Domoboard - Windows installation
Moderators: leecollings, wez3
Forum rules
Before posting here, make sure you are using the latest Beta or Stable version.
In order to fix issues or add features these have to be reported on the Domoboard Github pages.
This makes it possible to keep track of issues/features on a centralized place.
Refer to the issue of the github tracker when possible.
This subforum is meant to discuss issues and/or feature requests, or anything else related to Domoboard.
JvdBosch
Could anybody give me some pointers on installing domoboard on a Windows based Domoticz installation?
Henrik
Re: Domoboard - Windows installation
I would like to know too.
squandor
- Domoticz version: 3.5837
Hi Henrik,
Sorry for the late reply, but its pretty straight forward.
You can clone the github page and edit de config and set de domoticz url in the config.
When that has been done you can run domoboard by the command: python server.py -c configuration.conf -d
It should work like that
moengiant
If you want it to be windowless - no command line window open - rename the script to server.pyw and then run it. Use the cd command to go into the directory where you have the script and then run python server.pyw -c configuration.conf -d
This all assumes you already have installed python on your Windows box - hope this helps.
I'd rather have a bottle in front of me than a frontal lobotomy
