HUE Dimmer Switch Topic is solved
trixwood
HUE Dimmer Switch
Post by trixwood »
TRiXWooD Scripts viewtopic.php?f=23&t=12145&p=87422#p87422
I've implemented a crude dimmer switch button implementation of the philips remote dimmer switch...
Ow no auto off yet...
Anyway same as the viewtopic.php?f=23&t=11778&p=84624#p846 ... 0Powercode but with the dimmer support.
If your dimmer switch is called "Bedroom Dimmer Remote" on the hue bridge you need to create 4 virtual switches
Bedroom Dimmer Remote On
Bedroom Dimmer Remote Up
Bedroom Dimmer Remote Down
Bedroom Dimmer Remote Off
Anyway response time is between instant and 3 seconds... not happy with that... the best lua script can do i think...
alpha... not finished
Example of usage: Color change of a hue light on dimmer switch press..
if (devicechanged['Hue dimmer switch 2 Button Up'] == 'On') then
  brightness = 80
  iswhite = "false"
  hue = "0" -- red
  idx = otherdevices_idx["Bol Lamp"] -- name lamp
  url = 'http://10.0.0.1:8090/json.htm?type=command&param=setcolbrightnessvalue&idx=' .. idx .. '&hue=' .. hue .. '&brightness=' .. brightness ..'&iswhite=' .. iswhite
  commandArray['OpenURL']= url
Tha Script!
-- TRiXWood May 2016
-- https://www.domoticz.com/forum/viewtopic.php?f=23&t=11778&p=84624#p84624
-- https://www.domoticz.com/forum/posting.php?mode=edit&f=23&p=85418
-- configure Hue Bridge
local hueBridgeIP = '10.0.0.90'
local hueBridgeAPI = '73a968768758585ead808'
-- Max index of lights in the Philips App
-- this is not the number of lights you have!!!
-- since numbering continues if you delete a lamp, so check app!
local hueMaxIndex = 23
local hueMaxIndexSensors = 13
-- Wait time (sec) until script executes
local hueWait = 1
-- Wait time (sec)  until refresh without change (so it stays blue not red)
local hueRefresh = 60
-- Names of the total power & powermeter sensors
local huePower = "HUE Power"
local huePowerMeter = "HUE Power Meter"
-- do not change beyond this line
-- this part will get the Hue status
function getHueLight(id)
   local http = require('socket.http')
   local ltn12 = require('ltn12')
   local json = require('dkjson')
   stop = false
   t = {}
   local url = string.format("http://%s/api/%s/lights/%s", hueBridgeIP, hueBridgeAPI, id)
   b, c, h = http.request{url=url, sink = ltn12.sink.table(t), method='GET'}
   huestring = tostring(table.concat(t))
   local hue, pos, err = json.decode(huestring, 1, nil)
   --print (huestring)
   if (hue.name) then
      hue_name = (hue.name)
      hue_state = (hue.state.on)
      hue_level = (hue.state.bri)
      hue_reachable = (hue.state.reachable)
      hue_model = (hue.modelid)
      if not hue.state.reachable then hue_state = false end
     hue_name = "ERROR"
     stop = true
   return hue_name, hue_state, stop
function getHueSensor(id)
   stop = false
   t = {}
   local url = string.format("http://%s/api/%s/sensors/%s", hueBridgeIP, hueBridgeAPI, id)
   --print (huestring)
   if (hue.modelid == "RWL021") then
      hue_state = (hue.config.on)
      hue_button = (hue.state.buttonevent)
      --print (hue_button)
         hue_button1 = false
         hue_button2 = false
         hue_button3 = false
         hue_button4 = false
      if (hue_button) then
      x = tonumber(string.sub(tostring(hue_button), 1, 1))
      if x == 1 then hue_button1 = true end
      if x == 2 then hue_button2 = true end
      if x == 3 then hue_button3 = true end
      if x == 4 then hue_button4 = true end
      x = string.sub(tostring(hue_button), 4, 4)
      if x == 0 then hue_init = true end
      if x == 1 then hue_hold = true end
      if x == 2 then hue_shortreleased = true end
      if x == 3 then hue_longreleased = true end
      hue_init = false
      hue_hold = false
      hue_shortreleased = false
      hue_longreleased = false
    --  if (hue_button1) then print ("Button 1") end
    --  if (hue_button2) then print ("Button 2") end
    --  if (hue_button3) then print ("Button 3") end
    --  if (hue_button4) then print ("Button 4") end
      hue_battery = (hue.config.battery)
      -- print (hue_battery)
      hue_reachable = (hue.config.reachable)
      --if (hue_reachable) then print ("yes") end
      -- print (hue_state)
      -- print (hue_model)
      if not hue.config.reachable then hue_state = false end
       -- print (hue_reachable)
     hue_name = "ERROR"
     stop = true
function timedifference(s)
   year = string.sub(s, 1, 4)
   month = string.sub(s, 6, 7)
   day = string.sub(s, 9, 10)
   hour = string.sub(s, 12, 13)
   t1 = os.time()
   return difference
-- now check Hue state & correct Domoticz if needed
x = timedifference(otherdevices_lastupdate[huePower])
    print(x)
if timedifference(otherdevices_lastupdate[huePower]) > hueWait then
i = 1
powertotal = 0
repeat
   local hue = getHueLight(i)
   -- Powercode!!!
