[Solved] Script for turning on a charger at specific time
void
Post by void »
Edit: Solved, at the bottom of this post the working version for anyone that's interested.
I've tried to make this script which will turn on a switch (HomeEasy) at weekdays at 23:15 so the attached devices (phones, tablets, etc) can be charged with the cheaper power at night. However I keep getting this error and I must be getting blind but I can't figure out what I'm doing wrong...
Log:
2018-01-27 19:33:00.449 Error: dzVents: Error: error loading module 'ChargerStation' from file '/home/pi/domoticz/scripts/dzVents/scripts/ChargerStation.lua':
...e/pi/domoticz/scripts/dzVents/scripts/ChargerStation.lua:8: '}' expected (to close '{' at line 1) near 'execute'
Here is the script:
        active = false,
                timer = {
                        'at 23:15 on mon,tue,wed,thu,fri',
        execute = function(domoticz, timer)
                domoticz.log('Daluren stroom, ChargerStation aangezet')
                domoticz.log('The rule that triggered the event was: ' .. timer.trigger')
                domoticz.devices('Lamp_4').switchOn().forMin(240)
Can someone please point me in the right direction?
Cheers,
void
Working version:
        active = true,
                timer = {
Re: Script for turning on a charger at specific time
You need a comma between } and execute
void
Post by void »
... <voeg hier een aantal scheldwoorden in>
Ik wist wel dat het niet iets groots kon zijn, man man man... en maar haakjes tellen :D
Re: [Solved] Script for turning on a charger at specific time
To make it work (dzVents 2.4.1)
        on = { timer = {'at 23:15 on mon,tue,wed,thu,fri' }},
        -- on = { timer = {'every minute' }},
       execute = function(domoticz, device, triggerInfo)
                print ('Daluren stroom, ChargerStation aangezet')
                print ('The rule that triggered the event was: ' .. triggerInfo.trigger)
                domoticz.devices('Bedlampjes').switchOn().forMin(240)
