IF Button is pressed on (even if on already) do somthing
Evelen
Domoticz version: 2.4538
Post by Evelen »
Hi.
I have these wall switches that can be set to "on" or "off".
Now I just have JSON inside the device on "response by on" and "response by off", but this just works if I want to change one device, since that is what JSON supports.
I want in LUA:
IF "Button is pressed on (even if on already)"
DO: somthing
how do I write this?
SweetPants
Re: IF Button is pressed on (even if on already) do somthing
Post by SweetPants »
Try a 'device' triggered dzVentz event like this
		devices = {
			'Button'
    logging = {
        level = domoticz.LOG_INFO,
        marker = "dz_Test"
		domoticz.log('Device ' .. device.name .. ' was triggered', domoticz.LOG_INFO)
It will be launced every time you push the button even if it is already in the selected state
Evelen
Post by Evelen »
SweetPants wrote: Saturday 30 December 2017 9:57 Try a 'device' triggered dzVentz event like this
		devices = {
			'Button'
    logging = {
        marker = "dz_Test"
Thanks, it works, changed the code a little:
		devices = {
			266
    --	   if (device.state == 'On') then
    --    	domoticz.log('It is On')
    --	   if (device.state == 'Off') then
    --       	domoticz.log('It is Off')
    --     end
This part it what is not working (if activated):
    --     end
It gives the following error:
2017-12-30 15:17:56.918 Error: dzVents: Error: error loading module 'test' from file '/home/pi/domoticz/scripts/dzVents/generated_scripts/test.lua':
...e/pi/domoticz/scripts/dzVents/generated_scripts/test.lua:18: unexpected symbol near '}'
Can't really se why
Try this:
		devices = {
			266
    	-- Added the missing end
	-- Should also give the desired result.
	domoticz.log('Device ' .. device.name .. ' state: ' .. device.state , domoticz.LOG_INFO)
SweetPants
you missed one 'end' as waaren said
Evelen
Post by Evelen »
It works :)
