I'm aware there is also a plugin that makes something similar. I haven't tried it though. This is for you who wants to do it the dzVents way and have full control over whats going on. You will also be able to fetch forecasts.
This script requires dzVents 2.4
It comes with no documentation and because I will not hang around here any longer, it also comes without my support. You can use it if you like it and if you can understand how it works.
Hint: You should start with modifying the configuration script and create Domoticz devices for each sensor that you'd like to enable. Be extremely observant to create the Domoticz devices by the exact name that is in the config file, otherwise it will not work.
Sorry for not being able to give you any support. Maybe someone else like to take over the script. That would be perfectly OK with me.
Happy day!
wUnderScraperConfig.lua
Edit this file suit your needs
Place this file in the dzVents scripts folder using the name wUnderScraperConfig.lua
Using Weather API at http://api.wunderground.com/weather/api/d/docs
After editing always verify that it's valid LUA at http://codepad.org/ (Mark your paste as "Private"!!!)
local _C = {}
-- Variables you should customize are below
_C.location = 'Paris' -- City/location used for Wunderground API (You can also use a pws here like 'pws:ISTOCKHO854')
_C.countryCode = 'FR' -- Country code. See http://api.wunderground.com/weather/api/d/docs?d=resources/country-to-iso-matching
_C.wuAPIkey = 'XXXXXXXXXXX' -- Weather Underground API Key
_C.wuLang = 'EN' -- 'EN' Language for the API to return. See http://api.wunderground.com/weather/api/d/docs?d=language-support
_C.wuUseMetric = true -- Set to true for Metric. Set to false for Imperial.
-- Uncomment only those devices that you wish to use in your system
-- You need a virtual Domoticz sensor for each entry that you intent to use and
-- each device must be of the correct Domoticz device type of course.
-- You might want to create these devices on a dedicated virtual hardware device named "WU"
-- or something similar although it's not necessary to do that.
_C.domoWeatherDevices = {
['Barometer'] = {['enabled'] = true, ['sensorType'] = 'C_BARO'},
['Weather'] = {['enabled'] = true, ['sensorType'] = 'C_CONDITIONS'},
['Visibility'] = {['enabled'] = true, ['sensorType'] = 'C_VISIBILITY'},
['Solar radiation'] = {['enabled'] = true, ['sensorType'] = 'C_SOLAR_RADIATION'},
--['temp'] = {['enabled'] = true, ['sensorType'] = 'C_TEMP'},
--['hum'] = {['enabled'] = true, ['sensorType'] = 'C_HUM'},
--['temp/hum'] = {['enabled'] = true, ['sensorType'] = 'C_TEMP_HUM'},
--['temp/baro'] = {['enabled'] = true, ['sensorType'] = 'C_TEMP_BARO'},
['Temp/hum/baro'] = {['enabled'] = true, ['sensorType'] = 'C_TEMP_HUM_BARO'},
['Rain'] = {['enabled'] = true, ['sensorType'] = 'C_RAIN'},
['Wind'] = {['enabled'] = true, ['sensorType'] = 'C_WIND'},
['UV'] = {['enabled'] = true, ['sensorType'] = 'C_UV'},
-- Devices used for forecast period 1. (D+1 = 1 Day after today)
['Forecast D+1'] = {['enabled'] = true, ['sensorType'] = 'FC1_CONDITIONS'},
['Forecast D+1 temp low'] = {['enabled'] = true, ['sensorType'] = 'FC1_LOW_TEMP'},
['Forecast D+1 temp high'] = {['enabled'] = true, ['sensorType'] = 'FC1_HIGH_TEMP'},
--['Forecast D+1 avg hum'] = {['enabled'] = true, ['sensorType'] = 'FC1_HUM'},
--['Forecast D+1 rain all day'] = {['enabled'] = true, ['sensorType'] = 'FC1_QPF_ALLDAY'},
['Forecast D+1 rain day'] = {['enabled'] = true, ['sensorType'] = 'FC1_QPF_DAY'},
['Forecast D+1 rain night'] = {['enabled'] = true, ['sensorType'] = 'FC1_QPF_NIGHT'},
