Compile domoticz on Raspberry PI-3 memory problem
Because the precompiled Beta versions still fail on my system (Debian stretch, OpenSSL 1.1.0, Python 3.5.3) I compile from source on my backup / development PI-3 using:
git clone https://github.com/domoticz/domoticz.git dev-domoticz
cd dev-domoticz
# Update to latest
git pull
# -DUSE_OPENSSL_STATIC="NO" because of problem with Evohome API
cmake -DUSE_OPENSSL_STATIC="NO" -DCMAKE_BUILD_TYPE=Beta CMakeLists.txt
# Twice because of strange version number after first time
# to minimize amount of memory for GPU
raspi-config
shutdown -r
# Free up memory as much as possible
fail2ban-client quit
# setup zram
modprobe zram
echo 3 >/sys/devices/virtual/block/zram0/max_comp_streams
echo lz4 >/sys/devices/virtual/block/zram0/comp_algorithm
echo 536870912 >/sys/devices/virtual/block/zram0/mem_limit
echo 1073741824 >/sys/devices/virtual/block/zram0/disksize
mkswap /dev/zram0
swapon -p 0 /dev/zram0
sysctl vm.swappiness=80
# attempt one
cd dev-domoticz
make
# attempt two because first one fails at the link step (use one CPU)
rm domoticz  // sometimes file exist with size 0
make -j1
(of course I did the preparation steps as described in the wiki)
This works and give me a working executable with working Python plugins and working Evohome. Probably because of the static linked libraries the size of the executable is about twice the size of the precompiled version.
One thing that does not work, is to compile with the debug option and that's one of the reasons I am very much interested in better ways to compile with this limited amount of memory.
Hope other forum members with same setup can share how they compile.
