Controlicz - Domoticz to Google Home/Assistant integration Topic is solved
Madgeni
"Sync my devices" will do this
joker88
Hi Madgeni,
Can you add me please? I registrated on your website with byar****@gmail.com.
Thanks a lot
BR
Thanks a lot
BR
ramesses
- Domoticz version: 3.8755
Thanks Madgeni. I tried but Google said "I'm afraid an error occured while syncing Home Controlicz" - strange :/ ...but I can control all the devices already present in google home app.
Domoticz on RaZberry, OZW 1.4-2713
Aeotec MultiSensor 6, Aeotec LED Bulb, Vision ZD2102 Door/Window Sensor, Vision ZP3102 PIR Motion Sensor, D-Link Siren DCH-Z510, Fibaro Smoke Sensor FGSD002, Aeotec Key Fob, Qubino ZMNHDD1 Z-Wave Plus Flush Dimmer
Madgeni
hey ramesses - that happened to me today, had to unlink/relink my account - not happened before
joker88
Bonsoir
Je ne trouve pas cette option dans domoticz et l'action de demander l'ouverture du volet le ferme et vice versa
Merci
joker88
it is ok I find it
turn blind in On/off and option icone is OK, I can chose Generic
boris91530
- Domoticz version: v3.8153
Hello i have refind my sonde
huberzz
Re: Google assistant/Google home integration
It would be great to try out the controlicz, i registred on the website, would you like to add me for the google home? hu****@gmail.comMadgeni wrote: Thursday 09 November 2017 19:30 Hi Thomas,
yes it's using the Smarthome actions - PM me your email address, and i'll get you added.
Google run very short test phases - think it's a week - whereas Amazon allow beta tests to run for much longer.
I've submitted the app for certification, but it's definitely rough around the edges. The APIs i'd built for control and discovery were based around the Alexa API, so some on the fly refactoring for Google may be required! But i'm always happy to improve it - the Alexa skill grew based on the great feedback from the community here
and yes it runs both via Google Assistant (how i use it) and Google Home
Thanks in advance!
Greetz Huberzz
Questor1972
Hi Madgeni,
Could you please add me for the Google Home Beta. Mailaddresses ki***err***[email protected]. Already using Alexa version for Domoticz
ramesses
Thank you very much, it workedMadgeni wrote: Sunday 14 January 2018 19:43 hey ramesses - that happened to me today, had to unlink/relink my account - not happened before
- bueno79
- Domoticz version: 4.9700
just a quick word to tell you I continue to use your service EVERYdays. you change a small part of my daily life and it is the same for my family. It s a small part but it is great.
I hope google will aprove very soon your service. Stay strong and if I can do anything MP me.
do you have some news about the support of selectors ?
best regards
Bueno
best regards
Bueno
- thecosmicgate
- Domoticz version: newest
I wanted to start using Concrolicz together with the Home mini we own.
The fist steps completed : signup at the Conctrolicz website, but the ;(
The domoticz installation ( stable 3.8160 ) i run is configed with SSL ( Letsencrypt) , and i must use some other port the the default 443 .
So i use port : 444 , all that's fine, but when i enter this in the controlciz profile , and presses the "Test Domoticz " button , it say's ; Controlicz is unable to connect - please check your config
So i start looking at the domoticz log, to maybe find something about a failed login , but nothing at all.
What can i do wrong ?
Last edited by thecosmicgate on Wednesday 17 January 2018 15:54, edited 1 time in total.
It's nice to be important, but it's more important to be nice
Scooter ;)
Scooter ;)
corederoma82
Can I use with italian voice commands?
Raspberry PI 3, 3x Yeelight bulbs, 1x Yeeligh led strip, 1x Sonoff with ESP826, Controlicz, Kodi
- thecosmicgate
I did some furhter testing, and now getting this error :thecosmicgate wrote: Wednesday 17 January 2018 15:04 I wanted to start using Concrolicz together with the Home mini we own.
The domoticz installation i run is configed with SSL ( Letsencrypt) , and i must use some other port the the default 443 .
Error: [web:443] Failed authentication attempt, ignoring client request (remote address: 35.176.67.167)It's nice to be important, but it's more important to be nice
Scooter ;)
Scooter ;)
Madgeni
Hi - can you PM your email address?thecosmicgate wrote: Wednesday 17 January 2018 15:16I did some furhter testing, and now getting this error :thecosmicgate wrote: Wednesday 17 January 2018 15:04 I wanted to start using Concrolicz together with the Home mini we own.
but i know 150% sure that de pwd is okay :SCode: Select all
- thecosmicgate
sure i already did
Scooter ;)
Scooter ;)
moengiant
I have the Nest - e. Will that work?Madgeni wrote: Wednesday 10 January 2018 10:47 Hi -
does anyone using my app have a NEST thermostat? The Google testers are using a Nest integrated into a Domoticz for testing, but weirdly, it's not allowing queries, which is weird, as i do no special formatting of request/response - so a request of a dummy thermostat works, but of Nest, it doesn't work
I'd rather have a bottle in front of me than a frontal lobotomy
Madgeni
it's ok, worked through it - thanks for the assistance. The downside of the Nest implementation in Domoticz, which splits the different functions into different devices is that you can set and query Nest, but not 'increment/decrement'
Fred78
I managed to integrate my domoticz installation with Google Assistant by using IFTTT, and it works fine.
I'm trying to setup Controlicz, but I can't figure out how to us it. I don't have an Google Home speaker at home. Today I'm using my phone with Google Assistant installed.
Is there a way to use Google Assistant -> Controlicz -> Domoticz with only a phone with GA ?
Thanks in advance for your help.
Fred
Fred
Madgeni
hi, i only use GA, so works fine. whats the issue?
