I recently bought a RFX433 and came across Domoticz when looking for a nice UI to control devices in my home. First of all, I am not sure where this topic should belong to, Github issues or topic in some subforum here, so I'm really sorry if this is not the right place to post.
I wanted to pair some EMW100 power plugs (basic On/Off 433.92MHz power plug, supported out of the box by the RFX433). I tried quite a lot of things before actually coming across https://www.domoticz.com/forum/viewtopi ... 5&p=165110 and getting some extra infos on the way to pair a power plug with the RFX433.
Actually, I should have expected to be able to go into the "Add light manually" panel, fill-in fields and press "Test" button and get the plug associated. But it seems the "Test" button actually sends an "On" command, whereas it should send a "Group off" command in order to pair the RFX433 and the power plug.
I could not find any place in Domoticz to send a "Group off" command and had to resort to running RfxMngr. I may have missed something, but is this any kind of planned feature to be able to do all of this from within Domoticz directly?
Pairing power plugs (EMW100)
- Teknor
- Domoticz version: 3.48
Re: Pairing power plugs (EMW100)
Dont think they are compatible with Rfxcom.
Raspberry Pi 3 | EasyESP NodeMCU v3 | RFXTRX433e | Mysensors NRF24L01 | MotionEYE | PikrellCam
It might not be clear from my first post, but they *are* indeed compatible with RfxCom, I managed to control them from RfxMngr app.
