Why aren't my temperature sensores from the Honeywell Evhome HGI80 available in Blockly?
I know I can use JSON to control the zones/switch etc, but what if I want to react on a temperature value of a certain zone? For example when it is higher then 20 degrees, the fan should be turned on. I do not see the temperature sensors from Honeywell Evohome via the HGI80, I see other temperature sensors (Z-wave sensors) in Blockly. However when I show "current states", I see all my temperature sensors from the different zones with the correct temperature?
Why can I not use them in Blockly?
Kind regards
Honeywell Evohome HGI80 Blockly
- Domoticz version: stable
Re: Honeywell Evohome HGI80 Blockly
Thanks, but how can I use the temperature from these zones as input for an action?
Kind regards
