dzVents timer with switch
parrotface
Post by parrotface »
I have dzVents script running every minute OK but I am trying to run it only when a switch is on.
         timer = {'every 1 minutes'},
I still need it to run every minute but only when switch is on
emme
Domoticz version: latest
Re: dzVents timer with switch
Post by emme »
		device = { 'myDevice'},
	execute = function(domoticz, device, triggerInfo)
	    if triggerInfo.type  == domoticz.EVENT_TYPE_TIMER then
	        -- do timer event stuff
	    elseif triggerInfo.type  == domoticz.EVENT_TYPE_DEVICE then
	        -- do device event stuff
Last edited by dannybloe on Wednesday 17 January 2018 16:15, edited 1 time in total.
Reason: code block
"We always done this way"
parrotface
Thanks for your reply - very helpful but I am still having problem with the switch section. Every minute appears in log but when I switch On nothing happens. Do I have to check that it is either On or Off?
device = { 'Switch1'},
domoticz.log(' timer ')
domoticz.log(' switch ')
Thanks for your help
emme
Post by emme »
that's quite wired....
is Switch1 wrote correctly and reflect the correct UPPER and lower case? (Swith1 is no switch1 ;) )
try also to add this line after the extecute = (and before the if statement)
domoticz.log('Trigger ==> '..triggerInfo.type)
just to understand who's doing what ;)
ciao
M
parrotface
Thanks for you help will try that next.
in the mean time I have got it doing what I want but I don't think it is the correct way of going about things
if triggerInfo.type == domoticz.EVENT_TYPE_TIMER and domoticz.devices('Switch1').state == 'On'then
domoticz.log(' === Switch On ===== ')
parrotface
triger info
2018-01-18 10:53:00.162 dzVents: Info: Trigger ==> timer
emme
Post by emme »
and the switch never triggers?!
emme
Post by emme »
uuuuuh... F***!!!
deviceS = { 'Switch1'},
sorry... my fault :cry:
parrotface
Have tried devices before
still No Go
I will try again later as I have to go out for a few hours
Thanks for your help will let you know later
dannybloe
Post by dannybloe »
Read the troubleshooting section in the docs.
TheWoodenGamer
Post by TheWoodenGamer »
Perhaps this works? It does for me.
	-- triggers
		-- device triggers
		devices = {
			-- scripts is executed if the device that was updated matches with one of these triggers
			42, -- Philips Hue Wall Switch
	-- custom logging level for this script
	logging = {
        level = domoticz.LOG_DEBUG,
        marker = "Hue wall switch initiated"
    	-- do something with the event
	execute = function(domoticz, device, info)
		if (device.active) then -- state == 'On'
			device.switchOff().afterMin(1) -- if it is a switch, turn off after 1 minute
