Can RFLink and RFXtrx433E be connected at the same time?
433Mhz opensource Receiver & Transmitter.
Bernd
Domoticz version: 2023.1
Post by Bernd »
I have a RPi 3 and RFXtrx433E up and running for 433.92 MHz equipment.
I am planning to add some Somfy blinds to my house, which work on 433.42 MHz.
In order to be able to receive the Somfy control signal all the time, I need a seperate receiver from the RFXtrx433E (which only transmits on 433.42), so I thought of RFLink 433.42. Of course I also transmit the commands for the Somfy by RFLink than.
Is it possible to have both the RFLink and RFXtrx connected to the RPi (running Domoticz) at the same time (simultanuous) and have the RFLink operating for the Somfy equipment only?
Thanks for the time you take to answer my question.
Raspberry Pi 4 2GB (RPi OS Light)
RFXCOM RFXtrx433E, firmware version = 1025
Re: Can RFLink and RFXtrx433E be connected at the same time?
Hi Bernd,
I have an RFLink and RFXtrx433E both connected and active on my RPI 3.
So yes it's possible