   -- new powercode create for every lamp a virtual usage (energy) sensor called the name of the lamp with "Power"
   -- Example: "Bureau Lamp" you will need to add virtual usage (energy) sensor called "Bureau Lamp Power"
   hue_power_name = hue_name .. " Power"
   hue_powermeter_name = hue_power_name .. " Meter"
   -- I thought level would be 0..99 but domoticz its 0..15 und hue its 0..254 or something
   -- Anyway defaulting to 0..99
   level = 0
   if hue_state then
       level = hue_level / 2.56
   -- Philips Light Measuring with Powernode 1 (inaccurate :-)
   modelfound = false
   -- Model LCT007 (800 lum v2 HUE bulb)
   if hue_model == "LCT007" then
       modelfound = true
   if level <= 0 then watt = 0.4 end
   if (level > 0 and level <= 6) then watt = 1.6 end
   if (level > 6 and level <= 13) then watt = 1.7 end
   if (level > 13 and level <= 20) then watt = 1.8 end
   if (level > 20 and level <= 26) then watt = 1.9 end
   if (level > 26 and level <= 33) then watt = 2.2 end
   if (level > 33 and level <= 40) then watt = 2.4 end
   if (level > 40 and level <= 46) then watt = 2.7 end
   if (level > 46 and level <= 53) then watt = 3.0 end
   if (level > 53 and level <= 60) then watt = 3.5 end
   if (level > 60 and level <= 66) then watt = 3.9 end
   if (level > 66 and level <= 73) then watt = 4.5 end
   if (level > 73 and level <= 80) then watt = 5.1 end
   if (level > 73 and level <= 86) then watt = 5.5 end
   if (level > 86 and level <= 93) then watt = 6.4 end
   if (level > 93) then watt = 6.7 end
   -- Model LWB006 (White Bulb)
   if hue_model == "LWB006" then
           modelfound = true
   if level <= 0 then watt = 0.3 end
   if (level > 0 and level <= 6) then watt = 1.4 end
   if (level > 6 and level <= 13) then watt = 1.5 end
   if (level > 13 and level <= 20) then watt = 1.7 end
   if (level > 20 and level <= 26) then watt = 1.8 end
   if (level > 26 and level <= 33) then watt = 2.0 end
   if (level > 33 and level <= 40) then watt = 2.2 end
   if (level > 40 and level <= 46) then watt = 2.5 end
   if (level > 46 and level <= 53) then watt = 2.9 end
   if (level > 60 and level <= 66) then watt = 3.8 end
   if (level > 66 and level <= 73) then watt = 4.6 end
   -- fucked up here nog een keer meten 5.2W ???
