aqara gateway sounds
fubar
Post by fubar »
I'm new to domoticz and have a new aqara xiaomi gateway with firmware 1.4.1_151.0143 connected to a domoticz server running the latest github dev code on ubuntu 17.04. I'm relying on the guide at https://www.domoticz.com/wiki/Xiaomi_Gateway_(Aqara) but I can't see any of the sound devices that guide seems to suggest will be auto-generated when the aqara gateway is connected. Note that I have no devices yet - waiting on a couple to arrive.
In the log, the server seems to see the gateway:
2018-01-19 13:35:35.076 Domoticz V3.8825 (c)2012-2018 GizMoCuz
2018-01-19 13:35:35.076 Build Hash: 65ea7bbc, Date: 2018-01-18 22:12:17
2018-01-19 13:35:37.113 XiaomiGateway: will listen on 9898 for hardware id 2
2018-01-19 13:35:37.113 XiaomiGateway: Delaying worker startup...
2018-01-19 13:35:42.113 XiaomiGateway: Worker started...
However, the sounds documented in the guide don't appear anywhere when I poke around trying to test them.
I've removed and added the gateway with today's git updates but no joy...or else I'm looking in all the wrong places.
Any advice or suggestions appreciated - thanks!
fubar
Re: aqara gateway sounds
Post by fubar »
Replying to myself... :ugeek:
Turns out the problem was that I was not on the same LAN segment as the Aqara gateway. Shifted domoticz to the file server on the main LAN and it talks to the gateway just fine at startup. Now I have frequent disconnects to deal with so learning all about logging - it's the same in homeassistant so I fear it may be a hardware or local wireless stability problem....
Hoekies
Post by Hoekies »
I have the same problem . What do you mean with the same LAN segment ?
Have my raspberry connected to my LAN and the Gateway through wifi to the same router.
What do i miss ?
Hoekies
Post by Hoekies »
solved. wifi raspberry found them
