Timer scripts don't work if no devices change
Kasvand
Post by Kasvand »
I'm having an issue. It seems Domoticz only runs scripts when something changes somewhere. This means LUA scripts with timer functions don't work!
I created a LUA script that gives an alarm if a door remains open for more then a minute. The script itself works fine! However - the alarm doesn't sound if no device in my Domoticz set-up changes after this minute is reached.
It does work again when a device changes status, doesn't matter which device - can be a totally different device used in an entirely different script. But if nothing changes in my set-up it seems Domoticz falls asleep and timer functions alone won't wake Domoticz up...
Anyone know why this is? Is there a way to solve this? Been browsing through the settings, but found nothing that makes Domoticz fall asleep almost immediately from the moment no device changes no more.
jvdz
Domoticz version: 4.107
Re: Timer scripts don't work if no devices change
Post by jvdz »
Is this an internal script created with the internal editor or a file in the script/lua directory?
Internal: What are the settings for the script at the right side of the window?
External file: What is the name of the script file?
Maybe you can show the script as well?
Jos
febalci
Post by febalci »
Did you by any chance leave 'All' or 'Device' in your script settings? I believe it should be 'Time' in Events settings page in order to execute time scripts.
Kasvand
Post by Kasvand »
t1 = os.time()
s = otherdevices_lastupdate['Koelkast']
-- returns a date time like 2013-07-11 17:23:12
year = string.sub(s, 1, 4)
month = string.sub(s, 6, 7)
day = string.sub(s, 9, 10)
hour = string.sub(s, 12, 13)
print (s)
difference = (os.difftime (t1, t2))
if (otherdevices['Koelkast'] == 'Open' and difference > 60 ) then
    print ("Koelkast open!")
    commandArray['MP3']='Set Level: 16'
It's a script in Domoticz (no external file). I tried setting Device and Time and All.
With the setting 'All' it sortof works, except that the alarm triggers every millisecond and thus plays no sound at all.... :/
Update: With setting Time it does seem to work a bit - however this polls every minute. This means the alarm can have a delay of max. a minute.... Not really practical. But it does work. A bit....
jvdz
Post by jvdz »
Kasvand wrote: Tuesday 12 December 2017 19:44 Update: With setting Time it does seem to work a bit - however this polls every minute. This means the alarm can have a delay of max. a minute.... Not really practical. But it does work. A bit....
That is the idea for the Time scripts, which are run every minute on the minute. :)
Jos