--['Forecast D+1 snow all day'] = {['enabled'] = true, ['sensorType'] = 'FC1_SNOW_ALLDAY'},
--['Forecast D+1 snow day'] = {['enabled'] = true, ['sensorType'] = 'FC1_SNOW_DAY'},
--['Forecast D+1 snow night'] = {['enabled'] = true, ['sensorType'] = 'FC1_SNOW_NIGHT'},
['Forecast D+1 wind'] = {['enabled'] = true, ['sensorType'] = 'FC1_WIND'},
-- Devices used for forecast period 2. (D+2 = 2 Days after today)
--['Forecast D+2'] = {['enabled'] = true, ['sensorType'] = 'FC2_CONDITIONS'},
--['Forecast D+2 temp low'] = {['enabled'] = true, ['sensorType'] = 'FC2_LOW_TEMP'},
--['Forecast D+2 temp high'] = {['enabled'] = true, ['sensorType'] = 'FC2_HIGH_TEMP'},
--['Forecast D+2 avg hum'] = {['enabled'] = true, ['sensorType'] = 'FC2_HUM'},
--['Forecast D+2 rain all day'] = {['enabled'] = true, ['sensorType'] = 'FC2_QPF_ALLDAY'},
--['Forecast D+2 rain day'] = {['enabled'] = true, ['sensorType'] = 'FC2_QPF_DAY'},
--['Forecast D+2 rain night'] = {['enabled'] = true, ['sensorType'] = 'FC2_QPF_NIGHT'},
--['Forecast D+2 snow all day'] = {['enabled'] = true, ['sensorType'] = 'FC2_SNOW_ALLDAY'},
--['Forecast D+2 snow day'] = {['enabled'] = true, ['sensorType'] = 'FC2_SNOW_DAY'},
--['Forecast D+2 snow night'] = {['enabled'] = true, ['sensorType'] = 'FC2_SNOW_NIGHT'},
--['Forecast D+2 wind'] = {['enabled'] = true, ['sensorType'] = 'FC2_WIND'},
-- Devices used for forecast period 3. (D+3 = 3 Days after today)
--['Forecast D+3'] = {['enabled'] = true, ['sensorType'] = 'FC3_CONDITIONS'},
--['Forecast D+3 temp low'] = {['enabled'] = true, ['sensorType'] = 'FC3_LOW_TEMP'},
--['Forecast D+3 temp high'] = {['enabled'] = true, ['sensorType'] = 'FC3_HIGH_TEMP'},
--['Forecast D+3 avg hum'] = {['enabled'] = true, ['sensorType'] = 'FC3_HUM'},
--['Forecast D+3 rain all day'] = {['enabled'] = true, ['sensorType'] = 'FC3_QPF_ALLDAY'},
--['Forecast D+3 rain day'] = {['enabled'] = true, ['sensorType'] = 'FC3_QPF_DAY'},
--['Forecast D+3 rain night'] = {['enabled'] = true, ['sensorType'] = 'FC3_QPF_NIGHT'},
--['Forecast D+3 snow all day'] = {['enabled'] = true, ['sensorType'] = 'FC3_SNOW_ALLDAY'},
--['Forecast D+3 snow day'] = {['enabled'] = true, ['sensorType'] = 'FC3_SNOW_DAY'},
--['Forecast D+3 snow night'] = {['enabled'] = true, ['sensorType'] = 'FC3_SNOW_NIGHT'},
--['Forecast D+3 wind'] = {['enabled'] = true, ['sensorType'] = 'FC3_WIND'},
-- Devices used for forecast period 4. (D+4 = 4 Days after today)
--['Forecast D+4'] = {['enabled'] = true, ['sensorType'] = 'FC4_CONDITIONS'},
--['Forecast D+4 temp low'] = {['enabled'] = true, ['sensorType'] = 'FC4_LOW_TEMP'},
--['Forecast D+4 temp high'] = {['enabled'] = true, ['sensorType'] = 'FC4_HIGH_TEMP'},
--['Forecast D+4 avg hum'] = {['enabled'] = true, ['sensorType'] = 'FC4_HUM'},
--['Forecast D+4 rain all day'] = {['enabled'] = true, ['sensorType'] = 'FC4_QPF_ALLDAY'},
--['Forecast D+4 rain day'] = {['enabled'] = true, ['sensorType'] = 'FC4_QPF_DAY'},
--['Forecast D+4 rain night'] = {['enabled'] = true, ['sensorType'] = 'FC4_QPF_NIGHT'},
--['Forecast D+4 snow all day'] = {['enabled'] = true, ['sensorType'] = 'FC4_SNOW_ALLDAY'},
--['Forecast D+4 snow day'] = {['enabled'] = true, ['sensorType'] = 'FC4_SNOW_DAY'},
--['Forecast D+4 snow night'] = {['enabled'] = true, ['sensorType'] = 'FC4_SNOW_NIGHT'},
--['Forecast D+4 wind'] = {['enabled'] = true, ['sensorType'] = 'FC4_WIND'},
return _CCode: Select all
-- Weather Underground Scraper, wUnderScraper.lua
-- There is a daily limit and minute rate limit to the number of requests that can be made to the WU API for free.
