Scraping only temperature from DarkSky
Qcvictor
Post by Qcvictor »
Hi Guys
I'm trying to get only the temperature in an virtual temperature sensor from DarkSky, I use the script found here https://www.domoticz.com/wiki/Virtual_weather_devices unfortunately doesn't work
I get
 Error: EventSystem: in TempDarkSky: [string "--Script To Parse WeatherUnderground Multi-Va..."]:14: attempt to index global 'devicechanged' (a nil value)
Where the line said
if devicechanged[sensorwu] then
I imagine I have to change "sensorwu" !
Any clue
Qcvictor
Re: Scraping only temperature from DarkSky
Post by Qcvictor »
Reply to me:
Finally I use this script:
local sensorwu = 'THB' --name of the sensor that gets created when you add the WU device (and that contains multiple values like temperature, humidity, barometer etc)
local idxt = 76 --idx of the virtual temperature sensor you need to change this to your own Device IDx
        sWeatherTemp, sWeatherHumidity = otherdevices_svalues[sensorwu]:match("([^;]+);([^;]+);([^;]+)")
        sWeatherTemp = tonumber(sWeatherTemp)
        commandArray[1] = {['UpdateDevice'] = idxt .. '|0|' .. sWeatherTemp}
execute as "device" and look like working..
