Basic script. Where am I going wrong
digital
Domoticz version: 3.8153
Post by digital »
I am very new to scripting and learning as I go. What I am trying to achieve.......
When "Dusk Dawn Sensor" is On and "Hall Lamp Wall Switch" is Off switch "Hall Lamp Socket" On.
The script runs and shows no errors but the Hall Lamp Socket does not switch on and is not triggered in the script.
Where am I going wrong.
	active = true,
		devices = {
            'Hall Lamp Wall Switch',
            'Dusk Dawn Sensor',
            'Hall Lamp Socket'
       if ((device.name == 'Dusk Dawn Sensor' and device.state == 'On')
       and (device.name == 'Hall Lamp Wall Switch' and device.state == 'Off')) then
           domoticz.devices('Hall Lamp Socket').switchOn()
Last edited by dannybloe on Wednesday 03 January 2018 11:37, edited 1 time in total.
Reason: turned it into a code block
mosjonathan
Re: Basic script. Where am I going wrong
Post by mosjonathan »
i think it should be something like this:
active = true,
	devices = {
			'Test',
			'Dusk Dawn Sensor',
			'Hall Lamp Socket'
if domoticz.devices('Dusk Dawn Sensor') == 'On' and domoticz.devices('Hall Lamp Wall Switch') == 'Off' Then
emme
Domoticz version: latest
Post by emme »
the error is in the 2 conditions:
the table device (initialized in the statement function(domoticz, device)) contains the ONLY one device that triggered the script.
based on that, you cannot have 2 device.name different eachother, the condition is always FALSE
to do what you need the script should be:
active = true,
      devices = {
         'Dusk Dawn Sensor',
   if ((device.state == 'On')  then
      domoticz.devices('Hall Lamp Socket').switchOn().checkFirst()
      domoticz.devices('Hall Lamp Socket').switchOff().checkFirst()
I've added the else statement to switch off the light when the dusk sensor goes off ;)
the .checkFirst() function is used to avoid the condition in the if statement ( ...and domoticz.devices('Hall Lamp Socket').state == 'Off'): it does it for you
ciao
M
"We always done this way"
digital
Post by digital »
Thank you both.
I understand now what you are saying.
Thanks for your time and help
Users browsing this forum: Google [Bot] and 0 guests
