Domoticz doesn't show total kWh anymore
naitsirhc
Post by naitsirhc »
Recently I discovered that my Domoticz doesn't show the total amount of kWh pruduced by my solar panels. I don't know when it happened and I'm not sure if it's my fault ;)
When I look in devices, I do see the total amount of kWh, But when I look at utility I see "live" value and total of today.
Someone knows the trick? Thanks in advance
Und Tschjuß
blauwebuis
Domoticz version: current
Re: Domoticz doesn't show total kWh anymore
Post by blauwebuis »
There was a change in data output recently. I also noticed that an old power value was no longer coming through. This might be the same issue.
Dexter
Post by Dexter »
That was the issue in my case. Thanks!
My son tries new things without any fear. He likes those aquariums at aquariumairpump com. I'm gonna buy him the one pretty soon. I believe he knows about it.
naitsirhc
Post by naitsirhc »
I have been thinking. When I create a dummy device which shows the total amount, I would be satisfied.
When I type:
http://10.0.0.170:8080/json.htm?type=devices&rid=47
The device returns some values:
CounterToday "6.936 kWh"
CustomImage 0
Data "6427.55 kWh"
And more....
Probably it is possible to create a device which shows the data...?
Unfotunatly I don't have the skills to create the device with the proper code.
Can anyone help me?
Kind regards...
Und Tschjuß
naitsirhc
Post by naitsirhc »
Nobody???
Und Tschjuß
McMelloW
Domoticz version: V2024.1
Post by McMelloW »
naitsirhc wrote: Sunday 18 March 2018 8:51Nobody???
There are a number of other topics on the same issue.
Missing value at Energy Sensor
Solar panels not showing overall totals
Electric (instant+counter) - Domoticz doesn't compute Energy
Also there is an issue #2196 opened about it at github. But so far there is hardly any response on this matter.
It is not a lua or dzVents issue, so it seems to be a Domoticz issue.
Greetings McMelloW
SweetPants
Post by SweetPants »
GizMoCuz already answered this question on GitHub "This is intended by a recent change to cleanup all sensors
Anyway, this is an always increasing value and you can display this in the report view
Sasquatch
Post by Sasquatch »
So only feature i have build KWh sensor for is now hidden behind 4 clicks and not accessible on mobile app.
don't know anyone that needs daily kwh usage instead of total.
rant over
is there any way to undo this change manually on my install?
