Plugin - Homewizard
- Sjonnie2017
- Domoticz version: Latest ß
Re: Plugin - Homewizard
Impressive! Kudos! Will give it a try.
Greetz,
Sjonnie
EDIT: I can confirm this works. I now have 4 security devices; one for each water sensor.
Greetz,
Sjonnie
YouLess Energy meter
- gijsje
- Domoticz version: Stable
I was also able to work around that the heatlink is not working with this script
Made a selector swith and then used an url to change the temp
http://192.168.0.xxx/<password>/hl/0/settarget/15
Synology DS218+ - RFXtrx433 - Aeotec Z-Stick Gen5 - Toon Thermostat - Neo CoolCam plug - Neo CoolCam PIR - FIBARO PIR - Heiman Smart Smoke Senso - Neo CoolCam Leakage Detector - BeNext Tag Reader - P1 and S0 USB - many Mi-Light lights - KAKU switches
- Sjonnie2017
Gosh! You're good
Kudos!
Added the virtual switch to my config. Only have to wait to test once my HeatLink is operational again
Greetz,
Sjonnie
Greetz,
Sjonnie
i got this device from flamingoWobbles wrote: ↑Monday 27 February 2017 20:24 Hi all,
I started using Domoticz over a year ago, before that I was using homewizard as my domotica system. Since I discovered Domoticz I switched to using that but still have some hardware connected to my homewizard which I cannot move to domoticz. For this reason I have written a simple Python plugin (also my fist python experience) to integrate the homewizard.
Please have a look at it, give me comments and/or give me comments about it![]()
Github: https://github.com/rvdvoorde/domoticz-homewizard
All comments, good and bad are welcome.
Keep in mind, for the plugin system to work you need to have the latest Domoticz Beta running!
for some reason its not working
i have the ip adress of the flamingo homewizard and i can reach itusing the homewizard lite app and this works but when i set that ip adres of it in domoticz and set the pasword to my homewizard account its failing to respond when i look at the log
- Sjonnie2017
I do not know of a Homewizard by Flamingo.
Is this the device you're having: http://www.homewizard.co.uk/discover.html
- Sjonnie2017
You bought the switch but not the Homewizard unit (either that or you posted the wrong link
) The unit you need is the one I posted earlier. That's the unit the plugin enables in Domoticz. Without the unit, Domoticz can't do much with the switch.
HTH
Greetz,
Sjonnie
HTH
Greetz,
Sjonnie
Smart Switch SH5-GW-T
- Sjonnie2017
Yes, you have already shown us what you bought. Thank you for that.
I will try to explain why this plug-in will not work with your switch. The HomeWizard plug-in (which this thread is about) communicates with the HomeWizard Hub (this one: http://www.homewizard.nl/homewizard-121.html) It will and cannot communicate with individual devices; no matter how smart they are.
So either you buy the hub ( a bit expensive for one switch) or write your own plug-in that communicates with the switch
HTH
Greetz,
Sjonnie
HTH
Greetz,
Sjonnie
- Target OS: -
I have tried to install this on my synology....
when i run the python script it states:
File "plugin.py", line 26, in <module>
import Domoticz
ImportError: No module named Domoticz
Any idea where my error is?
import Domoticz
- Sjonnie2017
Have a look at post #63. Maybe that will help. Had some trouble myself getting it to work on a Syno.mielclaessens wrote:I have tried to install this on my synology....
import Domoticz
HTH
Greetz,
Sjonnie
Verstuurd vanaf mijn YOGA Tablet 2-1050F met Tapatalk
- Target OS: -
It worked!Sjonnie2017 wrote: ↑Friday 22 December 2017 8:07Have a look at post #63. Maybe that will help. Had some trouble myself getting it to work on a Syno.mielclaessens wrote:I have tried to install this on my synology....
import Domoticz
HTH
Greetz,
Sjonnie
we followed your post several times and now it works! great!!!!
for the response data energy link there are several commands for reporting day and month values including the s1 and s2 input of the energylinks, maybe has someone a idea for implementation in the plugin?Wobbles wrote: ↑Monday 14 August 2017 21:01 I have updated the code to not update the device if it doesn't exist...
