Alexa, Google Home and Siri
jeroenvanpelt
Domoticz version: 3.8153
Post by jeroenvanpelt »
georgesattali wrote:Hello,
I have a question about Google Home and Dz, please : is it possible to have it speaking ?
That is to send recorded sound files from the raspberry to the Google Home ?
GD
If you mean notification type plays, you cannot initiate that from Domoticz.
I have seen google-home-notifier, but you could also try a cli script that allows you to start a sound cast to the Google Home, as if you were chromecasting (chromecast-cli).
Sent from my Pixel 2 XL using Tapatalk
Domoticz latest stable - RaspberryPi 2 B - MySensors - Controlicz - Google Home - RFLink (w/MiLight)
HarryHase
Domoticz version: stable
Post by HarryHase »
Hi, is there actual a problem on controlicz.com?
i can connect from outsite via http and https but contolicz sayed
Controlicz is unable to connect - please check your config
alanlsmith
Domoticz version: Latest β
Post by alanlsmith »
jeroenvanpelt wrote: Sunday 17 December 2017 10:54 If you mean notification type plays, you cannot initiate that from Domoticz.
You can use a switch in Domoticz to trigger a node-red flow which can in turn speak a notification based on the switch state via a Google Home.
Last edited by alanlsmith on Monday 18 December 2017 3:04, edited 1 time in total.
Domoticz Latest β, RPi 4B with 110Gb SSD for Domoticz, RPi 4B with 110Gb SSD for Node-Red & a RPi 2B for logging / IP addressing. RFXCOM, PiZiGate, Z-Wave, Harmony, Hue lamps and a bit of Broadlink.
HarryHase
Post by HarryHase »
It comes back working ... spooky ..
sandervanpelt
Domoticz version: 4.10404
Post by sandervanpelt »
Hi Madgeni,
I just registered. Can you please add me to your beta program?
My email is my forum username @gmail.com
Thanks,
Sander
vboulaye
Post by vboulaye »
Hello Madgeni,
I registered on the controlicz website and would like to try the google home beta integration if possible.
My email is also my forum username at gmail.
Thanks,
Vincent
Vens
Post by Vens »
Hi Madgeni,
Can you add me to the beta program as well, my email address is arj**ven******@ gmail.com. And how can I add controlicz to google assistant?
Thnx!
Noka
Post by Noka »
Hi Madgeni!
Controlicz test say it unable to connect but it work for almost everythings except xiaomi smart plug. I don't understand why. Everythings are right on your side?
Madgeni
Post by Madgeni »
yes, the test is broken - going to remove it whilst i debug.
What's wrong with the xiaomi plugs? Not discovered at all?
Noka
Post by Noka »
It discovered but when I command it by google it work but not every time.. it's strange. I need to repeat several times the command.
Madgeni
Post by Madgeni »
ok that is strange!
Noka
Post by Noka »
Yep, and I don't know why. I search some technics, rename it etc.. on the google side it work but not in domoticz.
fergalom
Post by fergalom »
perhaps someone can help
S7 with 6.01 - home and assistant installed
Joined the controllicz beta
the controllicz "app" is not showing up on assistant when I ask it to "talk to controllicz" "talk to homecontrollicz" or "turn on my lights"
Any pointers? kinda driving me nuts now
jeroenvanpelt
fergalom wrote:perhaps someone can help
Have you signed up for the beta test?
fergalom
Post by fergalom »
thanks yes, signed up and enabled on the google actions page
jeroenvanpelt
fergalom wrote:thanks yes, signed up and enabled on the google actions page
Hmm, same Gmail account I assume?
tohn
Post by tohn »
Discovered that Google home can broadcast messages.
Would this function work with this integration to domoticz?
Madgeni
Post by Madgeni »
fergalom wrote: Monday 18 December 2017 18:37 thanks yes, signed up and enabled on the google actions page
so it's not showing up under settings>Home Control?
demon1977
Post by demon1977 »
Hi Madgeni, I just registered on Controlicz, my email demon****@gmail.com
Can you add me?
Thanks a lot!
fergalom
Post by fergalom »
Yes same gmail account
No "home control" option listed under settings in assistant
Sent from my SM-G930F using Tapatalk
