bycho
hi,
when I ask for temperature I get response with temperature and status off. what this 'off' is about? Alexa was saying just temp.
is there a chance to ask for humidity or other sensor type value?
Piotr
Piotr
axelbaas
Hi There.! Seems to be a good alternative for Apple Homekit, isn't it? Can you please add me to the beta testers group? a***@ax****as.nl
matzeb74
- Domoticz version: newest
now my system is reachable via Controlicz, i´ve created Roomplans and i´m also registered to Controlicz. My Emailadress is matze***@**ail.com.
Please add me to the test, thanks.
Madgeni
Hi, this the bane of my live. There's no logic behind this, I pass an online state, which it totally ignores. Even more frustratingly, if i remove that online state, it doesn't work at all..bycho wrote: Tuesday 09 January 2018 11:47 hi,
Piotr
I've raised it with Google
n1c0l45
- Domoticz version: V3.4834
Hi Madgeni,
Thanks for your work! i'll like to try, is it possible to join the tester's group?
I'm registered on controlicz website, my email is [email protected]
Many thanks
Many thanks
n1c0l45
hi Madgeni, thanks, i receved the link
but i get a "There was an error completing your request " and i can't go anyfurther?
any ideas?
thanks
any ideas?
thanks
n1c0l45
I may have find why, the gmail adress i used what not my GA account. I have changed it [email protected]
do i need a new 'invitation' ? i have changed the email in the controlicz account but it doesn't seems to work?
can i ask you anorher link?
thanks
thanks
moengiant
A little new to the google home - I have signed up and the connection is good, other than that what do I need to do in order to use google home device.
Running
Domoticz - rooms set up with devices
Z-wave
Milights
Nest
X10
Kodi
LMS
HD Homerun
3 - Google home mini's
Running
Z-wave
Milights
Nest
X10
Kodi
LMS
HD Homerun
I'd rather have a bottle in front of me than a frontal lobotomy
- Rayn
- Domoticz version: 3.8153
Hi Madgeni,
As many have said before : thanks for your work!
Can I please join the tester's group ?
I registered on controlicz today, my email is ra***[email protected]
TY
TY
Madgeni
Hi - I need your email address to add you to the beta - either PM, or give me some idea of what it is (see other examples in this thread)moengiant wrote: Tuesday 09 January 2018 19:45 A little new to the google home - I have signed up and the connection is good, other than that what do I need to do in order to use google home device.
Running
Z-wave
Milights
Nest
X10
Kodi
LMS
HD Homerun
Spectralparty
Hi, I would like to participate in the test as well. I've registered today. My email address is le****tkn****[email protected]
matzeb74
@Madgeni
I now tried it all. Everything works fine for me. I can switch all my Sockets i have in domoticz via Google Home. Is there anywhere a list which Commands works with Controlicz? I think ive seen anywhere.
Madgeni
Hi - there's no definitive list provided by Google. as soon as one is published, i'll update the FAQs
- gijsje
- Domoticz version: Stable
Here is a list what you can ask
https://assistant.google.com/explore/
Synology DS218+ - RFXtrx433 - Aeotec Z-Stick Gen5 - Toon Thermostat - Neo CoolCam plug - Neo CoolCam PIR - FIBARO PIR - Heiman Smart Smoke Senso - Neo CoolCam Leakage Detector - BeNext Tag Reader - P1 and S0 USB - many Mi-Light lights - KAKU switches
mraichura
Hey Nick,
Any update on Sync Devices error?
Mayank
Mayank
1 x RASPBERRY PI 1 MODEL B+ running Domoticz since June 2016
1 x RASPBERRY PI 3 MODEL B running Domtoicz since August 2017
Madgeni
Hi -
does anyone using my app have a NEST thermostat? The Google testers are using a Nest integrated into a Domoticz for testing, but weirdly, it's not allowing queries, which is weird, as i do no special formatting of request/response - so a request of a dummy thermostat works, but of Nest, it doesn't work
Madgeni
hey - weird as it's working for me. I know you've made some changes your side, I wonder if that's changing domoticz API call behaviour..I'll take a look when I canmraichura wrote: Wednesday 10 January 2018 10:40 Hey Nick,
Mayank
alanlsmith
- Domoticz version: Latest β
Although useful, this is just a list of the 'skills' that are available for Google Home and some examples of commands for each of them, almost all a specific to a type of hardware and most require the format "Ask <skillname> to switch on something".gijsje wrote: Wednesday 10 January 2018 7:43 Here is a list what you can askx
I think that what madgeni was referring to was a list of generic home control commands and terms that the Google assistant can handle / recognise.
Domoticz Latest β, RPi 4B with 110Gb SSD for Domoticz, RPi 4B with 110Gb SSD for Node-Red & a RPi 2B for logging / IP addressing. RFXCOM, PiZiGate, Z-Wave, Harmony, Hue lamps and a bit of Broadlink.
alanlsmith
This is also working for me, for the first time. Previously I always got an error and had to unlink and relink to Controlicz after adding devices. So this is much easier now.Madgeni wrote: Wednesday 10 January 2018 10:48hey - weird as it's working for me. I know you've made some changes your side, I wonder if that's changing domoticz API call behaviour..I'll take a look when I canmraichura wrote: Wednesday 10 January 2018 10:40 Hey Nick,
Mayank![]()
alanlsmith
I haven't got a Nest and I don't know if this is of any help but if I query a dummy temperature sensor I consistently get a different reply than the one I get for a real temperature sensor. ( Just different wording ).Madgeni wrote: Wednesday 10 January 2018 10:47 Hi -
Both still say that it is 'off' though. Could this be because Google thinks that it's querying a thermostat of control rather than a simple sensor.
