Alexa, Google Home and Siri
boris91530
Domoticz version: v3.8153
Post by boris91530 »
Merci
boris91530
Bonsoir savez vous si il est possible de changer le type d appareil car mon gh détecte mes volets comme simple lampe
Madgeni
Post by Madgeni »
dans Domoticz, changez l'image a 'Generic'.
boris91530
La commande "ferme" les volets ouvre et vice versa
0n370uch
Domoticz version: Latest
Post by 0n370uch »
Can you add me to the Google home beta program please. I'm already registered and the connection is successful.
fa****.br****@gmail.com
Seidel
Post by Seidel »
Can you add me to the test program ?
mister*****@gmail.com
Thanks !
bycho
Post by bycho »
Madgeni,
I switched from Alexa to GH and as others I would like to try adding Domoticz there.
please let me know how to - user bych...4 @ well known google mail :)
thanks!
andi216
Domoticz version: 3.7243
Post by andi216 »
Hello madegeni
Can you add me to the test program ? [email protected]
thanks !!
mraichura
Domoticz version: 3.8153
Post by mraichura »
Hi, the "Sync Devices" command is failing with a non-descript error.
1 x RASPBERRY PI 1 MODEL B+ running Domoticz since June 2016
1 x RASPBERRY PI 3 MODEL B running Domtoicz since August 2017
0n370uch
Post by 0n370uch »
everything works really nice after a bit trouble with the Google room managment... If someone run into the same problem (cannot add a device to a room): just delete the room and add the room again.
One question: Is it possible to add another account to the "Actions on Google" list without creating a new Controlicz account (same Domoticz server)?
Thanks for this nice API. Much faster and smarter than IFTTT :-).
Greetings Fabi
Tyturion
Post by Tyturion »
Madgeni wrote: Sunday 07 January 2018 20:34
Tyturion wrote: Sunday 07 January 2018 19:44
Madgeni wrote: Saturday 06 January 2018 10:07 ok, and can someone try 'white' now?
You are the man! Work well with the word "white".
I made a funny observation though: I control all devices in German, but for this particular command it only accepts the color in English.
Would you have an idea why that is?
Thanks a lot for all the efforts you put into this.
Best,
Thomas
Ahaha that would be because I hard coded it to route white through colour, rather than Kelvin. I'm rather ashamed of the hardcoding, but some times you have to. Will add weiß also - update - try now?
Hi again,
Thanks for that, but still doesn't work. 😀
Cheers,
Thomas
matzeb74
Domoticz version: newest
Post by matzeb74 »
Im also new to Domoticz and wanna try controlic. Im already registered to controlic but it say it can not connect. If i Try the host and port in Browser i reach my domotic.
Where is my error.
My mail by controlic is mat***74@gmail****.
Gesendet von meinem SM-G935F mit Tapatalk
0n370uch
Post by 0n370uch »
matzeb74 wrote: Monday 08 January 2018 19:33 Im also new to Domoticz and wanna try controlic. Im already registered to controlic but it say it can not connect. If i Try the host and port in Browser i reach my domotic.
Where is my error.
Hi, some ideas from my side:
- wrong username
- wrong user password
- no https
- user without permissions
jeromehettich
Post by jeromehettich »
Thank you for the great work - I have been using with amazon alexa for a while now,
could you add me to the google home test please?
firstname (below) @ hettich.org.uk
which should work with google, but if that fails
firstname dot hettich @ gmail
many thanks,
Jerome
basphilippus
Post by basphilippus »
Hi Madgeni,
I can't see Controlicz in my Google Home devices. I've registered on the controlicz website a while ago and I can connect to my Domoticz from there. Do you have any idea what is going wrong here? My email is bas.philippus @ gmail
Kind regards,
Bas Philippus
matzeb74
Post by matzeb74 »
[quote/]
- wrong username
- no https
- user without permissions[/quote]
Hi. Thx. Does it only work with https?
0n370uch
Post by 0n370uch »
matzeb74 wrote: Tuesday 09 January 2018 6:12
[quote/]
Hi, yeah only Https works. Check here:
https://www.controlicz.com/faq
Grüße ;)
Madgeni
Post by Madgeni »
basphilippus wrote: Tuesday 09 January 2018 0:05 Hi Madgeni,
Kind regards,
Bas Philippus
Hi - as it's still a beta, you have to be invited - you have mail :)
yanael
Post by yanael »
Hi works very very well
Envoyé de mon MI NOTE LTE en utilisant Tapatalk
Madgeni
Post by Madgeni »
Tyturion wrote: Monday 08 January 2018 19:23 Hi again,
Cheers,
Thomas
so it doesn't, although i have no idea why not! I'll look at it but it *should* just work :(