# Update energymeters (Wattcher) if ( len(Response["response"]["energymeters"]) != 0 ): try: en = Devices[self.en_id].sValue.split(";") en_0 = self.GetValue(Response["response"]["energymeters"][0], "po", "0") UpdateDevice(self.en_id, 0, str(en_0)+";"+str(en[1])) except: Domoticz.Error("Error on setting the Wattcher values!") Domoticz.Debug("Ended handle route /get-status")
Last data from EnergyLink:
http://<homewizard-ip>/<password>/el/get/0/telegram
response:
/KFM5KAIFA-METER
1-3:0.2.8(42) DSMR versie
0-0:1.0.0(180102172004W)
0-0:96.1.1(xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx) Meternummer Elektriciteit
1-0:1.8.1(005275.892*kWh) Meterstand Elektriciteit levering (T1/Laagtarief)
1-0:1.8.2(004269.272*kWh) Meterstand Elektriciteit levering (T2/Normaaltarief)
1-0:2.8.1(001272.702*kWh) Meterstand Elektriciteit teruglevering (T1/Laagtarief)
1-0:2.8.2(002764.975*kWh) Meterstand Elektriciteit teruglevering (T2/Normaaltarief)
0-0:96.14.0(0002) Actueel tarief Elektriciteit
1-0:1.7.0(02.142*kW) Actueel vermogen Electriciteit levering (+P)
1-0:2.7.0(00.000*kW) Actueel vermogen Electriciteit teruglevering (-P)
0-0:96.7.21(00005) Aantal onderbrekingen Elektriciteit
0-0:96.7.9(00004) Aantal lange onderbrekingen Elektriciteit
1-0:99.97.0(1)(0-0:96.7.19)(000101000001W)(2147483647*s) Lange onderbrekingen Elektriciteit logboek
1-0:32.32.0(00000) Aantal korte spanningsdalingen Elektriciteit in fase 1
1-0:32.36.0(00000) Aantal korte spanningsstijgingen Elektriciteit in fase 1
0-0:96.13.1()Bericht code
0-0:96.13.0()Bericht tekst
1-0:31.7.0(009*A) Instantane stroom Elektriciteit in fase 1
1-0:21.7.0(02.139*kW) Instantaan vermogen Elektriciteit levering (+P) in fase 1
1-0:22.7.0(00.000*kW) Instantaan vermogen Elektriciteit teruglevering (-P) in fase 1
0-1:24.1.0(003) Productsoort: 3 (Gas)
0-1:96.1.0(xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx) Meternummer Gas
0-1:24.2.1(180102160000W)(03901.221*m3) Meterstand Gas levering
!88F5 892.8
Meter readings: (Total power-consumption/production and Gas consumption)
http://<homewizard-ip>/<password>/el/get/0/readings
response:
{"status": "ok", "version": "3.38", "request": {"route": "/el" }, "response": [{"type":"electricity","tariff":1,"consumed":5275.892,"produced":1272.702}, {"type":"electricity","tariff":2,"consumed":4269.501,"produced":2764.975}, {"type":"gas","consumed":3901.221,"timestamp":1514930400}]}
Graph voor EnergyLink per dag:
http://<homewizard-ip>/<password>/el/graph/0/week
response in file week.json:
[{ "t": "2017-12-01 00:00", "u": 13.34, "a": 12.43, "s1": 381.00, "s2": 0.52, "g": 9.83}
, { "t": "2017-12-02 00:00", "u": 6.01, "a": 5.03, "s1": 59.00, "s2": 0.83, "g": 3.91}
, { "t": "2017-12-03 00:00", "u": 7.44, "a": 6.71, "s1": 124.00, "s2": 0.36, "g": 13.25}
, { "t": "2017-12-04 00:00", "u": 11.77, "a": 7.71, "s1": 224.00, "s2": 3.82, "g": 7.35}
, { "t": "2017-12-05 00:00", "u": 13.29, "a": 12.61, "s1": 169.00, "s2": 0.28, "g": 6.25}
, { "t": "2017-12-06 00:00", "u": 12.73, "a": 11.49, "s1": 260.00, "s2": 0.85, "g": 5.04}
, { "t": "2017-12-07 00:00", "u": 8.15, "a": 7.90, "s1": 118.00, "s2": 0.23, "g": 7.10}
, { "t": "2017-12-08 00:00", "u": 11.47, "a": 7.46, "s1": 255.00, "s2": 3.80, "g": 8.16}
, { "t": "2017-12-09 00:00", "u": 12.33, "a": 11.40, "s1": 176.00, "s2": 0.93, "g": 8.78}
