reset the persisitent data.
	If domoticz starts extremely slow, in theory it could be that this script will not be evaluated before the 180 seconds
	after startup has passed. On my test system (PI-3), first execution is well within that window. (somewhere between 13 and 60 seconds)
	active = function(domoticz)
			  return domoticz.startTime.secondsAgo < 180
			end,
    on 		= {  	timer 		= { 'every minute'  } },
	data 	= { 	Executed 	= { initial = 0 } },
    execute = function(domoticz)
		if domoticz.data.Executed == 0 then
			domoticz.data.Executed = domoticz.startTime.secondsAgo
			local minute=60
			local hour=60*minute
			local day=24*hour
			local seconds = domoticz.systemUptime
			local days = math.floor(seconds/day)
			seconds = seconds - days * day
			local hours = math.floor(seconds/hour)
			seconds = seconds - hours * hour
			local minutes = math.floor( seconds/minute )
			seconds = seconds - minutes * minute
			-- [DEFINE YOUR TASKS HERE]
			print ("System active time: " .. tostring (days) .. " days, " .. tostring(hours) .. " hours and " .. tostring(minutes) .. " minutes." )
			print ("Domoticz started " .. tostring (domoticz.startTime.secondsAgo) .. " seconds ago. I will do the startup tasks")
			print ("Älready executed; " .. tostring(domoticz.data.Executed) .. " seconds after domoticz started.")
			if domoticz.startTime.secondsAgo > 119 then
				domoticz.data.Executed = 0
dannybloe
Post by dannybloe »
I'm planning to have system events for a future version of dzVents like
    system = {'start', 'error'}
salvacalatayud
waaren wrote: Thursday 01 February 2018 3:40 Please have a look at the script below. Maybe not the optimal solution but it does the job as expected.
			end,
			local minute=60
			local day=24*hour
Thanks a lot, I'll try as soon as I can
doh
Post by doh »
dannybloe wrote: Thursday 01 February 2018 8:03 I'm planning to have system events for a future version of dzVents like
Has this been implemented yet? Would really love to use it.
rrozema
Post by rrozema »
Can you also add triggers for device's meta data changes? I use the description field to put a json text in containing many settings for this particular device, so I can write one generic script that works for all devices that have a specific value (or values) in their description field. As it is now I need to periodically execute the scripts and scan all devices on every run. I would like to be able to read all meta data once at startup to collect in variables those devices that have specific values. This way I only need to scan those devices when the generic script runs, instead of scanning all devices every time. I can already do most of this now, however when a device's description gets changed, my variables will not be updated and the device will no longer react according to the values in it's description field.
I would very much welcome a trigger for when a device's meta data changes. In other words: a "device meta data trigger" would be called when any property changes that not currently triggers the existing "device value" trigger.
Geitje
Post by Geitje »
Would be great if in the event system can be added a standard value for running time of Domoticz. This way we can let run an event if domoticz is running for 12 hours, for example make a backup (just to give an example).
I need it myself to cancel an event which for some reason is running everytime Domoticz starts up.
Zwave, Zigate, RFlink etc.
