Domoticz IOS App in Appstore Now
Moderator: remb0
- remb0
After the successful Android version we got many questions about an IOS version.
Last saturday the app for Apple is released!
Check the promo video:
Download it in the itunes store.
https://itunes.apple.com/us/app/domotic ... ?ls=1&mt=8
Please download, try and give it 5 stars.
Original topic on this forum:
http://www.domoticz.com/forum/viewtopic ... 36&t=17025
Re: Domoticz IOS App in Appstore Now
Works great!!!
- galadril
- Domoticz version: latest
`thanks, works for me too, I do have some feedback however. Should I send that to the bugs and issues pages?
- galadril
- htilburgs
Installed APP, entered configuration (IP, Port, name, etc...).
Then the App is telling me "checking configuration" and it crashes.
Tried several times, no luck.....
update:
this issue appears when you enter the public ip address AND the private (local) ip address
When I just use the local ip, the configuration finish and I can use the App.
Afterwards updating the information with the external and internal isn't working, the setup checks, but no results.
Maybe it has something to do with http / https configuration. I have to look further into this.
update:
Hardware:
- coolwine1962
- Domoticz version: 2020.1
Great App.
1 x Raspberry Pi4 Raspbian
1 x ANT GP433Mhz
1 x Rfxcom
1 x RainSensor
1 x Kaku Doorbel
1 X Aeon Z-Wave USB Stick
25 x Fibaro WallPlug
2 x ZRC90
2 x Aeotec MultiSensor
6 x zWave Greenwave 6
4 x zWave Greenwave 1
1 x Pi slave for Electra and Gas
1 x ANT GP433Mhz
1 x Rfxcom
1 x RainSensor
1 x Kaku Doorbel
2 x ZRC90
Looks nice! I've test some stuff on the free version. Bought it now.
- RickDB
Awesome, works great!
Domoticz IOS app has certificate problem with https server connection.
How can I solve it?
Tapatalkkal küldve az én SM-G935F eszközömről
How can I solve it?
I want to use my.domoticz.com for the app. Is it possible?
I think not. You can only set your local server address.Wolli82 wrote:I want to use my.domoticz.com for the app. Is it possible?
- Domoticz version: 4.10717
There is a problem with external access if the Dyn provider is not available.
First you specify the external access, e. g. with DynDNS or Changeip.
The second is the internal access with the local IP address.
If the external provider has a problem, or the Internet does not work, there is an error message.
If you are in the internal area, the app should still work, because the internal connection was specified as the second one.
If the external connection does not work because of a fault, the internal connection does not work either, even though you are in the internal area.
The app does not continue and does not check the local connection.
I am a novice and I wonder about the interest of this app. What does it bring compared to the view in a browser that seems much more ergonomic ?
Best regards
Best regards
- madpatrick
- Domoticz version: 2024.7
Great App and nice interface
I've one little issue with the app.
The controlling of my thermostaat (Toon) is not working. When i change the temparature nothing is happening.
Other Apps (Pilot) or by webpage is working.
Any clue what this can be ?
-= HP server GEN8 Xeon(R) E3-1220L_V2 -=- OZW -=- Toon2 (rooted) -=- Domoticz v2024.7 -=- Dashticz v3.12b on Tab8" =-
- Domoticz version: Stable
I purchased the App and think its great, just a bit disappointed that you cannot use a self signed certificate like you can in the Pilot App, even free certificates require them to be updated every three months which is still a pain.
- beamzer
- Domoticz version: stable
If you mean LetsEncrypt with free certificates, they are made to be auto-updated.
I have this line in my crontab, which runs every week. It updates the certificates when necessary, well in advance of expiration
30 3 * * 1 /opt/letsencrypt/certbot-auto renew
Domoticz stable on a Raspberry Pi 3
RFXtrx433E - RFLink - Smartmeter (through RasPi-Zero-W) - Hue - BMP180 - DHT22 - Wemos D1 Mini's with PIR
I’m new to this and have problems underatnding how to set up the app. How do I connect it to my application?
