[Plugin now available in Beta] Help with Yeelight Bulb
superczar
Re: [Plugin now available in Beta] Help with Yeelight Bulb
Post by superczar »
Isn't the value for otherdevices_svalues numeric?
In any case, the code is practically as -is from the wiki
corbin
Post by corbin »
see what value is returning for DomValue with "print(DomValue)":
DomDevice = 'White Temp Yeelight';
IP = '192.168.5.14';
PORT = '55443'
if devicechanged[DomDevice] then
   if(devicechanged[DomDevice]=='Off') then
     DomValue = 0;
     runcommandoff = "sudo echo -ne '{\"id\":1,\"method\":\"set_power\", \"params\":[\"off\", \"smooth\", 500]}\\r\\n' | nc -w1 " ..IP.." " ..PORT.."";;
     os.execute(runcommandoff);
     DomValue = otherdevices_svalues[DomDevice];
     print(DomValue)
   CalcValue = ((DomValue-1) * 48)+1700;
   if CalcValue==nil then CalcValue=0 end
     runcommand = " sudo echo -ne '{\"id\":1, \"method\":\"set_scene\",\"params\":[\"ct\"," .. CalcValue .. ", 75]}\\r\\n' | nc -w1 " ..IP.." " ..PORT.."";
   os.execute(runcommand);
   print(runcommand)
   print("Color Temp= "..CalcValue);
Westcott
Post by Westcott »
Perhaps it should be -
DomValue = tonumber(otherdevices_svalues[DomDevice])
superczar
Post by superczar »
@westcott - Making the change you suggested eliminated the string vs number error
However the dimmer for white temperature control still doesn't work (as in the dimmer is set at 0% and cannot be moved)
Here is the code from the wiki
DomDevice = 'nameofyourdummyselectorsetasdimmer';
IP = 'youryeelightip';
PORT = '55443'
     DomValue = 0;
   print(runcommand)
(have obviously changed the DomDevice Name and bulb IP)
Any idea what could be wrong
airmarshall
Post by airmarshall »
superczar wrote:@westcott - Making the change you suggested eliminated the string vs number error
PORT = '55443'
     DomValue = 0;
   print(runcommand)
Domoticz does not support dimming for X10 switches.
Create a switch from the hardware/dummy page, edit this switch, make it a dimmer
This allowed me to add a working dimmer slider, however I'm still having an issue setting the "TempValue", still researching but will post back here if I need my own help (which is likely, as I'm an idiot!)
airmarshall
If it's of use to anyone I managed to fix my issue, which was eventually everything seemingly working with the wiki scripts yet nothing actually happening on the bulb.
I had to remove 'sudo' from the commands, hence:
runcommandoff = "echo -ne '{\"id\":1,\"method\":\"set_power\", \"params\":[\"off\", \"smooth\", 500]}\\r\\n' | nc -w1 " ..IP.." " ..PORT.."";;
Probably OS specific, I'm running domoticz through a docker on an unraid server.
IS there anyway I can check/test the polling is working? If I switch the light off with the Temp Slider switch OR the Dimmer Switch, the other switch and the RGB Switch never update to being OFF etc....??
Ariz
Target OS: OS X
Post by Ariz »
Have you set on the lamp app developer mode?
Inviato da Tapatalk
gclub
chrispazz
Post by chrispazz »
Hello. I am havign status update problems too.
If I switch lamp ON or OFF with domoticz, the status if updated correctly.
If I switch the lamp off using the main power switch on the wall, the domoticz status remain ON.
How can I have the domoticz status to reflect the power status?
madrian
Post by madrian »
I have same question as chrispazz. It is possible to update bulb state if I do a manual (hardware) power cycle?
Second question is: the script from the Wiki is not working right: this script turn Bulb OFF if you set the dimmer to 0% or click on OFF --> this is not working. Is there a fix for this?
madrian
Post by madrian »
Running manually OFF command:
$ sudo echo -ne '{\"id\":1,\"method\":\"set_power\", \"params\":[\"off\", \"smooth\", 500]}\\r\\n' | nc -w1 192.168.1.82 55443
does nothing. Maybe the api was changed?
Max5962
Post by Max5962 »
This issues still exist !
There is a githup to report it ?
All we need is to mark the bulb as off if it was power off by the wall switch :) thanks
joys
Post by joys »
Hi, I have the same problem. If I switch off from the electric wall switch, the Domoticz report the yeelight is On. Also, if I first switch off yeelight from Domoticz and some second later I switch off wall switch, after few second Domoticz set yeelight to On state.
I explain my scenario better. On the same line, controlled by a wall switch, I have both normal and yeelight bulbs. Actually the wall switch can also be controlled by Domoticz (I've created a switch dummy that runs on / off scripts when triggered). with blocky I created an event that when the wall switch goes off, the two Yeelight lamps are put in off and then the off wall switch script is executed. I entered a delay of 5 seconds in the off script that turns off the line.
madrian
Post by madrian »
Anyone?
Max5962
Post by Max5962 »
With that bugs the plugins is almost useless for read-only users : for the moment I using it in order to know if I forgot to power off lights :)
Please if the bulb is offline, set the value to OFF :)
corbin
Post by corbin »
anyone volunteer to make the changes to the code?
joys
Post by joys »
I found a workaround for my experience. I have set a sleep time of 120sec to my switch off scrip for wall switch relay. So when I switch off the relay from Domoticz, the blocky events power off Yeelight, Domoticz acquire off status of yeelight (thake about 90sec to do it) and finally the line go off.
Max5962
Post by Max5962 »
Thanks for the workaround, but not usefull for me : "read only" (no wall switch connected to domoticz).
Derik
Post by Derik »
Dear All.
Is there perhaps someone that have the "new" app working from the yeelight bulb?
In the old app new how to set the bulb in developermode..
Only i cannot fin this in the new app...
Hope there is some one smarter then myself:-)
thanks
Max5962
Post by Max5962 »
I'm developing a lua script in order to update Yeelight device as OFF if there do not respond to ping twice.
EDIT my script works. but if i power on my yeelight ( with wall switch or by the yeelight app ) the state is not updated in the app :(
any one avec the same issues ?
by the way i'm using docker
Boredcat
Domoticz version: 3.9639
Post by Boredcat »
Derik wrote: Thursday 04 January 2018 11:53 Dear All.
thanks
How to go developermode in the Yeelight app.
Select the light
In the right down corner (Ios App) there is a triangle with a line below, select that.
The you see LAN Beheer (With be named differently in the English app)
Select that and you can enable/dsiable develop mode
RFXCom(E) - Yeelight Lights - KaKu / Alexa HA Bridge
Windows 2012 / Windows 2012R2 / Xpenology/ Pi 3 / Milight / Home build ESP8266 / Sonoff
