AND function kills script
R0yk3
Post by R0yk3 »
this script does not work like i want it to:
		devices = {
			'Telefoon_Jeanine',
			'Telefoon_Roy',
			'ZonOnder'
        if ((device.name == 'Telefoon_Jeanine' and device.state == 'On') or
            (device.name == 'Telefoon_Roy' and device.state == 'On') and
            (device.name == 'ZonOnder' and device.state == 'On')) then
	    domoticz.devices('Tuin').switchOn()
What i want is:
The light 'tuin' is turned on when:
'Telefoon_Jeanine', is on
or
'Telefoon_Roy', is on
and
'ZonOnder' is on
Al three are switches. Without the ZonOnder it works.
I replaced ZondOnder also by
timer = {
            'at nighttime''
But at nighttime does not work, or while testing at daytime.
I'm Using the latest beta Version: 3.8807
Raspberry PI 3, raspbian, ZwaveMe, RFLink
Re: AND function kills script
Maybe this can help you ?
active = true,
on = { devices = { ['Telefoon*'] = {'at nighttime'} 	}   },
execute = function(domoticz,Telefoon)
	if Telefoon.state == 'On' then
R0yk3
Post by R0yk3 »
Thank You!! This works for turning the lights on.
But, i also want the lights to turn off if we leave the house.
Now i added this
	    domoticz.devices('Tuin').switchOff()
But now the light does turn off if only 1 phone leaves the house?
How about ? [Edit]
	active = true,
		devices = { ['Telefoon*'] = {'at nighttime'}	,
                timer = { 'at sunrise', 'at sunset'}
execute = function(domoticz,Telefoon,TriggerInfo)
    if TriggerInfo.trigger == "at sunrise" then
    elseif TriggerInfo.trigger == "at sunset" then
        if domoticz.devices("Telefoon_Jeanine").state == "On" or domoticz.devices("Telefoon_Roy").state == "On" then
        elseif domoticz.devices("Telefoon_Jeanine").state == "Off" and domoticz.devices("Telefoon_Roy").state == "Off" then
R0yk3
Post by R0yk3 »
Thankyou, I wil try this tonight.
Just for me to learn as i think i understand the script.
{'at nighttime'} is a device????
and what is the difference between the red parts in the script:
I use spoiler so i can use colors
Loads of other questions because just starting with the dzvents.. Until now just copy paste scripts, so i would like to know what i did wrong in my version of the script.
R0yk3
Post by R0yk3 »
It works perfect!!!! Thank you.
:D :D :D
Maybe you found out already but to clarify:
devices = { ['Telefoon*'] = {'at nighttime'} -- Trigger script on any change to devices with a name starting with Telefoon but only at nighttime
Telefoon.state == 'On' then -- Check if state of (the single) device that triggered the script is 'On'
-- Only true if both phone states are "Off"
R0yk3
Post by R0yk3 »
Waaren, Thank you!!
Luuc_a
Post by Luuc_a »
I do some thing similar to your needs. I have edited the code I used to your needs
		devices = {
			'Telefoon*'
		local home = false
		--Look in Domoticz for each device started with Telefoon. If a device has the status on, then set local var "Home" to True
		domoticz.devices().forEach(function(device)
            if string.find(device.name,'Telefoon') then
                if (device.state == 'On') then
                     home=true
        end )
        if home==false then
            domoticz.log('Nobody home' .. device.name, domoticz.LOG_INFO)
            domoticz.devices('Tuinverlichting').switchOff().checkfirst()
            domoticz.log('Somebody home' .. device.name, domoticz.LOG_INFO)
            domoticz.devices('Tuinverlichting').switchOn().checkfirst()
		domoticz.log('Device ' .. device.name .. ' was changed', domoticz.LOG_INFO)
Every device had the name "Telefoon....." and the script is triggerd by that device. In the for each loop you check if one of the devices with that name is "On". If there is another device is On the "Tuinverlichting" will stay on.
Maybe you can use this and edit to your needs.
Edit/
The only thing I don't have is the check for nighttime.
R0yk3
Post by R0yk3 »
Thankyou. This helpes me learn the language.
