I modified my script:
function turnOffHeating(domoticz)
local boiler = domoticz.devices('boiler')
local left_radiator = domoticz.devices('left_radiator')
local right_radiator = domoticz.devices('right_radiator')
boiler.switchOff()
left_radiator.switchOff().afterMin(3)
right_radiator.switchOff().afterMin(3)
function turnOnHeating(domoticz)
left_radiator.switchOn()
right_radiator.switchOn()
boiler.switchOn().afterMin(3)
active = true,
logging = {
level = domoticz.LOG_DEBUG,
marker = "HEATING_"
devices = {
'temp_hum',
'heating', -- alow heating
'thermostat'
timer = {
'every 1 minutes'
execute = function(domoticz)
-- Timer triggered use
if (triggerInfo.type == domoticz.EVENT_TYPE_TIMER) then
domoticz.log("event: EVENT_TYPE_TIMER")
-- Device triggered use
elseif(triggerInfo.type == domoticz.EVENT_TYPE_DEVICE) then
domoticz.log("event: EVENT_TYPE_DEVICE aaa")
domoticz.log(device.name)
domoticz.log("event: EVENT_TYPE_DEVICE bbb")
local heating = domoticz.devices('heating')
local thermostat = domoticz.devices('thermostat')
local temp_hum = domoticz.devices('temp_hum')
domoticz.log("aaa")
domoticz.log(tostring(thermostat.setPoint))
domoticz.log("bbb")
domoticz.log(tostring(temp_hum.temperature))
domoticz.log("ccc")
if (heating.state == 'On' and temp_hum.temperature < thermostat.setPoint ) then
domoticz.log('turn on heating')
elseif (temp_hum.temperature > thermostat.setPoint) then
domoticz.log("turn off heating")
elseif (heating == 'Off') then
domoticz.log("heating prohibited")
domoticz.log("undefined state")
All switchs are off and in log I see:
2017-12-28 11:59:00.477 dzVents: Info: HEATING_: ------ Start internal script: HEATING_dzVents:, trigger: every 1 minutes
2017-12-28 11:59:00.477 dzVents: Info: HEATING_: event: EVENT_TYPE_TIMER
2017-12-28 11:59:00.544 dzVents: Debug: HEATING_: Device-adapter found for heating: Switch device adapter
2017-12-28 11:59:00.572 dzVents: Debug: HEATING_: Processing device-adapter for heating: Switch device adapter
2017-12-28 11:59:00.576 dzVents: Debug: HEATING_: Device-adapter found for boiler: Switch device adapter
2017-12-28 11:59:00.577 dzVents: Debug: HEATING_: Processing device-adapter for boiler: Switch device adapter
2017-12-28 11:59:00.580 dzVents: Debug: HEATING_: Device-adapter found for left_radiator: Switch device adapter
2017-12-28 11:59:00.581 dzVents: Debug: HEATING_: Processing device-adapter for left_radiator: Switch device adapter
2017-12-28 11:59:00.584 dzVents: Debug: HEATING_: Device-adapter found for right_radiator: Switch device adapter
2017-12-28 11:59:00.585 dzVents: Debug: HEATING_: Processing device-adapter for right_radiator: Switch device adapter
2017-12-28 11:59:00.588 dzVents: Debug: HEATING_: Device-adapter found for thermostat: Thermostat setpoint device adapter
2017-12-28 11:59:00.589 dzVents: Debug: HEATING_: Processing device-adapter for thermostat: Thermostat setpoint device adapter
2017-12-28 11:59:00.593 dzVents: Debug: HEATING_: Device-adapter found for temp_hum: Temperature+humidity device adapter
2017-12-28 11:59:00.594 dzVents: Debug: HEATING_: Processing device-adapter for temp_hum: Temperature+humidity device adapter
2017-12-28 11:59:00.594 dzVents: Info: HEATING_: aaa
2017-12-28 11:59:00.594 dzVents: Info: HEATING_: 13.5
2017-12-28 11:59:00.594 dzVents: Info: HEATING_: bbb
2017-12-28 11:59:00.595 dzVents: Info: HEATING_: 12.699999809265
2017-12-28 11:59:00.595 dzVents: Info: HEATING_: ccc
2017-12-28 11:59:00.595 dzVents: Info: HEATING_: undefined state
2017-12-28 11:59:00.595 dzVents: Debug: HEATING_: Constructed timed-command: Off
2017-12-28 11:59:00.596 dzVents: Debug: HEATING_: Constructed timed-command: Off
2017-12-28 11:59:00.596 dzVents: Debug: HEATING_: Constructed timed-command: Off AFTER 180
2017-12-28 11:59:00.597 dzVents: Debug: HEATING_: Constructed timed-command: Off AFTER 180
2017-12-28 11:59:00.597 dzVents: Info: HEATING_: ------ Finished HEATING_dzVents
Why "undefined state"? It might be "elseif (heating == 'Off') then" - heating switch is off.
