Get temperature
welby
Get temperature
Post by welby »
I currently have a working script that sends an email to my wife if the temp goes over a certain value and runs every hour. It works fine but i'd like to include the actual temp in the email if possible? This is my current code for testing it but it's not working, i'm sure someone will know where i've gone wrong.
		timer = { 'every minute between 12:00 and 22:00'
	execute = function(domoticz, )
		if (domoticz.devices ('Temperature').temperature > 20) then
		    domoticz.email('Hi Prue you may turn the Aircon on because the temp is:' .. 'Temperature'.temperature '',  '*****@gmail.com')
SweetPants
Re: Get temperature
Post by SweetPants »
Google is your friend, search for LUA string concatenation https://www.lua.org/pil/3.4.html
Re: Get temperature
welby wrote: Wednesday 31 January 2018 7:51 I currently have a working script that sends an email to my wife if the temp goes over a certain value and runs every hour. It works fine but i'd like to include the actual temp in the email if possible? This is my current code for testing it but it's not working, i'm sure someone will know where i've gone wrong.
There are some other minor syntax errors in your example please find corrected below
Email test
	execute = function(domoticz)
		local myTemp = domoticz.devices ('Kantoor').temperature
		if myTemp  < 20 then
			print ("Sending mail")
		    domoticz.email("Temperature alert for Prue", "Hi Prue you may turn the Aircon on because the temp is: " .. tostring(myTemp),  "[email protected]")
welby
Re: Get temperature
Post by welby »
Awesome waaren it works great thanks alot ;) I've got alot to learn and this has helped me heaps.
