How to manually add 433MHz Lighting4 switch with Pulse = 230usec
timsteeman
Domoticz version: 3.5877
Post by timsteeman »
Hello all,
I have an old set of Ranex RX 2582 switches (433,92MHz) and a remote.
Already discovered the below codes and Pulse timing. (230usec)
Via the "learn" mode the remote commands are not recognized.
I need to manually add these switches according to the below codes and a Pulse timing of 230usec.
How can I add a switch according to the specific settings?
(i found the Itho CVE RFT (also Lighting4) but that uses a diffreent pulse timing I'm afraid, tested and it won't work, different Pulse Timing?)
Manually adding these codes into RFXmngr works perfectly, but how to integrade them into Domoticz?
Example:
1 OFF = 3F 00 00 - (RFXcom 0011 1111 0000 0000 )
1 ON = 3F 00 C0 - (RFXcom 0011 1111 1100 0000 )
GCB2016
Domoticz version: V3.9208
Re: How to manually add 433MHz Lighting4 switch with Pulse = 230usec
Post by GCB2016 »
Hi Tim, did you ever find the answer to your question? I would appreciate a reply :) Thanks!
Nunox
Post by Nunox »
Hi Tim,
Same issue here. Any advice?