After I enable switch "heating", in log:
2017-12-28 11:59:59.671 dzVents: Info: HEATING_: ------ Start internal script: HEATING_dzVents: Device: "temp_hum (1st_floor)", Index: 10
2017-12-28 11:59:59.671 dzVents: Info: HEATING_: event: EVENT_TYPE_DEVICE aaa
2017-12-28 11:59:59.671 dzVents: Info: HEATING_: temp_hum
2017-12-28 11:59:59.671 dzVents: Info: HEATING_: event: EVENT_TYPE_DEVICE bbb
2017-12-28 11:59:59.672 dzVents: Debug: HEATING_: Device-adapter found for heating: Switch device adapter
2017-12-28 11:59:59.672 dzVents: Debug: HEATING_: Processing device-adapter for heating: Switch device adapter
2017-12-28 11:59:59.673 dzVents: Debug: HEATING_: Device-adapter found for boiler: Switch device adapter
2017-12-28 11:59:59.673 dzVents: Debug: HEATING_: Processing device-adapter for boiler: Switch device adapter
2017-12-28 11:59:59.674 dzVents: Debug: HEATING_: Device-adapter found for left_radiator: Switch device adapter
2017-12-28 11:59:59.674 dzVents: Debug: HEATING_: Processing device-adapter for left_radiator: Switch device adapter
2017-12-28 11:59:59.675 dzVents: Debug: HEATING_: Device-adapter found for right_radiator: Switch device adapter
2017-12-28 11:59:59.675 dzVents: Debug: HEATING_: Processing device-adapter for right_radiator: Switch device adapter
2017-12-28 11:59:59.676 dzVents: Debug: HEATING_: Device-adapter found for thermostat: Thermostat setpoint device adapter
2017-12-28 11:59:59.676 dzVents: Debug: HEATING_: Processing device-adapter for thermostat: Thermostat setpoint device adapter
2017-12-28 11:59:59.676 dzVents: Info: HEATING_: aaa
2017-12-28 11:59:59.676 dzVents: Info: HEATING_: 13.5
2017-12-28 11:59:59.676 dzVents: Info: HEATING_: bbb
2017-12-28 11:59:59.676 dzVents: Info: HEATING_: 12.699999809265
2017-12-28 11:59:59.676 dzVents: Info: HEATING_: ccc
2017-12-28 11:59:59.676 dzVents: Info: HEATING_: turn on heating
2017-12-28 11:59:59.676 dzVents: Debug: HEATING_: Constructed timed-command: On
2017-12-28 11:59:59.676 dzVents: Debug: HEATING_: Constructed timed-command: On AFTER 180
2017-12-28 11:59:59.676 dzVents: Info: HEATING_: ------ Finished HEATING_dzVents
Trigger was timer and "temp_hum" device. It is ok.
But after 3 minutes boiler must sitch on - not works. I wait about 10 minutes and boiler is still off.
My function "function turnOnHeating(domoticz)" run every 1 minute and turn on both radiators. But not boiler after 3 minutes.
How can I fix it?
