Does someone has a working SONOFF basic in Domoticz, ?
I try to flash it , with different tools and a lot of different bin file. I think i succeed in flashing it, the software did reply FLASH COMPLETE. But i did not get a wifi signal(esp_0) after flashing.
i seached over the internet, and it looked like there is something changed in the new SONOFF types.
Could some one help ?
SONOFF flashing no wifi
- philchillbill
Re: SONOFF flashing no wifi
If you program these newer baby devices using the standalone flasher, the Sonoff will appear to flash OK but when you power it up there will be no ESP_0 wifi network. The solution to this is to make sure that the flash mode is 'DOUT' which cannot be set from the standalone flashing program. A solution I used was to deploy the ArduinoIDE where there is an option to select flash-mode. I haven't used it myself, but apparently "esptool.py write_flash -fm dout" will also work.
Alexa skills author: EvoControl, Statereport, MediaServer, LMS-lite
- Mediacj
I had the same problem and found the solution in this forum post:
http://www.letscontrolit.com/forum/view ... =10#p18240
DosN
First thx for helping
Yes i read about DOUT, so i did already try
http://www.letscontrolit.com/forum/view ... e&start=50
it was also not working, i got an error
also trying the arduino software, but ther the problem is , i get for one to another error
i also wachted youtube , there it looked easy , but it looks like im doing something wrong , or the board is different
DosN
even a simpel programm like blinking LED is not working
http://geek.adachsoft.com/home/article/ ... E/refid/mz