-- When writing this, the number of free calls per day (New York time) was 500.
local fetchIntervalDayMins = 20 -- Day time scraping interval. Never set this below 4 if you have a free WU API account.
local fetchIntervalNightMins = 30 -- Night time scraping interval.
Please don't make any changes below this line. All configuration
except for the 2 variables above, is done in wUnderScrapeConfig.lua
Using Weather API: http://api.wunderground.com/weather/api/d/docs
To look at the returned json, you might use: http://jsonviewer.stack.hu/
local scriptVersion = '1.0.0'
local scriptName = 'wUnderScraper'
active = true,
logging = {
--level = domoticz.LOG_DEBUG, -- Select one of LOG_DEBUG, LOG_INFO, LOG_ERROR, LOG_FORCE to override system log level
marker = scriptName..' '..scriptVersion
timer = {
'every '..tostring(fetchIntervalDayMins)..' minutes at daytime',
'every '..tostring(fetchIntervalNightMins)..' minutes at nighttime',
httpResponses = {scriptName}
data = {
observation_epoch = {initial=-1}
local config = require (scriptName..'Config')
if (item.isTimer) then
local url = 'https://api.wunderground.com/api/'..config.wuAPIkey..'/conditions/forecast/'..'lang:'..config.wuLang..'/q/'..config.countryCode..'/'..config.location..'.json'
domoticz.log('Requesting new weather data from Wunderground...', domoticz.LOG_DEBUG)
domoticz.log('URL used: '..url, domoticz.LOG_DEBUG)
domoticz.openURL({url = url, method = 'GET', callback = scriptName}).afterSec(10)
if not item.isHTTPResponse then return end
local response = item
if not response.ok or not response.isJSON then
domoticz.log('Last http response was not what expected. Trigger: '..response.trigger, domoticz.LOG_ERROR)
local _ = require('lodash')
domoticz.log(_.str(response.data), domoticz.LOG_ERROR)
return
local wuData = response.json
local observation_epoch = tonumber(wuData.current_observation.observation_epoch) or 0
local observation_time = wuData.current_observation.observation_time
if observation_epoch <= domoticz.data.observation_epoch then
domoticz.log('Data from Wunderground is not newer than the previously fetched, are you fetching to often maybe? ('..observation_time..')' , domoticz.LOG_FORCE)
return
domoticz.data.observation_epoch = observation_epoch
domoticz.log(wuData.current_observation.display_location.full..', '..observation_time, domoticz.LOG_INFO)
-- Domoticz sensor types
local SENSOR_BARO = 1
local SENSOR_TEXT = 5
local SENSOR_VISIBILITY = 12
local SENSOR_SOLAR_RADIATION = 20
local SENSOR_TEMP = 80
local SENSOR_HUM = 81
local SENSOR_TEMP_HUM = 82
local SENSOR_TEMP_BARO = 247
local SENSOR_TEMP_HUM_BARO = 84
local SENSOR_RAIN = 85
local SENSOR_WIND = 86
local SENSOR_UV = 87
-- Each domoWeatherDevices entry in the config file should use one of the following as sensorType:
-- Where C_ stands for Current Conditions
-- and FC* stands for Forecast period number 1-4
local sensorTypes={
C_CONDITIONS = {domoType=SENSOR_TEXT, wuPeriod=0},
C_BARO = {domoType=SENSOR_BARO, wuPeriod=0},
C_VISIBILITY = {domoType=SENSOR_VISIBILITY, wuPeriod=0},
C_SOLAR_RADIATION = {domoType=SENSOR_SOLAR_RADIATION, wuPeriod=0},
C_TEMP = {domoType=SENSOR_TEMP, wuPeriod=0},