   if (level > 73 and level <= 80) then watt = 5.5 end
   if (level > 80 and level <= 86) then watt = 6.5 end
   if (level > 86 and level <= 93) then watt = 7.7 end
   if (level > 93) then watt = 9.0 end
   -- Model LST001 Lightstrip
   if hue_model == "LST001" then
       modelfound = true
   if not stop and not modelfound then
      print("HUE Power: Unsupported Lamp Detected Model "..hue_model)
      print("Please add & submit to https://www.domoticz.com/forum/viewtopic.php?f=23&t=11778&p=84624#p84624")
      watt = 0
   if not hue_reachable then watt = 0 end
   if not stop then powertotal = powertotal + watt end
   if not stop and (otherdevices_svalues[hue_power_name] ~= tostring(watt) or timedifference(otherdevices_lastupdate[hue_power_name]) > hueRefresh) then
      --print ("HUE Power (" .. hue_power_name .. ") Power: " .. otherdevices_svalues[hue_power_name] .. " Watt -> " .. watt .. " Watt")
      commandArray[otherdevices_idx[hue_power_name]] = { ['UpdateDevice'] = otherdevices_idx[hue_power_name]..'|0|'.. watt }
      powerold, energyold = string.match(otherdevices_svalues[hue_powermeter_name], "(%d+%.*%d*);(%d+%.*%d*)")
      interval = (timedifference(otherdevices_lastupdate[hue_powermeter_name]) / 3600)
      commandArray[otherdevices_idx[hue_powermeter_name]] = { ['UpdateDevice'] = otherdevices_idx[hue_powermeter_name] .."|0|" .. watt .. ";" .. (powerold*interval+energyold) }
      --print ("HUE Power (" .. hue_powermeter_name .. ") Power: " .. powerold .. " Watt -> " .. watt .. " Watt - Usage: " .. energyold .. " kWh -> " .. powerold*interval+energyold .. " kWh")
  if not stop and hue_state == true and otherdevices[hue_name] == 'Off' then
     -- DOES NOT WORK sometimes it updates sometimes it doesnot...
           commandArray[hue_name] = 'On'
     -- USE
     -- commandArray[otherdevices_idx[hue_name]] = { ['UpdateDevice'] = otherdevices_idx[hue_name]..'|0|'.. 'On' }
      -- print ("HUE Correction (" .. hue_name .. ") State: Off -> On")
   if not stop and hue_state == false and otherdevices[hue_name] ~= 'Off' then
      commandArray[hue_name] = 'Off'
      -- commandArray[otherdevices_idx[hue_name]] = { ['UpdateDevice'] = otherdevices_idx[hue_name]..'|0|'.. 'Off' }
      -- print ("HUE Correction (" .. hue_name .. ") State: On -> Off")
   i = i + 1
    -- more hue lamps then change this...
until(i > hueMaxIndex)
i = 1
repeat
   local hue = getHueSensor(i)
      hue_button1_name = hue_name .. " Button On"
     if not stop and hue_state and hue_button1 and  otherdevices[hue_button1_name] == 'Off' then
        -- print ("HUE Remote Button (" .. hue_button1_name .. ") Off -> On")
      -- commandArray[otherdevices_idx[hue_button1_name]] = { ['UpdateDevice'] = otherdevices_idx[hue_button1_name]..'|0|'.. 'On' }
         commandArray[hue_button1_name] = 'On'
      if not stop and not hue_button1 and otherdevices[hue_button1_name] ~= 'Off' then
       --   print ("HUE Remote Button (" .. hue_button1_name .. ") On -> Off")
       -- commandArray[otherdevices_idx[hue_button1_name]] = { ['UpdateDevice'] = otherdevices_idx[hue_button1_name]..'|0|'.. 'Off' }
      commandArray[hue_button1_name] = 'Off'
      hue_button2_name = hue_name .. " Button Up"
     if not stop and hue_state and hue_button2 and  otherdevices[hue_button2_name] == 'Off' then
        -- print ("HUE Remote Button (" .. hue_button2_name .. ") Off -> On")
         commandArray[hue_button2_name] = 'On'
        --        commandArray[otherdevices_idx[hue_button2_name]] = { ['UpdateDevice'] = otherdevices_idx[hue_button2_name]..'|0|'.. 'On' }
      if not stop and not hue_button2 and otherdevices[hue_button2_name] ~= 'Off' then
       --  print ("HUE Remote Button (" .. hue_button2_name .. ") On -> Off")
      commandArray[hue_button2_name] = 'Off'
