Controlicz - Domoticz to Google Home/Assistant integration Topic is solved
I'm using Fahrenheit for temperature. Up to a week ago I was able to set Thermostat to 72F . Now I get an error when I try to control pass 30F. But works fine setting Thermostat to 25 Celsius.
dlite
first of all, great development.. just donated..
When I ask about the status of any Hue light, I will always get that they are 'On' even if they are not.
Is there something I can do to fix it?
little tip on thermostat use and the 'Off' annoyance:
my setup with custom thermostat:
- temperature sensor with name 'temperature it'
- setPoint device for setting the thermostat with name 'thermostat it'
Google Home will say '20.5 degrees and the temperature it is off' followed by '21 degrees and the thermostat it is off' making it a little bit more logic than it was..
setting temp is as easy as saying 'set thermostat to 22', Google will see both devices as a thermostat so will respond with 'setting 2 thermostats to 22 degrees'..
Madgeni
Thank you for the donation - it really helps
Ok, the hue thing is odd - are they marked as Off in your Domoticz?
dlite
yep they are Off. Even told Google Home to turn them off seperatly to see if that helped.Ok, the hue thing is odd - are they marked as Off in your Domoticz?
Madgeni
ok, will take a look -
*update* - seems ok - can you pm your email address, and i'll see whats happening
superustas
Madgeni, Hi!
Thanks for a GREAT job!
Can you add me to your Beta program to access to GH ?
Thanks,
Alexey
I'm already registered on your site
It works with my Alexa, but does not work with Google yet
Thanks,
Alexey
Madgeni
Hi - if you go to your Profile on Controlicz - there's a button to request access to GH
superustas
Madgeni, button pressed;)
Madgeni
and email sent
superustas
Madgeni, i need your help:
"response": "Sorry, this action is not available in simulation",
"visualResponse": {
"visualElements": []
Madgeni
ok - once enabled in the simulation - move over to your Google Home/Google Assistant app, then under Settings>Home Control - you should see Home Controlicz - you can enable it, provide your controlicz email/pwd - and you should be done. Then you use it via voice (or in GA, text) with your Google Home device
superustas
Madgeni, thanks!!! It works!
Madgeni
yay \0/
- bueno79
- Domoticz version: 4.9700
hi,
still so happy with this service. Best service from GH. I just see this :
https://github.com/actions-on-google/ac ... /issues/75
issue is fix...does it means we can control selector now (and not only a washer. small/large ) ?
best regards,
Bueno
best regards,
Bueno
Madgeni
hah - i saw that too. I doubt very much they've allowed *any* levels to be passed through if we use 'Control' as the mode. I'll check later
- bueno79
OK...we will see. I hope you will not have to reopen this case and we will be able to use selector. It could be a HUGE improvement for this project.Madgeni wrote: Monday 29 January 2018 16:04 hah - i saw that too. I doubt very much they've allowed *any* levels to be passed through if we use 'Control' as the mode. I'll check later
regarding the validation by Google ? Still no news ? Nothing we can do ?
Madgeni
I've pushed *again* - it may fail again, but it's much closer, i think i've got passed all the thermostat issues (Google acknowledge the 'is off' is a bug for sensors) - i've had good tests with Hue lights, but they may still fail it on the Dim level - it seems that Domoticz (I don't *think* it's me - but it could be!) is miscalculating the 'Dim the light by 20%' command, and dimming by 19% for example. The more I think about it, the more likely it's me - In order to do this, I have to retrieve current state, then do maths - simple maths. It works for me, but as we know, Domoticz is different for everyone!
- bueno79
@madgeni
deleted
deleted
- bueno79
FIX, forget. I ve disociate service in google home app and re associate...all good.bueno79 wrote: Monday 29 January 2018 20:47 @madgeni
hey I done some bullshit I think...I ve play with the controlicz web site and now GH cannot control my devices...can you check on your site ?
email [email protected]
thanks
frenchyyii
Hi Magdeni, I dissociated controlicz but can't find it again to reassociate. Is there any tip to apply now ?
Eric
Edit: as I couln't connect to controlicz website with google chrome I did reset my pw and reconnected again using firefox. As it was possible then I used the "Sign up to GH". Now waiting but maybe that was the reason I could find "Controlicz (test)" or "Home Controlicz" . I hope I didn't make any mistake.
Eric