C_HUM = {domoType=SENSOR_HUM, wuPeriod=0},
C_TEMP_HUM = {domoType=SENSOR_TEMP_HUM, wuPeriod=0},
C_TEMP_BARO = {domoType=SENSOR_TEMP_BARO, wuPeriod=0},
C_TEMP_HUM_BARO = {domoType=SENSOR_TEMP_HUM_BARO, wuPeriod=0},
C_RAIN = {domoType=SENSOR_RAIN, wuPeriod=0},
C_WIND = {domoType=SENSOR_WIND, wuPeriod=0},
C_UV = {domoType=SENSOR_UV, wuPeriod=0},
FC1_LOW_TEMP = {domoType=SENSOR_TEMP, wuPeriod=1, wuField='low'},
FC1_HIGH_TEMP = {domoType=SENSOR_TEMP, wuPeriod=1, wuField='high'},
FC1_HUM = {domoType=SENSOR_HUM, wuPeriod=1, wuField='avehumidity'},
FC1_CONDITIONS = {domoType=SENSOR_TEXT, wuPeriod=1},
-- (QPF = Quantitative Precipitation Forecasts)
FC1_QPF_ALLDAY = {domoType=SENSOR_RAIN, wuPeriod=1, wuField='qpf_allday'},
FC1_QPF_DAY = {domoType=SENSOR_RAIN, wuPeriod=1, wuField='qpf_day'},
FC1_QPF_NIGHT = {domoType=SENSOR_RAIN, wuPeriod=1, wuField='qpf_night'},
FC1_SNOW_ALLDAY = {domoType=SENSOR_RAIN, wuPeriod=1},
FC1_SNOW_DAY = {domoType=SENSOR_RAIN, wuPeriod=1},
FC1_SNOW_NIGHT = {domoType=SENSOR_RAIN, wuPeriod=1},
FC1_WIND = {domoType=SENSOR_WIND, wuPeriod=1},
FC2_LOW_TEMP = {domoType=SENSOR_TEMP, wuPeriod=2, wuField='low'},
FC2_HIGH_TEMP = {domoType=SENSOR_TEMP, wuPeriod=2, wuField='high'},
FC2_HUM = {domoType=SENSOR_HUM, wuPeriod=2, wuField='avehumidity'},
FC2_CONDITIONS = {domoType=SENSOR_TEXT, wuPeriod=2},
FC2_QPF_ALLDAY = {domoType=SENSOR_RAIN, wuPeriod=2, wuField='qpf_allday'},
FC2_QPF_DAY = {domoType=SENSOR_RAIN, wuPeriod=2, wuField='qpf_day'},
FC2_QPF_NIGHT = {domoType=SENSOR_RAIN, wuPeriod=2, wuField='qpf_night'},
FC2_SNOW_ALLDAY = {domoType=SENSOR_RAIN, wuPeriod=2},
FC2_SNOW_DAY = {domoType=SENSOR_RAIN, wuPeriod=2},
FC2_SNOW_NIGHT = {domoType=SENSOR_RAIN, wuPeriod=2},
FC2_WIND = {domoType=SENSOR_WIND, wuPeriod=2},
FC3_LOW_TEMP = {domoType=SENSOR_TEMP, wuPeriod=3, wuField='low'},
FC3_HIGH_TEMP = {domoType=SENSOR_TEMP, wuPeriod=3, wuField='high'},
FC3_HUM = {domoType=SENSOR_HUM, wuPeriod=3, wuField='avehumidity'},
FC3_CONDITIONS = {domoType=SENSOR_TEXT, wuPeriod=3},
FC3_QPF_ALLDAY = {domoType=SENSOR_RAIN, wuPeriod=3, wuField='qpf_allday'},
FC3_QPF_DAY = {domoType=SENSOR_RAIN, wuPeriod=3, wuField='qpf_day'},
FC3_QPF_NIGHT = {domoType=SENSOR_RAIN, wuPeriod=3, wuField='qpf_night'},
FC3_SNOW_ALLDAY = {domoType=SENSOR_RAIN, wuPeriod=3},
FC3_SNOW_DAY = {domoType=SENSOR_RAIN, wuPeriod=3},
FC3_SNOW_NIGHT = {domoType=SENSOR_RAIN, wuPeriod=3},
FC3_WIND = {domoType=SENSOR_WIND, wuPeriod=3},
FC4_LOW_TEMP = {domoType=SENSOR_TEMP, wuPeriod=4, wuField='low'},
FC4_HIGH_TEMP = {domoType=SENSOR_TEMP, wuPeriod=4, wuField='high'},
FC4_HUM = {domoType=SENSOR_HUM, wuPeriod=4, wuField='avehumidity'},
FC4_CONDITIONS = {domoType=SENSOR_TEXT, wuPeriod=4},
FC4_QPF_ALLDAY = {domoType=SENSOR_RAIN, wuPeriod=4, wuField='qpf_allday'},
FC4_QPF_DAY = {domoType=SENSOR_RAIN, wuPeriod=4, wuField='qpf_day'},
FC4_QPF_NIGHT = {domoType=SENSOR_RAIN, wuPeriod=4, wuField='qpf_night'},
FC4_SNOW_ALLDAY = {domoType=SENSOR_RAIN, wuPeriod=4},
FC4_SNOW_DAY = {domoType=SENSOR_RAIN, wuPeriod=4},
FC4_SNOW_NIGHT = {domoType=SENSOR_RAIN, wuPeriod=4},
FC4_WIND = {domoType=SENSOR_WIND, wuPeriod=4}
local function degToCompass(num)
num = (num >= 0 and num < 360) and num or 0
