Using a variable as a setpoint?
freakshock
Post by freakshock »
I would like to use a Domoticz uservariable as a setpoint for my thermostat.
I can't seem to find the correct syntax for this in the wiki.
Right now my thermostat always changes to the same hardcoded value:
domoticz.devices('Thermostat').updateSetPoint(17)
But I would like it to change to whatever is in the uservariable 'Nighttemp'.
Can anyone help me with the correct syntax for dzVents?
dannybloe
Re: Using a variable as a setpoint?
Post by dannybloe »
		variables = { 'MySetpointVar' } -- integer variable
	execute = function(domoticz, variable)
		domoticz.devices('Thermostat').updateSetPoint(variable.value)
This script will make sure that whenever you edit the variable in the GUI, the setpoint is updated.
freakshock
Thanks for your suggestion Danny, your script works for when I want the change in the variable to directly change the setpoint.
However, I want to be able to choose the setpoint for the coming night, when my domoticz goes into 'sleep mode'.
Is this also possible?
dannybloe
Post by dannybloe »
I don't know what you mean with 'sleep mode'.
JuanUil
Domoticz version: 4.11083
Post by JuanUil »
I am using this in my ICY Thermostat.
-- Temperatuur instellingen
dagtemperatuur   = uservariables["dagtemperatuur"]
nachttemperatuur = uservariables["nachttemperatuur"]
vorstbeveiliging = uservariables["vorstbeveiliging"]
-- Dagtemperatuur instellen voor werkdagen en weekend
	if (werkweek and dag ~= 'Sun'and uur==7 and min>=0 and min<2 and setpoint<dagtemperatuur) then
		setpoint=dagtemperatuur
		set = "6|0|" .. setpoint
		commandArray ['UpdateDevice']= '6|0|' .. setpoint
	elseif ((weekend or dag=='Sun')and uur==8 and min>=0 and min<2 and setpoint<dagtemperatuur) then
CeesCKS
Domoticz version: 4.11474
Post by CeesCKS »
Did you consider to use the "Timers" option from the Thermostat device to change the setpoint value at a given time stamp without programming any code.
Cees
Cees
freakshock
@ Danny,
Sleep mode is just a simple dummy switch I use to switch off my devices for the night, and also to lower the thermostat setpoint.
What I want to be able to do in this case, is to set a variable setpoint, so I can choose the setpoint setting for the coming night in advance.
This is part of my current script for my 'sleep mode':
		devices = {
			'Sleepmode'},
	execute = function(domoticz)
		if (domoticz.devices('Sleepmode').state == 'On' then
		    domoticz.devices('LivingRoomLight').switchOff()
		    domoticz.devices('Thermostaat').updateSetPoint(17) --[b] I want to set this to a uservariable 'Night_temp[/b]'
How would that look like in dzVents code? Thanks for your patience !
dannybloe
Post by dannybloe »
Then it's probably something like this:
		devices = { 'Sleepmode' },
			local nightTimeSetpoint = domoticz.variables('Night_temp').value
		   	domoticz.devices('Thermostaat').updateSetPoint(nightTimeSetpoint)
freakshock
Great that works! Thanks Danny :D
