Alexa, Google Home and Siri
brakc
Post by brakc »
Madgeni wrote: Saturday 30 December 2017 16:34 can't see why not
OK thank you for your response Madgeni. Can you add me on beta controlicz please? I'm registered with [email protected].
Thank you,
Fabrice.
Madgeni
Post by Madgeni »
jaha wrote: Saturday 30 December 2017 16:42
Madgeni wrote: Saturday 30 December 2017 15:32 it does yep - 35.176.67.167
Great, does this service work with blinds? Could not find it on the faq page.
They aren't recognised as blinds, but you can "on/off" them.
brakc
Post by brakc »
brakc wrote: Saturday 30 December 2017 16:45
Thank you,
Fabrice.
I can't active Controlicz action to link to Google Home. My GH is in french (fr-FR), it's compatible?
Fabrice.
Madgeni
Post by Madgeni »
It is compatible - does the test connection work in controlicz?
brakc
Post by brakc »
Madgeni wrote: Saturday 30 December 2017 18:10 It is compatible - does the test connection work in controlicz?
Yes! "Controlicz can connect to your Domoticz!"
brakc
Post by brakc »
brakc wrote: Saturday 30 December 2017 18:18
I try in Google Assistant write (or say) sentense "talk to Controlicz" but, il return different web link
jaha
Post by jaha »
Madgeni wrote: Saturday 30 December 2017 16:48
It would be nice if you could add native support for them, so you can say close/open blind :)
brakc
Post by brakc »
brakc wrote: Saturday 30 December 2017 18:23
I try in Google Assistant write (or say) sentense "talk to Controlicz" but, il return different web link.
After tests, it's not possible to redirect on a secure account linking page. do you have one idea please?
HallezJB
Domoticz version: 3.486
Post by HallezJB »
Bonjour...
Je viens de m'enregistrer sur Controlicz sous [email protected]
Pouvez vous m'envoyer la demarche à suivre pour intégrer google home à Domoticz ?
(si j'ai bien saisie j'ai une mise à jour en version béta à faire...)
Merci beaucoup...
mark.sellwood
Post by mark.sellwood »
Hi, My Google Home has stopped connecting to my Domoticz, when I ask Google to sync devices i get "Sorry an error occurred syncing Controlicz" When I look at my firewall logs I don't see any incoming connections. If I go to https://www.controlicz.com login and click "Test connection to your Domoticz" this passes and I see an incoming connection on my firewall from an Amazon IP address.
Is something broken?
3 x Pi, 1 Master, 2 Slaves, 1x Aeotec Z-Stick S2, 4xSP103 PIR, 5xPowerNode 1, 1xSmart Energy Switch Gen5, 4xFGSS101 Smoke Sensor, 2xFGD212, 9xFGS212 , 7xFGS221/2, 1xAD142 , 1xTKB TZ68E , 2xAeotec Multi Sensor, 3 x NodOn CRC-3-1-00.
juju92
Post by juju92 »
Hi Madgeni,
I just created an account can you enable me ? (mail : [email protected])
Thks !
bluebit
Post by bluebit »
hi Madgeni,
fantastic work that you're doing!
I also registered on controlicz, could you enable my account as well for testing? ([email protected])
Hang on, changed the mail address to blue****************@gmail.com
thanks!!
bluebit
Post by bluebit »
just wondering, I registered at controlixz using a different gmail account then I normally use for google home...will that be an issue?
nevermind, I changed my mail adress in the profile on controlicz :)
Madgeni
Post by Madgeni »
brakc wrote: Saturday 30 December 2017 19:38
You don't need to say Talk to controlicz. Just say Turn on <device name>
Madgeni
Post by Madgeni »
jaha wrote: Saturday 30 December 2017 19:09
It would, but I can only use what Google gives me!
almanpt
Post by almanpt »
Hello!
Can you please add me to the test group?I have registered with Controlicz web page using mail address tmonep**[email protected]
Thank you
Skyteam
Post by Skyteam »
Hello Madgeni,
It's possible to test with Google Home...Can you add me on beta controlicz please? I'm registered with [email protected].
Thank you very much, and "bravo pour ton boulot" comme on dit en France
alanlsmith
Domoticz version: Latest β
Post by alanlsmith »
I have a couple of shortcuts in the Google Home app to translate saying 'open' and 'close' for my curtains to actioning 'on and 'off' in Domoticz and it works well. ( I'm using a simple motor/pulley mechanism in combination with Domoticz variables to control my curtains ).
Domoticz Latest β, RPi 4B with 110Gb SSD for Domoticz, RPi 4B with 110Gb SSD for Node-Red & a RPi 2B for logging / IP addressing. RFXCOM, PiZiGate, Z-Wave, Harmony, Hue lamps and a bit of Broadlink.
Madgeni
Post by Madgeni »
genius :)
Madgeni
Post by Madgeni »
Skyteam wrote: Sunday 31 December 2017 6:53 Hello Madgeni,
Fabrice.
Merci Fabrice! :)