local val = math.floor((num/22.5)+.5)
local t = {'N','NNE','NE','ENE','E','ESE', 'SE', 'SSE','S','SSW','SW','WSW','W','WNW','NW','NNW'}
return t[(val % 16) + 1]
local function getHumStat(hum)
if hum > 70 then
return domoticz.HUM_WET
elseif hum < 30 then
return domoticz.HUM_DRY
return domoticz.HUM_COMFORTABLE
local function getBaroForecast(mbar)
-- Barometer forecast, 0 = Stable, 1 = Sunny, 2 = Cloudy, 3 = Unstable, 4 = Thunderstorm, 5 = Unknown, 6 = Cloudy/Rain
-- A very primitive method indeed to make conclusions based only on current barometric pressure.
-- It wont work well! Better to also take other parameters in consideration.
if mbar < 950 then
return domoticz.BARO_THUNDERSTORM
elseif mbar < 1000 then
return domoticz.BARO_UNSTABLE
elseif mbar < 1020 then
return domoticz.BARO_CLOUDY
return domoticz.BARO_SUNNY
local function wind_chill(temp, wind)
-- Compute wind chill, using formula from http://en.wikipedia.org/wiki/wind_chill
if not temp then return end
local wind_kph = wind * 3.6
if wind_kph <= 4.8 or temp > 10.0 then return temp end
return domoticz.utils.round(math.min(13.12 + (temp * 0.6215) + (((0.3965 * temp) - 11.37) * (wind_kph ^ 0.16)), temp))
local function kmhToMs(kmh)
return domoticz.utils.round(kmh * 0.2778, 1) -- km/h to m/s rounded
for dDev, devConfig in pairs(config.domoWeatherDevices) do
if devConfig.enabled then
if domoticz.devices(dDev) ~= nil then
local device = domoticz.devices(dDev)
local sensorType = devConfig.sensorType
if not sensorTypes[sensorType] then
domoticz.log(tostring(dDev)..' has an invalid sensorType: \''..sensorType..'\'', domoticz.LOG_ERROR)
return
local sensorConfig = sensorTypes[sensorType]
-- print(sensorType) e.g. 'C_BARO'
local domoSensorType = sensorConfig.domoType
local wuField = sensorConfig.wuField
local fetchInterval = (domoticz.time.matchesRule('at nighttime') and fetchIntervalNightMins or fetchIntervalDayMins)
local temperature, pressure, humidity, weather, visibility, radiation,
rainCounter, rainRate, windBearing, windDirection, windSpeed,
windGust, windChill, baroForecast, humidityStatus
local wuPeriod = sensorConfig.wuPeriod
if wuPeriod == 0 then -- Current observation
temperature = tonumber(wuData.current_observation.temp_c) or 0
pressure = tonumber(wuData.current_observation.pressure_mb) or 0
local _hum, _ = wuData.current_observation.relative_humidity:gsub('%%','')
humidity = tonumber(_hum) or 0
weather = wuData.current_observation.weather
visibility = tonumber(wuData.current_observation.visibility_km) or 0
radiation = tonumber(wuData.current_observation.solarradiation) or 0
rainCounter = tonumber(wuData.current_observation.precip_today_metric) or 0
rainRate = tonumber(wuData.current_observation.precip_1hr_metric) or 0
windBearing = tonumber(wuData.current_observation.wind_degrees) or 0
windBearing = (windBearing >= 0 and windBearing <= 359) and windBearing or 0
windDirection = degToCompass(windBearing)
windSpeed = kmhToMs(tonumber(wuData.current_observation.wind_kph) or 0)
windGust = kmhToMs(tonumber(wuData.current_observation.wind_gust_kph) or 0)
baroForecast = getBaroForecast(pressure)
domoticz.log('\n\n==================================================', domoticz.LOG_DEBUG)