       --      commandArray[otherdevices_idx[hue_button2_name]] = { ['UpdateDevice'] = otherdevices_idx[hue_button2_name]..'|0|'.. 'Off' }
      hue_button3_name = hue_name .. " Button Down"
     if not stop and hue_state and hue_button3 and  otherdevices[hue_button3_name] == 'Off' then
         -- print ("HUE Remote Button (" .. hue_button3_name .. ") Off -> On")
           commandArray[hue_button3_name] = 'On'
          --       commandArray[otherdevices_idx[hue_button3_name]] = { ['UpdateDevice'] = otherdevices_idx[hue_button3_name]..'|0|'.. 'On' }
      if not stop and not hue_button3 and otherdevices[hue_button3_name] ~= 'Off' then
        -- print ("HUE Remote Button (" .. hue_button3_name .. ") On -> Off")
         commandArray[hue_button3_name] = 'Off'
         --       commandArray[otherdevices_idx[hue_button3_name]] = { ['UpdateDevice'] = otherdevices_idx[hue_button3_name]..'|0|'.. 'Off' }
      hue_button4_name = hue_name .. " Button Off"
     if not stop and hue_state and hue_button4 and  otherdevices[hue_button4_name] == 'Off' then
        --  print ("HUE Remote Button (" .. hue_button4_name .. ") Off -> On")
          commandArray[hue_button4_name] = 'On'
         --       commandArray[otherdevices_idx[hue_button4_name]] = { ['UpdateDevice'] = otherdevices_idx[hue_button4_name]..'|0|'.. 'On' }
      if not stop and not hue_button4 and otherdevices[hue_button4_name] ~= 'Off' then
         -- print ("HUE Remote Button (" .. hue_button4_name .. ") On -> Off")
          commandArray[hue_button4_name] = 'Off'
         --       commandArray[otherdevices_idx[hue_button4_name]] = { ['UpdateDevice'] = otherdevices_idx[hue_button4_name]..'|0|'.. 'Off' }
   i = i + 1
until(i > hueMaxIndexSensors)
if (otherdevices_svalues[huePower] ~= tostring(powertotal)) or timedifference(otherdevices_lastupdate[huePower]) > hueWait then
   commandArray[otherdevices_idx[huePower]] = { ['UpdateDevice'] = otherdevices_idx[huePower]..'|0|'.. powertotal }
   powertotalold, energytotalold = string.match(otherdevices_svalues[huePowerMeter], "(%d+%.*%d*);(%d+%.*%d*)")
   interval = (timedifference(otherdevices_lastupdate[huePowerMeter]) / 3600)
   commandArray[otherdevices_idx[huePowerMeter]] = { ['UpdateDevice'] = otherdevices_idx[huePowerMeter] .."|0|" .. powertotal.. ";" .. (powertotalold*interval+energytotalold) }
   -- print ("HUE Power (" .. huePower .. ") Power: " .. otherdevices_svalues[huePower] .. " Watt -> " .. powertotal .. " Watt")
   -- print ("HUE Power (" .. huePowerMeter .. ") Power: " .. powertotalold .. " Watt -> " .. powertotal .. " Watt - Usage: " .. energytotalold .. " kWh -> " .. powertotalold*interval+energytotalold .. " kWh")
Tweek
Domoticz version: 3.8153
Re: HUE Dimmer Switch
Post by Tweek »
Great work, got it all set up according to your guide. Though you mention
I am only able to get a response time as soon as the next Domoticz script time (the next full minute that will run the Lua script). Is the script supposed to run as a script_time Lua?
Tweek
Post by Tweek »
Tweek wrote: Sunday 17 December 2017 18:20 Great work, got it all set up according to your guide. Though you mention
For anyone else with this question:
I solved this eventually by running a python script in a loop which changes a virtual switch every 3 seconds through a http command. This virtual switch triggers your Lua script which I broke up in the remote part, which runs every 3 seconds now, and the Hue power usage script which is run as a time script to put less load on the server.
Python script that forces a virtual switch update:
#!/usr/bin/python
import time
import urllib2
while True:
        urllib2.urlopen("http://192.168.2.9:8080/json.htm?type=command&param=updateuservariable&vname=updateHueStatus&vtype=integer&vvalue=1")
        time.sleep(3)
Where vname stands for the name of the virtual switch.
