Timer question
Mozart
Timer question
Post by Mozart »
Hi, I created the following timer:
		timer = {
			'10 minutes before sunset',
			'at nighttime at 6:00 at mon,tue,wed,thu,fri',
This works fine except for the second timer, that works fine during the week but it also triggers on saturday and sunday :(
Is there something I'm doing wrong or is this a bug?
Raspberry 3
Aeon Labs Z-Wave Stick Series 2 - RFLink USB Gateway
Z-Wave switches
433 MHz Temperature + Humidity sensors
Philips Hue Lights
Mi-Light WiFi Bridge + RGBW Controllers
Re: Timer question
Hi Mozart,
change 'at nighttime at 6:00 at mon,tue,wed,thu,fri', to 'at nighttime at 6:00 on mon,tue,wed,thu,fri'
Mozart
Re: Timer question
Post by Mozart »
waaren wrote: Thursday 11 January 2018 9:32 Hi Mozart,
Thanks, changed it and hopefully it was that easy :)
I'll check this weekend...
Raspberry 3
Z-Wave switches
Philips Hue Lights
dannybloe
Re: Timer question
Post by dannybloe »
So, why use both 'at nighttime' and 'at 6:00'? This will only be true if sunrise is on or after 6:00 as nighttime is defined as the period between sunset and sunrise. Unless that's your intention of course :)
Mozart
Re: Timer question
Post by Mozart »
dannybloe wrote: Thursday 11 January 2018 13:50 So, why use both 'at nighttime' and 'at 6:00'? This will only be true if sunrise is on or after 6:00 as nighttime is defined as the period between sunset and sunrise. Unless that's your intention of course :)
It is my intention 😀
I want my garden lights on when I get up but only if it is still dark outside and I thought that this was a nice solution.
Raspberry 3
Z-Wave switches
Philips Hue Lights
Mozart
Re: Timer question
Post by Mozart »
With the change proposed here my timer works the way I want it!
Raspberry 3
Z-Wave switches
Philips Hue Lights
dannybloe
Re: Timer question
Post by dannybloe »
Good! Then my algorithms work!
