No connection with Domoticz
Armand0
Post by Armand0 »
Today I downloaded and installed Domoticz on my Raspberry Pi.
Installation was done 'the easy way' using "curl -L install.domoticz.com | sudo bash".
After installation I can not connect to the webpage to configure Domoticz. The webpage is not found. Restarting did not help, network connection is not the problem because i am able to log in with Putty.
I have some basic Linus knowledge but I'm lost right now and don't know what to do to get things working.
BakSeeDaa
Re: No connection with Domoticz
Post by BakSeeDaa »
Armand0 wrote: Friday 22 December 2017 17:42 Today I downloaded and installed Domoticz on my Raspberry Pi.
1) What URL did you try to open?
2) What is the IP address of your Domoticz host?
Armand0
Post by Armand0 »
I did try both addresses
http://192.168.178.111:8080
https://192.168.178.111:443
Hence the IP address is 192.168.178.111
BakSeeDaa
Post by BakSeeDaa »
Armand0 wrote: Friday 22 December 2017 21:56 I did try both addresses
Is the Domoticz service up and running?
sudo service domoticz.sh status
If not, try to start it
sudo service domoticz.sh start
and check status again.
If it fails to start as a service, try to start it manually and see if you get any messages that might tell you why it isn't starting
sudo ~/domoticz/domoticz
Did that help?
CaesarPL
Post by CaesarPL »
I am 99% sure that it’s ssl issue and was described here 100 times...
Armand0
Post by Armand0 »
BakSeeDaa wrote: Saturday 23 December 2017 9:10
Did that help?
I get an errormessage:
"Error while loading shared libraries: libssl.so.1.0.0: cannot open shared object file: No such file or directory"
So it seems to be the famous (but unknown to a newbe like me) ssl issue. Is there a link to a solution available?
::edit
Downloaded the .deb file and placed it on the sd-card. Installed it and can connect now!
Thanks for pointing me in the right direction...
::/edit