domoticz.log('temperature: '..tostring(temperature), domoticz.LOG_DEBUG)
domoticz.log('pressure: '..tostring(pressure), domoticz.LOG_DEBUG)
domoticz.log('humidity: '..tostring(humidity), domoticz.LOG_DEBUG)
domoticz.log('weather: '..weather, domoticz.LOG_DEBUG)
domoticz.log('visibility: '..tostring(visibility), domoticz.LOG_DEBUG)
domoticz.log('radiation: '..tostring(radiation), domoticz.LOG_DEBUG)
domoticz.log('rainCounter: '..tostring(rainCounter), domoticz.LOG_DEBUG)
domoticz.log('rainRate: '..tostring(rainRate), domoticz.LOG_DEBUG)
domoticz.log('windBearing: '..tostring(windBearing), domoticz.LOG_DEBUG)
domoticz.log('windDirection: '..windDirection, domoticz.LOG_DEBUG)
domoticz.log('windSpeed: '..tostring(windSpeed), domoticz.LOG_DEBUG)
domoticz.log('windGust: '..tostring(windGust), domoticz.LOG_DEBUG)
domoticz.log('baroForecast: '..baroForecast, domoticz.LOG_DEBUG)
domoticz.log('==================================================\n\n', domoticz.LOG_DEBUG)
else -- Forecast
if domoSensorType == SENSOR_TEXT then
weather = wuData.forecast.simpleforecast.forecastday[wuPeriod].conditions
elseif domoSensorType == SENSOR_TEMP then
temperature = tonumber(wuData.forecast.simpleforecast.forecastday[wuPeriod][wuField].celsius) or 0
elseif domoSensorType == SENSOR_HUM then
humidity = tonumber(wuData.forecast.simpleforecast.forecastday[wuPeriod][wuField]) or 0
elseif domoSensorType == SENSOR_RAIN then
rainCounter = tonumber(wuData.forecast.simpleforecast.forecastday[wuPeriod][wuField].mm) or 0
rainRate = rainCounter
elseif domoSensorType == SENSOR_WIND then
wuField = 'low' -- Need a temperature for calculating wind chill
windBearing = tonumber(wuData.forecast.simpleforecast.forecastday[wuPeriod].avewind.degrees) or 0
windSpeed = kmhToMs(tonumber(wuData.forecast.simpleforecast.forecastday[wuPeriod].avewind.kph) or 0)
windGust = kmhToMs(tonumber(wuData.forecast.simpleforecast.forecastday[wuPeriod].maxwind.kph) or 0)
-- Baro pressure N/A in forecast
-- visibility N/A in forecast
-- radiation = N/A in forecast
if temperature and windSpeed then windChill = wind_chill(temperature, windSpeed) end
if humidity then humidityStatus = getHumStat(humidity) end
if domoSensorType == SENSOR_BARO then
if (pressure ~= device.barometer)
or (baroForecast ~= device.forecast)
or (device.lastUpdate.minutesAgo > 60-fetchInterval) then
domoticz.log('Updating Domoticz barometer device '..tostring(dDev)..' to value: \''..tostring(pressure)..'\', \''..baroForecast..'\'', domoticz.LOG_DEBUG)
device.updateBarometer(pressure, baroForecast)
elseif domoSensorType == SENSOR_TEXT then
if weather ~= device.text then
domoticz.log('Updating Domoticz text device '..tostring(dDev)..' to value: \''..weather..'\'', domoticz.LOG_DEBUG)
device.updateText(weather)
elseif domoSensorType == SENSOR_VISIBILITY then
if (visibility ~= device.visibility) or (device.lastUpdate.minutesAgo > 60-fetchInterval) then
domoticz.log('Updating Domoticz solar visibility device '..tostring(dDev)..' to value: \''..tostring(visibility)..'\'', domoticz.LOG_DEBUG)
device.updateVisibility(visibility)
elseif domoSensorType == SENSOR_SOLAR_RADIATION then
