RFXtrx433 Version 0
meyland
RFXtrx433 Version 0
Post by meyland »
I'm running Domoticz 3.8153 under Fedora 26 x64 and I'm using the packages found i the Fedora Update Repository. The installation is running smooth and I think everything is working, including my RFXCom RFXtrx433 connected as /dev/ttyUSB0. But if I click the botton "Set Mode" in the Hardware View screen no protocols are checked and if I click "Default" then the checkboxes are cheked and when I click "Set Mode" I can see these entries in the log:
2018-01-20 21:48:38.742  subtype           = Interface Command
Sequence nbr      = 208
set configuration of the interface
2018-01-20 21:48:39.032  subtype          = Wrong command received from application (3)
Sequence nbr      = 208
2018-01-20 21:48:39.304  subtype           = Interface Response
Sequence nbr      = 209
response on cmnd  = Save
Also the "Hardware screen" tells me the firmaware are "version: 0"
I hope that someone can tell me what I have been missing og could guide me in the right direction
regards
Peter
Siewert308SW
Domoticz version: Stable
Re: RFXtrx433 Version 0
Post by Siewert308SW »
Do you have the hardware enabled?
Schermafdruk 2018-01-20 22.06.31.png (11.55 KiB) Viewed 1575 times
Setup:
- DS923+ Docker
Domoticz Latest Stable
Mosquitto / ZwaveJSUI @ Aeotec Z-Stick Gen5+ / PiHole Unbound
P1 USB Gas/Power, HW watermeter
- A lot of Zwave switches, contacts, plugs, smoke/Co2 ect
- DiY 7.5kWh Solar Storage @ GitHuB
meyland
Post by meyland »
Yes, the hardware are enabled and my 433.92MHz devices can communicate with the transiver, byt as you can see the version are wrong. My RFXtra433 device are upgraded with the lateste firmware (version 1022)
regards
Peter
meyland
Post by meyland »
Problem solved
A reboot of the computer did the trick. I can not see the firmware version and which protocols there are enabled
regards
Peter