, { "t": "2017-12-10 00:00", "u": 11.69, "a": 11.69, "s1": 317.00, "s2": 0.00, "g": 8.95}
, { "t": "2017-12-11 00:00", "u": 11.65, "a": 11.65, "s1": 218.00, "s2": 0.00, "g": 9.31}
, { "t": "2017-12-12 00:00", "u": 10.74, "a": 10.58, "s1": 153.00, "s2": 0.15, "g": 9.84}
, { "t": "2017-12-13 00:00", "u": 10.36, "a": 10.10, "s1": 159.00, "s2": 0.24, "g": 11.01}
, { "t": "2017-12-14 00:00", "u": 11.14, "a": 9.77, "s1": 134.00, "s2": 1.19, "g": 7.27}
, { "t": "2017-12-15 00:00", "u": 9.54, "a": 8.37, "s1": 218.00, "s2": 1.16, "g": 8.08}
, { "t": "2017-12-16 00:00", "u": 8.09, "a": 3.99, "s1": 90.00, "s2": 3.67, "g": 8.54}
, { "t": "2017-12-17 00:00", "u": 15.21, "a": 9.32, "s1": 351.00, "s2": 5.87, "g": 8.26}
, { "t": "2017-12-18 00:00", "u": 11.19, "a": 9.15, "s1": 191.00, "s2": 1.92, "g": 6.92}
, { "t": "2017-12-19 00:00", "u": 12.99, "a": 10.38, "s1": 154.00, "s2": 2.49, "g": 6.43}
, { "t": "2017-12-20 00:00", "u": 10.92, "a": 10.57, "s1": 265.00, "s2": 0.34, "g": 6.13}
, { "t": "2017-12-21 00:00", "u": 8.90, "a": 8.32, "s1": 220.00, "s2": 0.57, "g": 5.47}
, { "t": "2017-12-22 00:00", "u": 8.13, "a": 7.89, "s1": 109.00, "s2": 0.23, "g": 4.39}
, { "t": "2017-12-23 00:00", "u": 10.80, "a": 10.42, "s1": 228.00, "s2": 0.24, "g": 2.92}
, { "t": "2017-12-24 00:00", "u": 15.16, "a": 14.55, "s1": 292.00, "s2": 0.44, "g": 4.12}
, { "t": "2017-12-25 00:00", "u": 9.59, "a": 9.20, "s1": 198.00, "s2": 0.37, "g": 3.14}
, { "t": "2017-12-26 00:00", "u": 10.32, "a": 5.85, "s1": 209.00, "s2": 4.11, "g": 8.15}
, { "t": "2017-12-27 00:00", "u": 13.62, "a": 11.72, "s1": 365.00, "s2": 1.68, "g": 7.24}
, { "t": "2017-12-28 00:00", "u": 9.04, "a": 4.26, "s1": 190.00, "s2": 4.51, "g": 7.25}
, { "t": "2017-12-29 00:00", "u": 7.79, "a": 7.34, "s1": 177.00, "s2": 0.44, "g": 8.66}
, { "t": "2017-12-30 00:00", "u": 9.90, "a": 9.29, "s1": 195.00, "s2": 0.61, "g": 6.42}
, { "t": "2017-12-31 00:00", "u": 11.90, "a": 11.37, "s1": 327.00, "s2": 0.50, "g": 3.15}
, { "t": "2018-01-01 00:00", "u": 10.37, "a": 7.45, "s1": 247.00, "s2": 2.85, "g": 7.08}
, { "t": "2018-01-02 00:00", "u": 8.42, "a": 6.73, "s1": 218.00, "s2": 1.68, "g": 4.40}]}
Toelichting:
u=used(kWh), a=aggregate(kWh), s1=waterverbruik (ltr), s2=zonnepanelen(kWh),g=gas(m3)
Graph voor EnergyLink per maand
http://<homewizard-ip>/<password>/el/graph/0/year
response in file year.json:
[{ "t": "2017-01-01 00:00", "u": 354.56, "a": 227.14, "s1": -2738.00, "s2": 125.84, "g": 288.00}
, { "t": "2017-02-01 00:00", "u": 294.39, "a": 185.79, "s1": 12892.00, "s2": 107.03, "g": 180.09}
, { "t": "2017-03-01 00:00", "u": 306.63, "a": -9.91, "s1": 6905.00, "s2": 313.62, "g": 108.40}
, { "t": "2017-04-01 00:00", "u": 246.35, "a": -147.81, "s1": 5494.00, "s2": 385.30, "g": 71.26}
, { "t": "2017-05-01 00:00", "u": 250.60, "a": -177.46, "s1": 10615.00, "s2": 421.46, "g": 22.32}
, { "t": "2017-06-01 00:00", "u": 280.18, "a": -147.77, "s1": 7769.00, "s2": 419.56, "g": 7.38}
, { "t": "2017-07-01 00:00", "u": 256.64, "a": -139.01, "s1": 6077.00, "s2": 387.61, "g": 7.73}
, { "t": "2017-08-01 00:00", "u": 216.68, "a": -173.92, "s1": 4783.00, "s2": 379.51, "g": 5.48}
, { "t": "2017-09-01 00:00", "u": 261.86, "a": -42.30, "s1": 6256.00, "s2": 293.12, "g": 9.87}
