Apologies for the long post but just need to list all the steps I took that have resulted in my Domoticz install dying.
New Broadlink RM Device arrives
Setup on Wifi, set static IP within DHCP for device
Checked Pre-reqs and had Python 3.6.1 and Domoticz latest Beta so no issues there I thought
Downloaded the Setup.exe from the Dropbox link listed on the Wiki and installed, got the red screen (heres where all the trouble started
Downloaded latest Python just to make sure, upgraded to 3.6.2, re ran the Setup.exe - same issue red screen
Downloaded latest Beta of Domoticz just to make sure, upgraded, re ran the Setup.exe - same issue red screen
At this point I researched the forums and attempted some of the suggestions other users had been provided with
Tried extracting the .exe manually running the pycrypto-2.6.1.win32-py3.4.exe, gave an error saying couldn't find Python 3.4.0
More research suggested the for Win x64 versions remove all python versions, install 3.4.0 and then manually run pycrypto-2.6.1.win32-py3.4.exe and setup.exe as admin. Tried this and yep all worked, no red screen!
buttttt now if I went to my Domoticz webconsole I could not get in "wrong password" even though I 100% know it was the right password. Restarted the Domoticz service, still same issue.
Freaking out I then reinstalled the latest Python. Bam I could get in to the webconsole again (briefly), I could log in and setup the Broadlink but Windows/interface was acting very laggy and weird with focus being lost as you clicked on things or tried to type in fields.
So I am now looking at some suggestions to get everything back working again without losing my setup/config. I can reset the service and very briefly I can get into the console but it shows my Aeotech Stick offline and then after it lags and cannot be accessed. Refreshing or opening the a new browser window and can no longer get to web interface again until I reset the service again, obviously something is wigging out
HELP!
