Wrong lua version after upgrade
McMelloW
Domoticz version: V2024.1
Post by McMelloW »
After install lua 5.3.4 lua-v still shows: Lua 5.1.5 Copyright (C) 1994-2012 Lua.org, PUC-Rio
lua is installed faccording these line
sudo curl -R -O http://www.lua.org/ftp/lua-5.3.4.tar.gz
sudo tar zxf lua-5.3.4.tar.gz
cd lua-5.3.4
sudo make linux test
How can I tell the system lua is at 5.3.4?
Greetings McMelloW
SweetPants
Re: Wrong lua version after upgrade
Post by SweetPants »
Have you tried sudo make install or sudo make linux install?
McMelloW
Post by McMelloW »
SweetPants wrote: Wednesday 10 January 2018 18:01 Have you tried sudo make install or sudo make linux install?
Greetings McMelloW
Siewert308SW
Domoticz version: Stable
Post by Siewert308SW »
That doesn't work as far as i know.
Lua is integrated in Domoticz it self and installing/compiling it your self doesn't work.
The only way to get it updated is to build Domoticz from source with the updated LUA source.
Been there 2 years ago but as we speak i'm running and testing LUA 5.3.4
Compiled it into Domoticz this afternoon and runs fine sofar.
I know Gizmocuz tried to update LUA somewhere February 2016.
But something wasn't right and he reverted back to 5.2.
For now i run 5.3.4 and if i don't encounter any issue i can try to make a pull request and get in the latest beta.
Setup:
- DS923+ Docker
Domoticz Latest Stable
Mosquitto / ZwaveJSUI @ Aeotec Z-Stick Gen5+ / PiHole Unbound
P1 USB Gas/Power, HW watermeter
- A lot of Zwave switches, contacts, plugs, smoke/Co2 ect
- DiY 7.5kWh Solar Storage @ GitHuB