if (radiation ~= device.radiation) or (device.lastUpdate.minutesAgo > 60-fetchInterval) then
domoticz.log('Updating Domoticz solar radiation device '..tostring(dDev)..' to value: \''..tostring(radiation)..'\'', domoticz.LOG_DEBUG)
device.updateRadiation(radiation)
if (temperature ~= device.temperature) or (device.lastUpdate.minutesAgo > 60-fetchInterval) then
domoticz.log('Updating Domoticz temperature device '..tostring(dDev)..' to value: \''..tostring(temperature)..'\'', domoticz.LOG_DEBUG)
device.updateTemperature(temperature)
if (humidity ~= device.humidity)
or (humidityStatus ~= device.humidityStatus)
domoticz.log('Updating Domoticz humidity device '..tostring(dDev)..' to value: \''..tostring(humidity)..'\', \''..tostring(humidityStatus)..'\'', domoticz.LOG_DEBUG)
device.updateHumidity(humidity, humidityStatus)
elseif domoSensorType == SENSOR_TEMP_HUM then
or (humidity ~= device.humidity)
domoticz.log('Updating Domoticz temp hum device '..tostring(dDev)..' to value: \''..tostring(temperature)..'\', \''..tostring(humidity)..'\', \''..tostring(humidityStatus)..'\'', domoticz.LOG_DEBUG)
device.updateTempHum(temperature, humidity, humidityStatus)
elseif domoSensorType == SENSOR_TEMP_BARO then
domoticz.log('Updating Domoticz temp baro device '..tostring(dDev)..' to value: \''..tostring(temperature)..'\', \''..tostring(pressure)..'\', \''..baroForecast..'\'', domoticz.LOG_DEBUG)
device.updateTempBaro(temperature, pressure, baroForecast)
elseif domoSensorType == SENSOR_TEMP_HUM_BARO then
domoticz.log('Updating Domoticz temp hum baro device '..tostring(dDev)..' to value: \''..tostring(temperature)..'\', \''..tostring(humidity)..'\', \''..tostring(humidityStatus)..'\', \''..tostring(pressure)..'\', \''..baroForecast..'\'', domoticz.LOG_DEBUG)
device.updateTempHumBaro(temperature, humidity, humidityStatus, pressure, baroForecast)
if (rainCounter ~= device.rain)
or (rainRate ~= device.rainRate)
domoticz.log('Updating Domoticz rain device '..tostring(dDev)..' to value: \''..tostring(rainRate)..'\', \''..tostring(rainCounter)..'\', \''..tostring(humidityStatus)..'\'', domoticz.LOG_DEBUG)
device.updateRain(rainRate, rainCounter)
if (windBearing ~= device.direction)
or (windDirection ~= device.directionString)
or (windSpeed ~= device.speed)
or (windGust ~= device.gust)
or (temperature ~= device.temperature)
or (windChill ~= device.chill)
domoticz.log('Updating Domoticz wind device '..tostring(dDev)..' to value: \''..tostring(windBearing)..'\', \''..windDirection..'\', \''..tostring(windSpeed)..'\', \''..tostring(windGust)..'\', \''..tostring(temperature)..'\', \''..tostring(windChill)..'\'', domoticz.LOG_DEBUG)
device.updateWind(windBearing, windDirection, windSpeed, windGust, temperature, windChill)
elseif domoSensorType == SENSOR_UV then
if (radiation ~= device.uv) or (device.lastUpdate.minutesAgo > 60-fetchInterval) then
domoticz.log('Updating Domoticz UV device '..tostring(dDev)..' to value: \''..tostring(radiation)..'\'', domoticz.LOG_DEBUG)
device.updateUV(radiation)
domoticz.log('I don\'t know what to do with: '..tostring(dDev)..', domoSensorType: '..tostring(domoSensorType), domoticz.LOG_ERROR)
