XML as input information for Domoticz-readout & -switching
- Domoticz version: mixed
The PVLogger of my solar system has xml-output at a specific IP-address at my LAN.
Calling that IP-address with Firefox (or any browser) with command status.xml, I get as output a string of characters.
In Firefox the page-source for the latest XML-readout converts to the following example response:
<response>
<gauge_power>358</gauge_power>
<gauge_temp>0.0</gauge_temp>
<gauge_vpv>94.5</gauge_vpv>
<gauge_iac>0.0</gauge_iac>
<energy_today>5.667</energy_today>
<energy_total>1755.4</energy_total>
<hours_total>4347</hours_total>
<time_stamp>20140224 16:13</time_stamp>
</response>
For Domoticz I would like to display this information like the weather-data.
And secondly I would like to apply the value of <gauge power> as triggerpoint for switching.
Anyone with experience in such application?
Script(s) available which can do that function?
<response>
</response>
- elythomaslumber
- Domoticz version: 2023.1
Re: XML as input information for Domoticz-readout & -switchi
That gave me the chance to play a little with XML I never did before.
Do you think that the code below could be a base for a solution?
Regarding your first question there's a possibility: http://www.domoticz.com/wiki/Domoticz_API/JSON_URL%27s
Look at the bottom for "Experts commands". I tried it it some weeks before but failed with a chrashed database. Don't know what I did wrong but never touched again
Examaple:
Examaple:
#!/usr/bin/php
<?php
$xmlString = "<response>
</response>";
$xml = simplexml_load_string( $xmlString );
//echo $xml->gauge_power;
$gp = $xml->gauge_power;
echo $gp;
if ( $gp > 200 ) {
$ch = curl_init("http://192.168.1.18:8080/json.htm?type=command¶m=switchlight&idx=4&switchcmd=On&level=0");
curl_exec($ch);
curl_close($ch);
else if ( $gp <= 200 ) {
$ch = curl_init("http://192.168.1.18:8080/json.htm?type=command¶m=switchlight&idx=4&switchcmd=off&level=0");
curl_exec($ch);
curl_close($ch);
Should not be so difficult, but I have no/little experience with XML and with Domoticz.
To me should look like:
1) read XML from IP-address
2) sort the data in the XML read-out to get the required parameter
3) display as information
4) make available as data for switching etc.
Correct approach? Or different plan-of-attack required?
- elythomaslumber
Yes, the data in XML format you received by a http request have to be "stored" in a variable like I used for this example: $xmlString
Then I used some "simplexml" commands as explained here: http://www.w3schools.com/php/php_xml_simplexml.asp
Finally with the CURL command you can switch Domoticz devices.
I don't know if you use an Raspberry Pi. If so, you need PHP5 and CURL which can be installed by:
sudo service domoticz.sh stop
sudo su
cd
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install php5
sudo apt-get install php5-curl
exit
sudo service domoticz.sh start
- CopyCatz
- Developer
- Target OS: -
I think the easiest way to do this is by using python. It's a lot easier than php and handles xml input in a very simplified way.
I'm not expert but in lua, you can use lxp, no?
A little late, bit check my post here: http://www.domoticz.com/forum/viewtopic.php?f=23&t=2505
I'm doing the same with the standby status of my Dreambox, which is also posted in XML after a curl command. You can leave out the curl of course and use xmlstarlet directly on the file.
I found solution too I use php and simplexml
I still have issues with activating RaspPi camera module. Domoticz freezes when adding the camera. Adding webcam or IP cam works perfectly
Cut down your exam stress by using our latest 642-747 dump and EMC demos.We provide updated Cornell University questions with 100% pass guarantee along with Youtube training.
Re: XML as input information for Domoticz-readout & -switching
http://www.domoticz.com/forum/viewtopic ... 472#p84594
http://<ip-address>/real_time_data.xml
The resulting XML-file looks like
<real_time_data><state>Wait</state><v-grid>229.6</v-grid><i-grid>0.07</i-grid><f-grid>49.98</f-grid><p-ac>0</p-ac><temp>18.3</temp><e-today>0.0</e-today><t-today>0.0</t-today><e-total>4576.2</e-total><CO2>4562.47</CO2><t-total>14435.6</t-total><v-pv1>275.0</v-pv1><i-pv1>0.02</i-pv1><v-pv2>-</v-pv2><i-pv2>-</i-pv2><v-bus>276.5</v-bus></real_time_data>
initial attempt in another thread ......
