Alexa, Google Home and Siri
Madgeni
Post by Madgeni »
windhoos wrote: Wednesday 27 December 2017 20:26 Hi there madgeni,
Thanx for adding me. Something really weird is happening however....
When i was configuring controlicz yesturday night it said everything was working when i tested the connection. Then all of a sudden i could not access the my.domoticz.com website anymore. I've tried multiple phones and laptops but the all could not connect, either in or out my home network. I guess the website is down? or has my account been blocked for some reason perhaps ? Do you have any idea ?
Edit: nope its down: http://downforeveryoneorjustme.com/my.domoticz.com
Since the website is down i also get the controlicz error when i test the connection. I however nonetheless tried to add controlics at my google home app. I could go into the link and enter my controlicz password. I was asked to give full access to controllicz, after i pressed agree i got a extra prompt for the controllicz login information (is it normal you need to log in 2 times?), then google went back to the device selection screen and gave me the prompt: sorry something went wrong, try again later.
I know you don't control my.domoticz.com but doesn't run all your traffic run trough their server? But if that is so, why does it seem that only I have problems connecting to my.domoticz.com? Souldn't more people have problem with controlicz?
a further question, when adding controllicz in my google home app, im told i need to give full access? Does this mean you can access my google drive and email and such ? Or am i understanding this wrong ?
Thank you in advance!
Hi -
i have nothing to do with my.domoticz.com, and controlicz doesn't use it.
Re: access - honestly no idea - I use the google assistant, and haven't had to specify anything. I certainly don't ask for, or require full access to your Google Home, so this sounds like a standard Google requirement - and no, i don't have access to your email or Drive!
windhoos
Post by windhoos »
Hi there, thanx for the fast reply.
So when i press test connection, i test the connection with my local raspberry pi rather than the my.domoticz server?
This was unclear to me in the description of the process. So if i dont make a connection with my.domoticz but rather my raspberry this means that i am the source of the problem. That is great news, it means i can fix it :-)
curious
Post by curious »
When I type "Talk to Controlicz" in the simulator the result is : Sorry, this action is not available in simulation
Same response when I use commands like switch garden light or something like that.
wimfabries
Post by wimfabries »
Hi Madgeni,
Could you please add me to the beta programm. I've registered under wim.fab*****@casema.nl
thanks for all the good work
Wim
torchit1
Post by torchit1 »
Good morning @mageni. I have changed my email to the Gmail account jesseste*****@gmail.com from my previous could you please re-invite me to the beta using this email. I believe this is the issue as to why it's saying "there was an error completing your request" when clicking the beta invite link.
evildonkey
Domoticz version: 3
Post by evildonkey »
@Madgeni ,
Ben working with it for a month now, And every thing is still working with no problems @ all. (11 Milight lights).
Good job!!!!
Domoticz v3 - Beta Channel @ Pi3 | Harmoney Hub | MiLight Ibox2 | Google Home (1) | Google Home Mini (3)
sirpokey
Post by sirpokey »
Hey. Can you add me? I registered on http://www.controlicz.com. Email address is [email protected]
doomastor
Post by doomastor »
Hi Madgeni,
I wish testing your google home integration. I've just regsistered to controlicz with this e-mail : [email protected]
Plz, can you add me to your beta tests ?
maxtrash
Post by maxtrash »
curious wrote: Wednesday 27 December 2017 21:44 When I type "Talk to Controlicz" in the simulator the result is : Sorry, this action is not available in simulation
I think I made the same mistake before. You don't need to do anything in the simulator. Just go the google home app on your phone, choose home control from the menu and press the + to add the home controlicz service.
curious
Post by curious »
maxtrash wrote: Thursday 28 December 2017 21:23
I tried that but nothing happened. The service is added allready and shows about 16 devices
Suppose I have a device called "garden light"
Should the command then be : Ok google 'Talk to controlicz switch on garden light ?
boris91530
Domoticz version: v3.8153
Post by boris91530 »
hi,
Can i joint to your test please i m realy interested by your work. my english is realy poor. i can't connect to mydomoticz and i don't know how to activate the ssl port on synology domoticz. does someone can help me please. I have alredy Makes mi inscription to controlicz under thé mail adresse :o[email protected]
thanks
Last edited by boris91530 on Friday 29 December 2017 6:56, edited 1 time in total.
00luke
Target OS: OS X
Post by 00luke »
Hi Madgeni, this looks great, thanks for all the work you're putting in to it. Can you add me to beta? I registered on http://www.controlicz.com. Email address is lukeand******@gmail.com. Thanks!
Madgeni
Post by Madgeni »
curious wrote: Thursday 28 December 2017 23:17
Hey - no you just say 'Ok Google turn on the garden light'
mpullens
Post by mpullens »
Someone encountered the same problem?
When I add controlicz in the assistant it states that it is succesfully added but it doesnt show up at the installed devices list. Conncetion between controlicz and Domoticz is up and running.
flav
Post by flav »
I have an issue when i ask google to synchronize my devices.
it say "an error happened when trying to sync the box Home controlicz"
Anyone else has it ?
P.S. it's in french
curious
Post by curious »
flav wrote: Friday 29 December 2017 14:09 I have an issue when i ask google to synchronize my devices.
P.S. it's in french
I get the same message (in English)
Madgeni
Post by Madgeni »
ok strange, it's working here - can anyone else confirm either way?
curious
Post by curious »
Madgeni wrote: Friday 29 December 2017 9:36
When I do that the answer is "I am sorry, there was an error why i am unabling controlling your home device" (or something like that)
Is there a way to check my settings are correct ? Because I cannot sync either.
I have checked that controlicz can connect, and I see my devices in Google home too.
Madgeni
Post by Madgeni »
curious wrote: Friday 29 December 2017 17:01
ok, am looking - can you try now?
JoshDinsdale
Post by JoshDinsdale »
Hi Madgeni
I have everything setup and mostly working, however controlicz doesn't seem to be grabbing some of my devices; I can't quite workout why. If I log into domoticz as the user account I can see all of the devices. One of the devices I can't see is a hue bulb, but I have other hue bulbs that are listed correctly. I've checked how these are setup and can't see anything different.
Any ideas?
Last edited by JoshDinsdale on Friday 29 December 2017 22:14, edited 1 time in total.