, { "t": "2017-10-01 00:00", "u": 261.08, "a": 66.23, "s1": 5899.00, "s2": 187.35, "g": 35.27}
, { "t": "2017-11-01 00:00", "u": 275.32, "a": 163.70, "s1": 5934.00, "s2": 107.09, "g": 152.25}
, { "t": "2017-12-01 00:00", "u": 335.20, "a": 288.52, "s1": 6526.00, "s2": 42.35, "g": 221.32}
is er ook een optie om de 868mhz lampen toe te voegen:
waarde in get-sensor.json
{"id":5,"name":"Buitenlamp","type":"led2ch","status":"on","color":{"hue":155,"sat":0,"bri":25},"version":5.00,"favorite":"no"}
waarde in get-status.json
{"id":5,"type":"led2ch","status":"on","color":{"hue":155,"sat":0,"bri":25}}
{"id":5,"te":12.4,"hu":65,"favorite":"no"}
{"id":5,"status":"no","timestamp":"13:08"}
Sjonnie2017 wrote: ↑Thursday 03 August 2017 19:05 Hi All,
I'm a bit stuck getting this plugin to work. Maybe someone is able to help me?
I am trying to get the plugin.py to work on my Synology NAS and I can't seem to get it to work. I need the python script to connect to my HomeWizard. Some facts and figures:
I also tried to place the plugin in /usr/local/domoticz/plugins (even with 777 permissions) to no avail.
- NAS: Synology DS115
Installed application: Python 3 (not Python 2 or the python 2 plugin package (although I tried these as well))
Domoticz version: 3.8153-7 (package by @Jadahl)
Plugin located at: /usr/local/domoticz/var/plugins
Plugin permissions: 777 (rwx for all)
If I look in the installation log of Domoticz I don't really see anything that could cause the plugin not to load:
Please note that I have re-installed the software multiple times and rebooted the NAS after each re-install to make sure that there are no residual settings.
Second note is that I have the plugin working on a test machine running Ubuntu server 14.04.2. But I really need it to run on my Syno.
Any help greatly appreciated!
Greetz,
Sjonnie
Edit: Got it!I had to place the plugin in a subfolder at /usr/local/domoticz/var/plugins. In this case I chose HomeWizard. Stopped the package and restarted it. Et voilá! I could select HomeWizard as my hardware
HTH
Greetz,
Sjonnie
how can i place the plugin in a subfolder, can someone help me with that.
thanks john
he Guy's
before and comment comes, indeed i did not scroll trow the 5 page's full sorry...
the enerylink from homewizzard is that working good ?, and if so is there some steps to make it working ?
tnx
tnx
- Sjonnie2017
thanks john
You will need to ssh into the Syno and copy them manually. Use your regular admin account for ssh.
Good luck!
Greetz,
Sjonnie
I copy PLUGIN.PY into /usr/local/domoticz/var/plugins button in stil not see homwizard in domoticz.
- Sjonnie2017
Hi smaus,
Create a subfolder in /usr/local/domoticz/var/plugins and call it HomeWizard. Place the file there and restart domoticz.
HTH
Greetz,
Sjonnie
HTH
Greetz,
Sjonnie
- waaren
on my Synology the plugin.py for homewizard is in the /usr/local/domoticz/var/plugins/domoticz-homewizard directory.
after installing it, you need to restart domoticz. (Please note that not all precompiled domoticz executables fom Jadahl have python included)
Python should be installed and active in domoticz. You can check that as it should show something like
2018-01-27 00:33:56.536 PluginSystem: Started, Python version '3.5.1'.
2018-01-27 00:33:59.042 Python EventSystem: Initalizing event module.
in your domoticz logfile.
